335d Carbon Cleaning DIY or write up?
06-20-2014, 08:40 AM | #1 |
Rep 54
Is there anything that outlines best way to do this? Looking to do DPF delete, EGR block off/by pass and software update. Not sure if the catch can will be needed at that point. Figured better get carbon cleaned with changes to other items all at the same time. Thank you!
06-20-2014, 08:52 AM | #2 |
229
Rep 3,489
Drives: Montego Blue 335d
Meth it Brice Hooper did the meth thing and his car is running great, dpf is a pain in the ass to remove but 2deerwhistlers can help you on this. Iaknown has the EGR plugs. I believe with the above actions a catch can would be overkilll
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
06-20-2014, 09:02 AM | #3 | |
Curmudgeon and Pedant
690
Rep 3,489
06-29-2014, 07:46 PM | #6 | |
69
Rep 1,766
If it wasn't for the ridiculous costs of the CBU cleaning (looks like an extended warranty doesn't help), somewhat lazy transmission (8-speed ZF would of helped) and inability to delete EGR/DEF (due to my state's emissions law), this car would of definitely been a keeper. Sorry to be a downer all the time gents but I see no clear solution other than opening that wallet and feeding the hungry hungry BMW hippo.
JBD @ 100% | KW ST Coilovers | M3 rep. front bumper | 888Concepts AE Upgrade | GP Thunder 7500k fogs | Cyba 4" carbon tips | BSW Stage 1 | APEX ARC-8 W/ Michelin PSS | Ziza LED interior | Weisslicht LED side lenses | Sprint Booster | Euro side mirrors | M-Sport semi-conversion | Coded | LOTS of carbon fiber
06-29-2014, 10:28 PM | #7 | |
BMW Advanced Diesel, 2011 BMW 335d M sport...
87
Rep 783
BMW Advanced Diesel, 2011 335d M sport...
06-30-2014, 12:52 PM | #8 | |
69
Rep 1,766
Resetting helps a bit but after it adjusts, D is still unusable, DS has a slight response lag when you want to gun it and manual shifting is the way to go but you suffer a bit with MPG. If anyone needs an Alpina flash, it's clearly us 335d owners. Alas, I don't expect to ever see one.
06-30-2014, 01:14 PM | #9 | |
87
Rep 783
06-30-2014, 02:34 PM | #10 |
213
Rep 2,210
Are you guys running tunes or JBD? I noticed a huge difference in the way the tranny operates between no JBD and 100% JBD. I attribute it to the JBD fiddling with the system as it goes back to shifting fine if I remove the JBD.
06-30-2014, 03:55 PM | #11 |
870
Rep 2,615
Strangely, I do not have a problem with this transmission. Drives fine, shifts fine and no lag. If I need a quick start or a burst, I flip into DS. Did the manual reset and it is better than it was though. No JBD here.
06-30-2014, 04:17 PM | #13 |
87
Rep 783
Mine has always shifted fine, I just feels so lazy with the throttle, it always revert back to that setting, lazy, when I reset it has a more direct quicker feel, more like DS, but then back to blaah...
07-01-2014, 09:19 AM | #14 | |
3575
Rep 10,355
Some did mention the awkward city performance. |
07-01-2014, 02:44 PM | #15 |
69
Rep 1,766
Doing that gives you a jolt that you can't avoid, unless you have some kind of special throttle technique, because it starts in 1st gear and quickly wants to jump to 2nd. Doubt you start off to a smooth run unlike in manual shift mode.
07-01-2014, 02:46 PM | #16 |
69
Rep 1,766
I've never tried the OBD method and I have no clue how long it takes for the adapted settings to permanently set.
07-01-2014, 04:17 PM | #17 |
87
Rep 783
Im going to bmw Monday for this and my ac belt and my taillight to see what they say, SA also to me he has has 3 335d in for CBU cleaning, they are sending out the intake and walnut blasting in house with new DIESEL WAND, lol
07-01-2014, 04:59 PM | #18 | |
69
Rep 1,766
I just hope my CBU triggers soon then maybe, just maybe, I'll think about keeping it till 100k. Other than its terrible flaws, I still love all that stomach-churning torque!
07-01-2014, 05:50 PM | #19 |
87
Rep 783
I'm at 52k with a extended warranty, when he said their new DIESEL WAND, yes he did say that, I thought OMG these guys are in for a treat...
07-01-2014, 06:14 PM | #20 | |
72
Rep 697
All the nice new cars are direct injection. |
07-01-2014, 06:21 PM | #21 |
87
Rep 783
I said it a million times, I'm not opposed to CBU in a DI car , I hate all the damage It does to everything else, that is what I want BMW to take care in every CBU case...the stuff it messes up...
07-01-2014, 09:38 PM | #22 |
213
Rep 2,210
Yeah, general direct injection CBU and our CBU are leagues apart. Walnut blast the intake valves vs blast the valves, head, ultrasonic wash the intake, blast egr valve, replace various sensors and injectors as required. Two issues with similar names and some similar symptoms but vastly different typical repair scopes. Now that its much more well documented and recognized though it should get a little less difficult to deal with. Should being the keyword
