07-24-2014, 06:08 PM | #4 |
2680
Rep 3,406
Different engine. These N55s run obnoxiously hot...standard operating oil temp is 240-250. Seems quite ridiculous to me. In contrast, my GTR with more than double the power is consistently in the mid-170s. I have to wind out several gears to get it north of 190.
07-24-2014, 08:15 PM | #5 | |
772
Rep 1,502
My 335i is always at the exact same temp shown in the pic. I thought it's be a bit warmer given today's heat (I'm in Phoenix too), but oil temp was the same today as on an 80F day. 170F actually sounds a bit low to me.... your thermostat probably isn't even open at that temp. |
07-24-2014, 09:19 PM | #6 |
206
Rep 472
Ran the car all day flat out against E92 M3's, C7 Corvettes, Boss 302 Mustangs etc road racing and the car never went over 240-245F.
A/C was off the whole time. Ambient temps were mid 80's. Was doing 20min sessions, 6 sessions total. On Lightning@ NJMP Brakes are squeaking though Giving chase by -mik3ymomo- NewJersey Motorsport's Park by -mik3ymomo- BMW 435xi Msport by -mik3ymomo-
18’ 540i XDrive M Sport
https://www.flickr.com/photos/mik3ymomo/ |
07-24-2014, 09:44 PM | #7 | |
199
Rep 1,114
I love this photo, hope my GC looks just as good from that angle! Same wheels too.
My Ride! : 2015 428i GC (F36) - MSport, Alpine, Black Leather, MBrakes, Adaptive, Sport Seats, Hex. Alum w/Piano, HK Sound, 400m's, Comfort Acc. When I’m not Driving: https://youtube.com/shorts/ViKD_Hj5htE?feature=share
07-24-2014, 09:47 PM | #8 |
206
Rep 472
Stock
07-24-2014, 09:53 PM | #9 |
199
Rep 1,114
Looks great! But some reason in the photo they don't look black?
07-24-2014, 10:03 PM | #10 |
253
Rep 1,003
Drives: 16 340i, 15 X3d, 91 318i
The operating temperature is controlled by the thermostat, which as we know controls flow via the electric water pump instead of a conventional plunger-type thermal switch. The set temperature changes based on driving mode - sport mode is lowest, normal is hotter, Eco pro is hottest. I don't recall exactly but I think it's something like 180-225-245 degrees F. Cooler is nominally better for performance, hotter reduces friction for efficiency. I've posted on this before, search to find the technical manual to learn more about it, interesting stuff.
07-24-2014, 10:05 PM | #11 |
206
Rep 472
Car was driven in Sport + during every session
07-24-2014, 10:40 PM | #12 |
116
Rep 347
I just randomly checked on my 435GC that I drove home for only about a 20 min ride. The hood and engine compartment are way more hot/warm than I'm used to. I got home 40 mins ago. guess it's been awhile since I've had a turbo car....
07-25-2014, 04:50 AM | #14 |
123
Rep 441
You can start to flex the engine's muscle once the oil gauge comes off its rest stop.
EBII 335i Touring M-Sport (Munich built July 2013)
| 6 Speed Manual | 2VF Adaptive M Suspension | 2VL Variable Sports Steering | 403M wheels | M-Sport brakes | 688 Harman Kardon | 494 Heated Seats | 610 HUD | 322 Comfort Access | 5AC High-Beam Assist | 609 Navigation Professional | |
07-25-2014, 05:50 AM | #15 |
1435
Rep 4,724
250 is a normal operating temp. The car is designed to run that hot.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
07-25-2014, 11:04 AM | #16 |
772
Rep 1,502
I got curious so I had a look at the N55 engine description from BMW. Here's what the manual says:
The engine control unit regulates the following temperature ranges: • 108°C/226°F = Economy mode • 104°C/219°F = Normal mode • 95°C/203°F = High mode • 90°C/194°F = High mode and control with characteristic map thermostat The engine management sets a higher temperature (108°C) when, based on vehicle operation, the engine control unit detects ”Economy” mode. The engine is operated with relatively low fuel requirements in this temperature range. The internal engine friction is reduced at higher temperatures. The increase in temperature therefore results in low fuel consumption in the low load range. The driver wishes to utilize the optimum power developed by the engine in “High and control with characteristic map thermostat” mode. For this purpose, the temperature in the cylinder head is reduced to 90°C. This temperature reduction promotes improved volumetric efficiency, thus resulting in an increased engine torque. Adapted to the relevant driving situation, the engine control unit can now regulate a defined operating range. In this way it is possible to influence the fuel consumption and power output through the cooling system. System Protection If the coolant or the engine oil overheat during operation, certain vehicle functions are influenced to the effect that more energy is available to the engine cooling system. These measures are divided over two operating modes: • Component protection - Coolant temperature between 117°C/242°F and 124°C/255°F - Engine oil temperature between 150°C/300°F and 157°C/314°F - Result: The output of the air conditioning system (up to 100%) and of the engine is reduced • Emergency - Coolant temperature between 125°C/257°F and 129°C/264°F - Engine oil temperature between 158°C/316°F and 163°C/325°F - Result: The power output of the engine is reduced (up to 90%) |
07-25-2014, 11:15 AM | #17 |
404
Rep 962
Maybe slightly off topic, but is there any reason to monitor the coolant temperature as long as oil temperature is available? I assume that if the cooling system failed the oil temperature would rise north of 250F. Is this correct?
07-25-2014, 11:19 AM | #18 |
72
Rep 876
Excellent post chief!!
Definitely ties in with my real world experience. On my MSport RWD 335i, when I am out playing on the back roads really pushing it in sport or sport+ the car actually runs cooler than on my normal commute in comfort mode. |
07-26-2014, 08:15 AM | #19 |
813
Rep 1,986
Drives: 2014 335i xdrive, 2014 X5 3.5d
Because when your driving fast, there is more airflow through the intercooler, hence it keeps it at a cooler temperature
07-26-2014, 09:56 AM | #21 |
1435
Rep 4,724
Who really runs their car in Econ Pro anyway..?
