I think I was SPEED LIMITED last night
07-20-2014, 04:47 PM | #1 |
40
Rep 493
Drives: 2013 BMW 335is
I was driving home last night (on a closed road with another professional driver in front of me) in a Cayman GTS. After another professional driver moved out of the way, the Cayman took off. I hit overboost and was able to close the gap very quickly. However, he was slowly start pulling away from me till 7th gear kicked in. At 145mph, we were side by side. But then, he was gone. I wasn't really watching the gauges and I don't recall seeing anything on the Infotainment screen either. But, it felt like I hit the speed limiter at 150mph or something. The Porsche isn't limited till 175mph. So, my question to all of you is... Have any of you hit your SPEED LIMIT yet? If so, what did your BMW do? Did it display anything on the dash or on the Infotainment screen? And, is there anything logged on the ECM - like with Launch Control? PORSCHE GTS vs BMW 335is 340hp/280tq vs 330hp/370tq HUGE DIFFERENCE IN WEIGHT |
07-20-2014, 04:57 PM | #2 |
I have to return some video tapes
362
Rep 4,712
i have hit the limiter at 155. no lights come on, nothing really happens. it just stops going faster
13 Carbon Black e70 X5M - 13 Black Sapphire e92 335i - 10 Le Mans Blue e92 335i - 09 Monaco Blue e92 328i xdrive - 07 Sparkling Graphite e92 328xi
07-20-2014, 05:00 PM | #3 |
16
Rep 238
Since I have the non-sport version my 328i is limited at 135. Nothing happens, whenever I hit 135 it just lays off you can feel it has more but it just stops going.
07-20-2014, 05:00 PM | #4 | |
15
Rep 261
Drives: 2011 E93 335is AW Coral Red
Awesome. I would think if you are tuned then the tune removes the speed limiter. If not tuned then that is a very good possibility.
Here is some information from Burger Motrosports. BMW models with Sport Package are Electronically governed at 155 MPH without Sport Package are electronically governed at 135 MPH Quote:
2011 E93 - 335is - AW/CR
vrsf 7 FMIC| vrsf DP | COBB |
07-20-2014, 05:11 PM | #5 | |
40
Rep 493
Now that I am speed limited again, I'm pretty sure I hit it at 155mph. Nothing happened. The car was pulling fine - and then it wasn't. Felt like I had lifted. So, I had to watch the Porsche pull away. |
07-20-2014, 05:16 PM | #6 | |
362
Rep 4,712
07-20-2014, 05:18 PM | #7 |
866
Rep 5,452
I ran on the limit for a while on the autobahn with mine, it is a very soft limiter, you just get to 155 and it just stops going faster, almost like it is drag limited, just sneaks up on 155 and goes no faster - no warning or anything, just stops accelerating (no longer a problem, speed limiter has been flashed out now!)
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
07-20-2014, 06:05 PM | #8 |
Libertarian
132
Rep 1,577
My Vishnu tune supposedly removes the electronic limiter, but I've not gone that fast in this car yet...
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
07-20-2014, 06:13 PM | #9 |
Rep 105
All my cars have this intermittent speed limiter kick in. Generally around 90-100 mph, then it forces me back to 70-75ish. It only happens when my wife is in the car...
Car is speed limited, but certain tuners will resolve that. Here's a link to the ones that do: http://www.e90post.com/forums/showthread.php?t=374508 |
07-20-2014, 06:58 PM | #10 | |
59
Rep 552
Try this tune instead. Don't let her have coffee, reserved for the driver! She's out and you're having fun. Works most of the time |
07-20-2014, 10:16 PM | #11 |
The Crowing
111
Rep 2,005
Same thing happened in my 135i once it hit 155 it did exactly what you describe. Now that I have the BMS backend flash I had it to 160 to test out the delimiter claim. And it kept pulling. Then I had high cross winds and things got a little sketchy so I let off.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
07-21-2014, 01:19 PM | #12 |
106
Rep 925
I believe the M-sport package cars like mine do not have a speed limiter, if you have a 335IS, I would expect the same?
2016 M235i | BSM | 6SPD | BMS JB4 | Dinan Intake | Wagner Evo 2 Comp IC | VRSF DP | ER CP | Dinan Exhaust | M Performance LSD | M Performance Springs
Gone: 2016 F30 340i, 2015 Corvette Z06, 2011 E92 335i, 2007 E92 335i, 2008 Corvette Z51, 1999 E46 323i, 2001 Boxster, 1999 Carrera 2, 1997 Corvette, 2001 Camaro SS |
07-21-2014, 01:23 PM | #13 |
BMW Love
Rep 81
07-21-2014, 01:24 PM | #14 |
106
Rep 925
Sorry you are right... what a bummer I kept thinking it was de-limited not just bumped up from 130 to 155 :/
07-21-2014, 01:26 PM | #15 |
39
Rep 315
+1 to the smooth limiting. I've got 155 in my 535i a few times and each time I could feel the engine slowly cut the power right around the 155 mark. No lights, no sudden stopping, etc.
My speedo is actually off by ~5% so it was maxed out at 160mph when the speed limiter kicked in. I probably wouldn't have even noticed I hit the speed limiter if it weren't for my GPS stopping at 155.
07 335i
Mods: JB4 + MHD BEF, RB Twos Plus, Phoenix PI Manifold, Dual Walbro 450 LPFP's, DCI, VRSF DP's, VRSF 7.5" FMIC, VRSF CP + TiAL BOV, VRSF inlets & aluminum outlets, TC Kline SA, M3 F/R control arms, M3 subframe bushings |
07-21-2014, 01:28 PM | #16 | |
86
Rep 1,849
2011 E90 / Premium Package / Stage 2 PPK / Performance Suspension
07-21-2014, 01:29 PM | #17 |
need4speed
510
Rep 1,903
All NA BMW's have a speed limiter. Sports package and m sport package is limited to 155, non sport is limited to 135. If you flash your ECU then you'll no longer have a speed limiter besides how big your balls are.
N54
07-21-2014, 01:30 PM | #18 |
39
Rep 315
Thats how mine is. Hence the fact it said I was doing 160+ when I was really hitting the speed limiter at 155mph.
07 335i
07-21-2014, 01:37 PM | #19 | |
28
Rep 583
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
07-21-2014, 01:39 PM | #20 | |
86
Rep 1,849
Incidentally, the fastest I've gotten my 3 up to is 169mph.
07-21-2014, 02:17 PM | #22 |
15
Rep 156
Drives: 2007 e92 335i
I've hit the speed limiter a few times. With around e40. Felt like I hit a wall since my speed was still climbing so fast. No lights or warnings though.
BMS
451whp/489wtq @ EAS |
