06-30-2014, 07:54 PM | #1 |
BMW, can I have some LSD please?
88
Rep 1,591
Any way to shift tranny from P to N on an AT without engine restart?
As above.
For example, if I had already parked and switched off ignition, but then decide I want to move the car a few inches forward or backward. On my previous MT it was easy as pie. Apologies if this has been addressed before.
2006 330i | TiAg | Black | Al | 6MT | Sports Package | Logic 7 retired
2008 335i | AW | Black | Al | 6MT | Sports Package | Logic 7 retired 2013 328xi | Red | Gray | Al | 8AT | Sports Line | Premium | Executive | Heat Pkg retired 2017 340i xDrive | Estoril | Black | Al | 8AT | M Package |
07-03-2014, 08:59 AM | #4 |
118
Rep 1,668
I havent tried but can you jsut turn on the ignition (foot off brake and press button) then pull the lever? I suppose it wont but just wondering if you tried that too?
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
07-03-2014, 02:29 PM | #6 |
14
Rep 86
On vehicles produced from 09/2010 or on vehicles updated with ISTA/D 2.39.0 or higher (target integration level from 10-09-500), the following procedure to electronically unlock the parking lock may be used if an engine does not start but the starter motor is still operational:
1) Turn the ignition ON (KL15). 2) Press the brake pedal and continue pressing it throughout all further steps. 3) Press the Start/Stop button (starter will engage). 4) As soon as the starter motor is engaged, press the unlock button on the left side of the GWS shifter and move the shifter forward to position N. Note: For M57Y diesel engine-equipped vehicles and during low ambient temperatures, a certain delay (up to 4 seconds) may be experienced before switching to the N position. 5) Continue pressing the GWS shifter towards the N position until the audible gong is heard and a CC message "Gearbox Malfunction. Gearbox position P may not be possible. Activate parking brake while vehicle is standing" is displayed. 6) Then release the gearshift and reselect the N position within the next 6 seconds. Gear position N is then displayed in the instrument cluster. 7) Continue depressing the brake pedal until the starter motor stops cranking. Then the brake pedal can be released and the vehicle can be moved/pushed into a desired place. Important: After applying the procedure described above, the vehicle can only be moved manually. Towing is prohibited since the parking lock may engage, causing severe transmission damage. 8) The ignition has to be ON (KL15) at all the times during this process. If turned OFF, the Park gear position is going to be engaged automatically. NOTE: If neutral position N cannot be achieved, cycle the ignition ON/OFF several times (press the Start/Stop button without depressing the brake pedal). Then try steps 1 to 7 again. After 3 unsuccessful attempts, a minimum 10-minute starter "cool-down" period is required before another try. Secondly, this is for an E90 but might be the same: Last edited by Caught Looking; 07-03-2014 at 02:43 PM.. |
