07-01-2014, 06:13 PM | #1 |
European Editor
10532
Rep 22,992
secondary water-cooler for S55 inter-cooler...
I had not seen anyone post pics of the water cooler for the S55's intercooler. BMW uses a radiator up front to keep the intercooler cold. Here it is on my buddy's new M4. The cut away pics were taken in the lobby of the BMW Museum.
front radiator used to keep intercooler on top of the engine cold...
07-08-2014, 12:02 AM | #3 |
70
Rep 287
Maybe not ideal for the track, but should weigh less than a whole secondary WTA intercooler system.
http://www.iosrjournals.org/iosr-jmc...3/F0233844.pdf http://www.superchevy.com/how-to/eng...ooler-install/ Turbocharging System with Air Conditioner Assisted Intercooler In this system the air conditioning system is used to assist the turbocharging system. In summers, when the efficiency of the intercooler is low due to high ambient temperature, the air conditioning system will be used to improve its efficiency because in summers, normally the AC is always switched on while we drive and on the other hand, we don’t need this system in winters because the ambient temperature is sufficiently cool to improve the efficiency of the intercooler. So the design of the intercooler is such that it will work properly with and without the air conditioning system (i.e. in summers and winters both). Besides this it will also increase the charge density to high extent. This will increase the oxygen availability in the cylinder for combustion. Circulating refrigerant enters the compressor in the thermodynamic state known as a saturated vapor and is compressed to a higher pressure, resulting in a higher temperature as well. The hot, compressed vapor is then in the thermodynamic state known as a superheated vapor and it is at a temperature and pressure at which it can be condensed in the condenser. That hot vapor is routed through a condenser where it is cooled and condensed into a liquid by flowing through a coil or tubes of the condenser. This is where the circulating refrigerant rejects heat from the system and the rejected heat is carried away by the air. The condensed liquid refrigerant, in the thermodynamic state known as a saturated liquid, is next routed through an expansion valve where it undergoes an abrupt reduction in pressure. That pressure reduction results in the adiabatic flash evaporation of a part of the liquid refrigerant. Then this mixture of vapor and liquid refrigerant is passed through the intercooler of the turbocharger as the cold fluid where it is completely evaporated by absorbing the required latent heat. This cools the hot compressed air flowing in the tubes of intercooler coming from the turbocharger compressor. Description of Intercooler The design of intercooler is such that the air to be cooled is passed through the outer tube and the refrigerant passes through the inner tube of the two concentric tubes arrangement fitted in the arrangement of fins. This type of heat exchanger is suitable for our purpose because when the air conditioning system (AC) is running, the hot air can give its heat to both, the refrigerant and the cold air passing through the fins of the intercooler. When the AC is not running, the hot air from the turbocharger can give its heat to the cold air passing through the fins and will work as the normal intercooler. In winters, the intercooler will work as a normal intercooler and in summers, it will be assisted by the air conditioning system of the vehicle.
Drives: 2010 E70 X5M Carbonschwarz Loved and lost: 07 E92 M3 Silverstone II / 96 E36 M3 Evo Estoril Blue / 07 E84 Z4 M Coupe Interlagos Blue |
07-08-2014, 11:45 PM | #4 |
13
Rep 89
http://www.killerchiller.com
It would be pretty cool to have one of these on an M3/M4. M3 the Cobra killer/ track king. |
09-13-2016, 05:47 AM | #5 | |
21
Rep 46
Coolant
Do you know what coolant is required in this reservoir? Do you put the same coolant as engine coolant fluid when a top up is needed? Thanks... |
09-13-2016, 07:40 AM | #6 |
220
Rep 433
Great pictures, but FYI the radiator you have pictured is the engine oil cooler.
If I remember correctly the intercooler radiators are in the passenger side air dam and in front of the main radiator behind the kidney grills.
______________________________
?05 E46 M3 ZCP 6MT ?06 C55 AMG '97 911S 6MT |
