Need some guidance…
07-11-2014, 09:48 AM | #1 |
Rep 46
Need some guidance…
I have a 2009 335d with the sports suspension. I have 19” rims with 275r19 tires in the rear. When I drive the car at high speeds and take a dip or turn sharply around a corner my tires scrap. I think at 95k miles that the rear springs have become week and need of replacement. What I need guidance on, is there a temporary way to make the springs stiffer and possibly add ride height (1”) through the use of a coil spring booster and\or isolator, while I save money to get a coilover kit?
Thanks. |
07-11-2014, 09:55 AM | #2 |
69
Rep 1,766
Wait, did you recently swap to 19" or have you had them for a while and this scraping issue only started happening? Also, when you mean by "scraping," are your tires rubbing?
JBD @ 100% | KW ST Coilovers | M3 rep. front bumper | 888Concepts AE Upgrade | GP Thunder 7500k fogs | Cyba 4" carbon tips | BSW Stage 1 | APEX ARC-8 W/ Michelin PSS | Ziza LED interior | Weisslicht LED side lenses | Sprint Booster | Euro side mirrors | M-Sport semi-conversion | Coded | LOTS of carbon fiber
07-11-2014, 10:16 AM | #3 |
Rep 46
When I bought the car they came with 19". The scrapping\tire rubbing happened when I made the mistake of going up in tire size from 265 to 275. It was rubbing before but now its more pronounce. I like the aggressive look but cannot sit anyone in the back without it majorly rubbing the tires.
07-11-2014, 10:20 AM | #4 |
229
Rep 3,489
Drives: Montego Blue 335d
youll have to do the fender rolling amigo that took care of my rubbing
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
07-11-2014, 10:27 AM | #5 |
Rep 46
07-11-2014, 10:42 AM | #6 |
229
Rep 3,489
I have NON sport suspension with Koni FSDS shocks i had VMR 710 19"(never knew the offset but I bought it from a guy who had a E90 Coupr) and never rubbed I went with again with VMR 710 18" and 265 rear with the correct offset and they rubbed so i did the fender rolling at a shop and so far so good
07-11-2014, 12:11 PM | #7 | |
Rep 73
I'm currently running 19" AG m310. I wanted the VMR 710's but they were all out of stockđŸ˜* |
07-11-2014, 03:52 PM | #8 |
69
Rep 1,766
That's what happened to me when I added wheel spacers w/ Michelin PSS tires. Just need a good ol' fender rolling like Puerto Rican suggested and the problem will disappear. No need to brake open the wallet for some pricey coilovers.
07-15-2014, 04:06 PM | #10 |
Rep 46
So after talking with a mechanic I have the following options:
- Go with a smaller tire 255 instead of the 275 already on there - Replace the 19 M3 rims with a set of "regular" 19's - Or add coilovers |
07-15-2014, 04:28 PM | #11 |
BMW Advanced Diesel, 2011 BMW 335d M sport...
87
Rep 783
Im on coilovers, you will rub even more, M3 wheels are too big and 275 are too big unless you use spacers, go with a 265 rear and get non m3 wheels... I have 265-18-35 in rear, im all the way to the ground no spacers rear et rim is 45 and I do not rub and my fenders are not rolled, I bottom out everywhere but im an inch off the ground...
BMW Advanced Diesel, 2011 335d M sport...
07-15-2014, 07:09 PM | #12 |
40
Rep 322
I tried fitting M3 rims to my E90 and it was scrape city.
Getting the proper offset it key. I now have 19x9.5" in the front and 19x10" in the rear with ZERO scraping and I have sports suspension. Gotta tuck those wheels in! I have 235/35ZR-19 Michelin Pilot Super Sport XL in the front and 265/30ZR-19 Michelin Pilot Super Sport XL in the back. -Ed
2012 X5 3.5d Jet Black / Black w/ Sport Pkg - Loaded
Mods:Factory 214 Y-Spoke 20" black-chromed wheels - Gloss black grilles - LED front/rear turns & fogs - coding mods Other rides:2006 VW TDI Pkg 3 / 2008 Duramax LTZ / BMW K1300s Previous rides:2011 335d Jet Black / Black w/ Sport Pkg - Loaded |
07-16-2014, 03:33 AM | #13 | |
53
Rep 686
M3 offsets don't work on LCI E90's, period. Pre-LCI it is certainly doable with the extra 8mm on each side out back but rubbing is a definite with a 275. You'll have to stretch a tire to an unhealthy (and ugly) degree to keep the M3 ET's and avoid tire rub. Wrong wheel for the car and really just need to replace the wheels with proper non-M offsets. |
07-16-2014, 08:41 AM | #14 |
229
Rep 3,489
WHAT I decided cause of the roads down here and guess what I have damaged one rim(had to get another) already and bent other 3 aint that some crap, i have done more damage on 18'' than 19" damn it
07-17-2014, 01:51 AM | #15 | |
870
Rep 2,615
07-17-2014, 03:23 AM | #16 |
87
Rep 783
best size for a sedan 335d, front 18.85 et 35 tire 235/40/18--- rear 18.95 et 45 tire 265-35-18, I am on coilovers lowered and i do not rub no fender rolling, you can also do 225 front 255 rear tire, i just like a little more meat, don't know about 19's they are too heavy and tires get pricey at that size...just my opinion...
07-18-2014, 12:35 AM | #17 | |
53
Rep 686
Definitely no rubbing on ET45 9.5 rear! |
