06-29-2014, 01:19 AM | #1 |
138
Rep 740
435 engine overhested/smoke under hood
guys,
Today i got an engine overheated notification from my 435. I turned car off for hour, as i was having dinner in restaurant. On way home, no engine issues. As i parked in my garage, the engine overheated msg came on again, and smoke started to come out insanely from under the hood. I opened it to give it air, and the coolant just completely leaked out. Took about an hour for engine and collant box to stop making weird noises. Since it is night, i locked the car and hood and went home. What the deuce????!!!?!?!! branc new car...1600 miles on it. And also to mention it was in limp mode as i parked, gave it gas and didnt move above 1200 rpm. Did anyone else have this? Any advice or recommendations guys? Can it catch fire or anything else while its off, parked, and in garage? Really would hate to have it towed to dealer. Hopefully i wont pay anything for repairs. And now, even if they fix it, ill be too cautious and nervous to drive it, and maybe with some spirit. Not reliable. I know that is not why we buy or lease bmws, but still, makes you think twice now and be more aware. I wont be able to gun it sometimes after this, ill be thinking all the time, will the car go into overheating or smoke or catch fire? Please help with advice guys. Thank you!!! |
06-29-2014, 01:21 AM | #2 |
2024 M440i GC (G26)
278
Rep 511
I wouldn't mess around with this. Car overheated. Could be any of a half dozen reasons for this (such as a stuck thermostat control valve). Call BMW Assist, and they'll arrange a tow of the car to your dealer, who will then provide a loaner while they diagnose and fix the problem. All under warranty.
06-29-2014, 05:51 AM | #3 |
240
Rep 1,756
Was it steam or smoke? What was the oil temp? It's a pity it doesn't have a water temp gauge so you can keep an eye on it, as mentioned above hopefully it's just a stuck thermostat, but if they get too hot the head can warp and need replacing
06-29-2014, 06:05 AM | #4 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Have BMW pick it up. Alloy engines do not do well in an overheat situation especially when you have driven them after the fact without solving the problem first.
You have two back to back overheat cycles on it & you need to decide if you really want to share that info with BMW.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
06-29-2014, 07:37 AM | #5 |
10
Rep 131
Yes the worst thing you could have done was drive it. Overheating typically is caused buy a bad temp valve which is a simple fix or a bad pump... Now you driven it everything from head gasket, crank bearings, piston seals, turbo bearings, etc could have sustained damage, not limited to engine block (aluminum). Oil losses it's protection properties over a certain temp.. The good thing is that BMW uses synthetic which has a much higher temp before break down. Unfortunately you went past the point and got the temp high enough for the radiator valve to open..coolant is highly corrosive and now that causes another mess to deal with.
For sure the moment you said you drove it in this condition it will pose an issue... Don't tell them. Lesson learned to anyone..the moment you see over heating stop the car and turn off the motor open the hood... Don't spray water on it...it could cause other damage due to rapid cooling. |
06-29-2014, 08:18 AM | #7 |
189
Rep 609
Problems are what kept me away from the N55. Loving my N20
2019 Z4 sDrive 30i Msport,
Previously owned BMWs, 2014 428i Msport, 2008 335i Coupe, 2007 328xi sedan, 2002 325i sedan 1996 318ti (loved this little car) |
06-29-2014, 08:48 AM | #9 |
38
Rep 596
On most every forum, you tend to hear the problems over the people who have no problems. The engine for me has been solid for the 14 months I've had the car
2013 BMW 335i xDrive Sport Line
06-29-2014, 08:50 AM | #10 |
189
Rep 609
Yes it is a great engine, i have personal bad history with it, that's all
06-29-2014, 08:52 AM | #11 | |
651
Rep 5,803
F30 330i Alpine white/Coral red Msport 6MT
06-29-2014, 09:58 AM | #13 |
Rep 35
Drives: 2014 320i 6MT M sport
Agreed-the history of events will be retrieved by thr dealer from the ecu. My brother who is a car tool dealer, and visirs the nechanics in the shops, has told me about expensive engine jobs on the bmw 6 cylinder when they over heat due to coolant pump failures.
06-29-2014, 10:18 AM | #14 | |
772
Rep 1,502
In any case, presumably now it's with the dealer and they should take care of it. The only advice you need at this point is to not ignore serious warnings from the car in the future. Last edited by chiefneil; 06-29-2014 at 10:28 AM.. |
06-29-2014, 10:19 AM | #15 | |
16
Rep 337
2014 M Sport
//OEM+// |
06-29-2014, 10:33 AM | #16 |
772
Rep 1,502
Maybe you're not aware of how new car warranties work? While your car is under warranty you get repairs for free at any dealer. The tow is also free. Call BMW Assist or push the SOS button in the car and have it towed.
06-29-2014, 10:43 AM | #17 |
16
Rep 247
Bdwonder, if you're not a total travelbro, you should just heed the advice of the idrive screen when such malfunctions occur. It should tell you whether to stop driving, drive cautiously, etc.
good luck with the repairs and keep us posted on the issue/resolution. |
06-29-2014, 10:46 AM | #18 |
51
Rep 1,831
Drives: 335i MSport + MPS/MPPK
I am still amazed that people believe new items cannot have issues (whether it is a car, tv, appliance, phone, etc).
For the love of everything, take it to the dealer ASAP. |
06-29-2014, 10:56 AM | #19 |
2024 M440i GC (G26)
278
Rep 511
Well, if the OP (*cough* travelbro *cough*) doesn't know the difference between "smoke" and steam, it shouldn't surprise anyone that he also wouldn't know enough to shut down the car on an overheat warning and get a tow.
Call me skeptic, but when stuff this dumb gets posted, I always ask, what's the rest of the story? There's nearly always something that's been hidden or gone unstated.* Who knows what uninformed folks do to complex pieces of tech like the F30. As someone wise once said, you can't fix st.......... *Or in about a third of these cases, it's just trolls posting inflammatory crap they make up; e.g. guy that claims to own 2 M5s, and M6, a couple of F32s, and an X5 and constantly posts "problems" that come up with these cars. We outted him as a total troll just recently... Last edited by diablo2112; 06-29-2014 at 11:19 AM.. |
06-29-2014, 11:12 AM | #20 |
3129
Rep 5,264
If it overheated as he got to the restaurant he may not have noticed it until heat soak cooked it off.
That is different than saying yeah it was overheating on my way to the restaurant so I kept going to let it cool off over dinner, did nothing to check the problem, then drove it home & it overheated again. In the second case they should symbolically rip up his warranty.
Kevin
06-29-2014, 12:14 PM | #21 |
138
Rep 740
Hey, looked like steam. Oil temp was smack in middle at 250, or whatever the middle number is. Its weird, not a wrong code, bc all the coolant just leaked out from under car, bone dry.
06-29-2014, 12:19 PM | #22 | |
138
Rep 740
