06-23-2014, 10:05 AM | #1 |
73
Rep 549
Wider tires.
Hi, I'm looking for a wider tires like ad08r or cup2.
So if the stock ones are 255/35 and 275/35, my wheels will be 9.5 and 10.5, what tires do I need to use? I think that is possible to install the 275/30 and 295/30 tires, but the wheel size will be 14mm smaller for the front and 16mm smaller to the rear. The 265/35 and 285/35 will be 7mm bigger. The other choice is to use the set of e92m3 of my friend 265/35 and 295/30, but front wheel will be bigger and the rear will be smaller. So whitch way do I need to go? Tnx.
F80 M3 SO/SO |BM3 St.1 91 oct.|Cattless DPs|Tractive P'n'P|Brembo 6pot|Rays G25 with CUP2 tires|GTS coding|
1M VO FBO (KW DDC) PTF st.2+ sold e90 335i FBO jb4 sold |
06-25-2014, 11:17 AM | #2 |
Moderator
617
Rep 10,855
Honestly I think you are much better off staying with the stock PSS that are designed specifically for this car. Unless your streets are much better than the ones I drive on, 30 series tires are going to be trouble.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
06-26-2014, 06:31 AM | #4 | ||
73
Rep 549
It is like to use rs2 on 1m) I switched to the ad08 and rs-3 and was happy. The open question is - what size? I can go: 255/35 275/35 like stock 265/35 295/30 like e92m3 people go 265/35 285/35 just 1 size bigger (7mm) 265/35 305/30 like one of the guys in Sochi will go Quote:
Just I need to get the Michelin Pilot Alpin 4 and everythink will be okay - I like this tire!
06-26-2014, 09:29 AM | #5 |
BimmerPost Supporting Vendor
9574
Rep 10,869
275/30/19 and 295/30/19 are a very acceptable 2% reduction in tire size from the original 255/35/19 and 275/35/19 tires.
A 2% reduction in outer diameter is about the most I'd accept, but is well within reason for performance setups. I would not install tires on a client's car that were 3% smaller than the OE diameter, but we have gone 2% shorter for many years with no issues. One other item to consider- the sidewall profile number in a tire size is a % of the width, not an equal indicator of sidewall height. This means that going from a 255/35 to a 255/30 tire would give you a dramatically shorter side wall, but going from a 255/35 to a 275/30 only gives you a very slightly shorter sidewall- not short enough to make an impact in relation to ride comfort or potholes. The next step is determining wheel offsets that will work well with the 275/295 tire combination!
06-26-2014, 09:35 AM | #6 |
Dinosaur supervisor
3030
Rep 4,214
A 295/30 is almost identical in sidewall height to the front 255/35 so why would it be trouble?
06-26-2014, 10:03 AM | #7 | |
73
Rep 549
Unfortunatly the Michelin Pilor Sport CUP 2 doesn't exist in 275/30 size and I'm stuck in going stovck size 255/35 and 275/35 or to go 265/35 front with lower rear. If we will go back to e92 m3 it had 245/35 and 265/35, but the m3 gts had 255/35 front and 285/30 rear. May the way to is 265/35 and 295/30? Now I'm thinking on going with the stock sizes - it def. be okay)
06-26-2014, 10:43 AM | #8 | |
9574
Rep 10,869
I would not suggest using a 265/35 front, it's likely that the tire will be too tall and could rub. Are you considering anything along the lines of Advan AD08?
06-27-2014, 02:39 AM | #9 |
73
Rep 549
I was thinking in getting ad08r, but I've got the ad08 on my 1m and I can say it is almost identically to the rs-3 which costs 1.5 times less. So for this price I want to try the new tire - cup2 and I thing I will try firstly the stock size 255/35 and 275/35.
06-30-2014, 10:21 AM | #10 |
9574
Rep 10,869
Sounds good! I'm looking forward to seeing the results!
