Smoke Detectors
12-08-2007, 04:04 PM | #1 |
40
Rep 1,167
Drives: Audi RS5 Sportback Carbon Blac
Smoke Detectors
Very OT but one of our smoke detectors has started beeping constantly today to 'tell' us that the back-up battery is low/dead. Driving us nuts but we cannot get the battery drawer out to replace it - there is a Key Slot above the battery drawer but we never got a key (we have had the house from new). I have tried screwdrivers etc and there is no manufacturer's details on the detector to try and get a key
Anyone else got detectors needing a 'key' to unlock the battery drawer? If so what do they look like etc Next step is sledgehammer to knock it off the ceiling as the beeping isdoing my nut!!! |
12-08-2007, 04:50 PM | #3 |
83
Rep 2,353
Drives: 2009 Z4 sDrive 23i
Is the key not located on the inside of the detector (the cover bit perhaps)?
E89 Z4 sDrive 23i... for the more discerning driver
12-08-2007, 08:35 PM | #4 |
128
Rep 2,426
Drives: E93 335i M-sport
yeh I'd be tempted to simply break in or smash it they only cost like a 5er or something for a new one...
12-09-2007, 03:09 AM | #5 | |
164
Rep 4,190
Drives: F30 335d M Sport, F15 X5 40d
Does the cover unscrew from the body ? |
12-09-2007, 03:39 AM | #6 |
40
Rep 1,167
Thanks all - it is a mains powered unit and you cannot dismantle the unit without taking the battery drawer out first (serious design fault in my opinion). I am nervous about just breaking it off the ceiling as it is wired in.
Thanks for the help - I will continue to try the elbow grease route!! |
12-09-2007, 05:15 AM | #7 |
571
Rep 7,519
Drives: 2009 E90 335i MT
Call the fire brigade (non-emergency number) and ask them to come take a look. I know they fit smoke detectors for a small fee. Once you get it resolved, replace the unit with one that doesn't require a key (what a screwed up design).
In the meantime, what does the keyhole look like? Maybe if we knew that we could brainstorm some solution to get your sanity back. Is the unit mounted on a wall or ceiling with a baseplate? Most smoke detectors do and you normally insert it into the plate and twist. There will be a latch to keep it from easily being removed. The mains connection will normally be a socket (female) so that the unit can be removed and the electric remain safe. Some are designed where you have to remove the mains connection before you can gain access to the battery compartment.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
12-09-2007, 09:20 AM | #8 | |
273
Rep 9,218
Does this help: http://www.diconsafety.co.uk/downloads/2502_A0033.pdf |
12-09-2007, 09:38 AM | #9 |
Campervan man
94
Rep 2,667
Try using a lump hammer!
12-09-2007, 09:46 AM | #10 |
83
Rep 2,353
Do these mains powered smoke devices have 240volts going to them, or is it some sort of low voltage 12v setup?
12-09-2007, 09:52 AM | #11 |
171
Rep 7,953
Drives: Merc diesel
Garage List 2010 TTRS [9.00]
2007 Audi S5 [0.00] May 2007 Porsche 99 ... [0.00] March 2007 Porsche ... [0.00] Sep. 2007 E92 335d SE [0.00] July 2006 E90 330i ... [0.00] |
Good test would be, lick your fingers and touch the wires. The difference between 240 & 12 V must be about 6'......ie. where you end up on the floor
Seriously, if you can't isolate it off the ring main, then attack the bugger & make sure you've got a pair of rubber gloves on (marigolds should do it). That bleeping noise would drive me insane. Hope you haven't got a dog or cat as well. |
12-09-2007, 09:59 AM | #12 |
17
Rep 468
I had exactly the same problem, drove me nuts and was mains powered. In the end I cut the power to the house and took a screwdriver and hammer to it in order to get it off the mounting plate. The silence afterwards was wonderful!
12-09-2007, 10:09 AM | #13 | |
83
Rep 2,353
12-09-2007, 10:46 AM | #14 | |||
40
Rep 1,167
Seriously considered it Oli Quote:
Well (cue drum-roll) I finally got the b*gger out!!! One broken knife and forced lock later the little battery drawer relented. Popped new super duper (extra long life) Duracell in and waited... me on the step ladder, miswah and sprogwah standing just below waiting..... and silence, GLORIOUS SILENCE (so good I feel the need to shout!!!) Thanks to all the support/advice and attempted murder (you know who you are....*cough* BeemerBird *cough*) |
12-09-2007, 11:04 AM | #15 | |
273
Rep 9,218
There is usually a locking pin, which prevents idle hands opening the battery drawer and filching the battery. The pin (or key) would have to be removed before the drawer could be opened. Or alternatively you could try a knife. |
12-09-2007, 11:36 AM | #16 |
The Tarmac Terrorist
944
Rep 29,345
Drives: 997.2 GT3
i would not spend 5 quid on a safety device.
Thats like buying a 70 pound crash helmet, sod that.. My Arai GP3k was 400 squid in 2000. Proper helmet!!! Some are far more expensive tho. Mine is safe enough to use in f1
997.2 GT3
12-09-2007, 11:41 AM | #17 | |
103
Rep 2,292
Alonso is replaced by 'Fandango' BMW 3 Series Diesel Test Pilot.
Golf Ed35 Black with - Black Leather
12-09-2007, 11:48 AM | #18 |
83
Rep 2,353
Absolutely Carlos - smoke detectors are a waste of money and will not save your life. I have one of these expensive devices parked on my driveway to deal with any fires in my home.
12-09-2007, 11:54 AM | #19 | |
944
Rep 29,345
Drives: 997.2 GT3
997.2 GT3
12-09-2007, 11:55 AM | #20 | |
171
Rep 7,953
Drives: Merc diesel
Silence is golden though eh. Glad you're sorted. |
12-09-2007, 12:19 PM | #21 | |
191
Rep 6,110
Drives: Don't know yet!
You need to light a bonfire underneath the detector to check it out,dining room table and chairs is a good test. Make sure the lacquer is not toxic as the fumes might kill you,Helen has already failed! |
12-09-2007, 12:29 PM | #22 | |
571
Rep 7,519
BTW, that big red and yellow machine wouldn't fit in my driveway. Heaven help me if I needed them to pay a visit. Love the wheels on it though.
