2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Need help cf lip kit
      06-30-2014, 06:36 PM   #1
Kevindamoe
23
Drives: 2011 BMW 535I
Alright...so I put on a cf front lip recently and I used 3M tape on the top inside and screwed it down from the bottom up....it's not falling of it's just not as flushed because the tape isn't strong enough any suggesting on something that will stick? Pleas let me know
      06-30-2014, 08:17 PM   #2
jdmfrogg
27
Drives: 2011 535
It could be the tape is failing or it might also be the lip is not 100% form fitting (rep, or mold is getting old) if the over the counter 3m moulding tape isn't strong enough by itself...
option 1: 3m adhesion promoter http://www.oreillyauto.com/site/c/de...6.oap?pt=N0400, and then try the 3m moulding tape again http://www.autozone.com/autozone/acc...-Tape/_/N-25ej
option 2: get some 3m VHB... but you have to find the right match... go here - http://multimedia.3m.com/mws/media/6...nical-data.pdf and read page 1 & 2. the multi purpose or general is prob the safest bet. Once you find the model#, you'll have to find it on Ebay since they only sell it in bulk. Note - use it sparingly since it is very strong, when time to remove, you'll need to use fishing line to cut through the middle of the tape then something like goo gone to soak and remove the remnants.
g luck
5post
