07-14-2014, 12:31 PM | #2 |
1399
Rep 5,262
Enet Cable search on ebay http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
E-sys software (ask here http://www.bimmerfest.com/forums/sho...38188&page=121) token for e-sys (you can buy from one of the links in the e-sys installation instructions) my cheat sheet :-D https://drive.google.com/file/d/0Bwv...it?usp=sharing NCD CAFD tool http://www.bimmerfest.com/forums/sho...&postcount=108 Whatever you do never ever ever press "Code Default Values" ... you have been warned :-) good video Last edited by pikcachu; 12-14-2014 at 02:36 AM.. |
BMDUBGIRL32.50 |
07-14-2014, 01:15 PM | #3 | |
Rep 39
07-14-2014, 01:32 PM | #4 |
1399
Rep 5,262
ya you can code DVD in motion... look at the cheat sheet and also play video from USB stick instead of DVD and DivX and other video formats
08-09-2014, 07:05 PM | #5 | |
526
Rep 1,078
08-09-2014, 07:11 PM | #6 |
Rep 21
08-09-2014, 09:48 PM | #7 |
1399
Rep 5,262
Do not press "Code default values"... to go to factory settings you use "Code" (also know as VO code) instead of "Code FDL"
If you use "Code default values" you might have to have your car towed to the dealer as it might not start back up.... Really good video here |
08-13-2014, 07:53 PM | #9 |
255
Rep 1,040
Look at the "How To" instructions for obtaining your token. This will need to be purchased to activate the changes to your car. It is always good to take a backup of the FA and VO everytime you have a coding session. This will give you a good point in time should you need to undo a previous change. Copy the backup to another device like a thumb drive and store it away from your computer.
08-14-2014, 02:09 AM | #10 |
526
Rep 1,078
In the event something goes wrong, how does one restore the data from a working backup of the ncd files? I'm assuming you copy over all the files (ovewrite) from your backup to the CAF folder, and then what action will need to be done on Esys?
08-14-2014, 10:57 AM | #11 |
1399
Rep 5,262
No need to overwrite....
Open esys and then either load a backed up SVT or you need to do "Read SVT" then for the ECU's CAFD you want to update just do right click - New - FDL and pick the backed up ncd file... make sure you pick the right one else it won't load values meaning you can't load the FEM_BODY ncd into the HU_NBT... then right click the CAFD again and do "Code FDL and do the same for each FDL you want.... Also if you just want to go back to the factory setting you code VO code the whole car and will reset any custom coding...just select the top "SVT" root and click "Code" BY NO REASON EVER CLICK "CODE DEFAULT VALUES" |
08-14-2014, 11:00 AM | #12 |
48
Rep 207
Even though the software is readily available on the net...
You need to be extremely careful when working with E-SYS! You can brick your car. You'll then either have to play dumb, or beg the service people at the dealer to fix it. Make backups, move slowly, and understand what you are going to to, BEFORE you do it. Anyone in the CA Bay Area, I'm happy to help you set up and give you some tips on your coding setup, or do coding for you (for free!) |
08-14-2014, 12:09 PM | #13 | |
Rep 75
Im not in the Bay area but am interested in coding myself when my car arrives shortly. Can you elaborate on where to get the software. thanks.. |
08-14-2014, 12:10 PM | #14 |
1399
Rep 5,262
it's in the 2 post http://www.bimmerfest.com/forums/sho...38188&page=121
08-14-2014, 12:27 PM | #15 | |
Rep 75
08-25-2014, 06:30 PM | #17 |
Rep 2
system requirements
GREAT info in here, thanks pikcachu. For somebody who's not a programming genius, do you know what minimum system requirements I would need on my laptop to run E-SYS?
09-23-2014, 10:38 AM | #21 |
They like my Swag...
433
Rep 3,762
Drives: 15 GSM 435i GC
Awesome stuff.
2015 435i Gran Coupe - Current 2008 AW 135i - Sold |
10-02-2014, 03:35 PM | #22 |
58
Rep 69
Any advice on coding the Enhanced Bluetooth (6NS)? My M235i is coming with Pro-Nav (ZNP), but not Enhanced Bluetooth. Would love to get this sorted.
I've got an ENET cable on its way to me, and ready to go with all the E-Sys tools (got version 3.25.3, with token and pin, and PSdZData 52.1). |
