07-21-2014, 08:38 PM | #1 |
15
Rep 205
6-speed transmission failure
34,000 miles 2nd gear would grind like a blender. Look at service statement...........Very Disappointed....
07-21-2014, 08:47 PM | #3 |
15
Rep 205
Just wait mine started hard shifting then started grinding even on slow easy very easy granny shifts. lol
07-21-2014, 10:11 PM | #5 | |
244
Rep 701
Every 6mt i have owned was like that. 3rd to 2nd was hard and 2nd to 1st is almost impossible ( you never really need to anyways) i find Rev match to 2nd makes it easier though. |
07-21-2014, 10:24 PM | #7 |
793
Rep 1,627
Sorry to hear that... I was just thinking how smooth the F32 gearbox is compared to the E92... Still, 2nd gear engagement could be smoother.
07-21-2014, 10:35 PM | #8 |
Computer Janitor
Rep 272
I had a weird issue with mine where it was grinding and popping out of gear when I would let the clutch out after shifting into 2nd. It would go into gear fine but the second I would let the clutch out it would pop out. Went away on its own and hasn't happened again.
At least they replaced it though. That's one of the things that makes me paranoid about owning an expensive car with a stick - the looming possibility that if there's any kind of a failure they might try to blame it on driver error, even if it's a legit defect.
2012 328i Sport Line 6MT (Turned In)
2015 Ford Mustang GT Premium (Current) |
07-22-2014, 12:32 AM | #10 |
171
Rep 688
I just came from a 2005 TL that was notorious for having a 3rd gear that would just pop out. My car was out of commission for nearly 5 weeks while they replaced the transmission (under warranty of course). Not reassuring hearing something similar might happen to my F30 as well. Ugh.
2014 Carbon Black 535i M Sport - Bootmod3 / M Performance Exhaust / Carbon Graphite Vorsteiner V-FF 103 / KW V2
Retired- 2013 MG 328i Sport Line 6MT - BMS Stage 1 / M Performance exhaust / M Performance steering wheel / M Performance shift knob/boot |
07-22-2014, 07:13 AM | #11 |
15
Rep 205
Yes sir they replaced the MT pretty fast they had the car about 10 days. Just very disappointed paying $50,000 for a car that had that many problems in so little time.
07-22-2014, 08:27 AM | #12 | |
Computer Janitor
Rep 272
Per the RO you've had the car since October of '12 and it has 34k miles on it. If these are the only problems you've had in that timeframe, you're better off than a lot of people on these forums.
07-22-2014, 08:59 AM | #13 | ||
251
Rep 640
Example: We bought brand new 2009 Audi A6 3.0T. Had LED DRL go out three times, Water Pump Burst resulting in Engine Overheat, TPMS malfunction twice, ECU Malfunction once, and the grand finale of the battery draining completely every 3 days. Was only 10 months old with 13,000 miles. We paid $62,000, and nobody expected these problems but it doesn't mean these things can't happen. Audi ended up giving us a brand new 2010 Audi A6 with a higher Sport Package and this car was perfect for 65,000 miles. There is bound to be a bad seed here and there with mass produced vehicles. 10 days out of service is not bad. Sorry to hear you had troubles with it in the first place, but be lucky it wasn't something more severe like others have had. You know you truly have a bad car if it's in for service more than you can drive in.
2018 Audi RS7 4.0T
2006 BMW e46 330Ci Convertible ZHP 2010 Audi S5 4.2L [Sold] 2014 BMW 335i xDrive M-Sport [Sold] 2010 Audi A6 3.0T [Sold] |
08-11-2014, 08:19 PM | #15 | |
15
Rep 205
08-11-2014, 09:13 PM | #16 |
3187
Rep 10,509
08-11-2014, 10:03 PM | #17 |
15
Rep 349
08-12-2014, 07:52 AM | #18 |
344
Rep 941
I had the exact problem on a 2013 335 xdrive. From day one I would get the occasional grind when shifting into second gear. Lately it was doing it every single time. Brought car in on Wednesday, instantly diagnosed 2nd gear synchros, replaced gearbox and got my car back on Thursday. I almost fell out of my chair when they called me the next day to pick it up. Lucky for me there was 1 6MT transmission in stiock at the depot in Toronto.
2019 M4CS Lime Rock Grey, MP HAS, GC camber plates, MPE
08-12-2014, 08:03 AM | #19 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
So they apparently changed the 6-speed manual from the one used in the E9x series? I say this because I had a 2007 E92 335i tuned to over 400HP (flywheel) and drove it over 40,000 miles with ZERO transmission problems; I didn't baby it, but I also made it a point to rev-match when downshifting. Did a good bit of speed-shifting, especially the 1-2 shift, never once heard a grind.
I bought my '07 E92 as a CPO in early 2008, with an in-service date of Sept. 2006. At around 36K miles, I was out of the warranty period which on a CPO runs from in-service date, not purchase date. I had the differential and transmission drained and re-filled with Red Line fluids - one specifically designed for each component. Red Line MTL in the gearbox seemed to make the trans shift a little smoother effort-wise, but again, no grinding. The "lifetime fill" for trans and diff have long been dismissed as inadequate, according to knowledgeable BMW technicians such as Mike Self in Roundel magazine. If your trans is under warranty, I'd most definitely get BMW to fix it, but I'd seriously consider refilling the trans after that many miles.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
08-12-2014, 10:31 PM | #20 |
24
Rep 293
I took mine in last week for 2nd gear issues (Friday) they called me Monday this week to let me know a new transmission was on the way.
Car has 60k miles, so glad I got the extended warranty... |
08-13-2014, 09:14 AM | #21 |
127
Rep 764
Lol. By that logic, BMW's are garbage too since yours (along with some of the other forum members) have 'so many problems'?
08-13-2014, 10:13 AM | #22 | |
Curmudgeon and Pedant
690
Rep 3,489
Note however, that the early E9x used a G6-53... |
