BMW 3-Series (E90 E92) Forum
Headlight shake?
06-06-2010, 02:54 PM | #1 |
Rep 53
Headlight shake?
I have 2010 e90 335i and the xenon headlights shake whenever I hit any kind of small bump in the road ( take note I live in NY and therfore a bump is hit every second). The beam of light shakes up and down which I have never had happen on any previous cars.
It seems as if the light bulb housing is loose. Is this common? Am I just acting crazy? |
06-06-2010, 02:58 PM | #3 |
ahat
1040
Rep 2,592
There is an extra support that BMW included in a tsb update for e92. But I don't think the lights on the e90 have the same support. I would just give it the visual once over - I found screws loose on mine even AFTER the dealership installed the support
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
06-06-2010, 02:59 PM | #4 | |
208
Rep 9,339
06-06-2010, 03:05 PM | #5 | |
Rep 53
I do have adaptive healights . Is that the cause? I mean this is more of a rattle shake up and down not a smooth movement. |
06-06-2010, 03:09 PM | #6 |
Rep 53
06-06-2010, 03:18 PM | #8 |
126
Rep 1,546
i had the same problem with my e90 lci 335i.... my e92 335i had the same problem i told bmw about it when i went into service they installed the extra bracket but it still did it a little.
06-06-2010, 03:20 PM | #9 |
15
Rep 603
I had a similar problem and took it to the dealer and I was told the automatic adjust mechanism was busted. They replaced the whole light. I lived with it for a few months b/c I figure it was just the Xenon which I hadn't had before. I actually figured out that it wasn't normal after having two loaners w/o the problem. Funny b/c the also left the support off when the installed the new light assembly and I had to take it back. Took me 3 trips to the dealer for them to get it right.
If they can't figure it out make them replace the whole assembly, it's really unacceptable. |
06-06-2010, 03:28 PM | #11 |
77
Rep 940
I have this same issue. I thought it was normal because I've never had Xenons before and I figured the cutoff line was just super sensitive to vibration. Driving on bumpy roads, the headlights vibrate and bounce up and down quite a bit. Also, they were aimed very low when I first bought the car a month back, and I had to raise both of them up. I have adaptive xenons, could the adjusters be broken or messed up?
My mom has the same car pretty much and I don't remember her headlights being like that. |
06-06-2010, 07:45 PM | #12 |
Dismembered Member
3613
Rep 9,213
Just try tightening the screws in your housing, adaptive headlights should not be cause of them rattling as they work in conjunction with steering ratio; you mentioned they jiggle going over bumps and stuff. It should work! If not, there's always the dealership
My delivery experience and beach photoshoot here. |
06-06-2010, 09:14 PM | #14 |
73
Rep 1,375
it shacks because u hit a hole think man!!!
Current 2008 M6 e63 v10 6mt Current 2012 e70 x5 35i -jb4 2008 335xi e92- Sold 2007 335i e90 - Sold 2002 Taig / Red / / / M3 - SOLD |
06-06-2010, 09:34 PM | #15 |
Rep 53
Excellent advice you should also follow it...
Think man!!! Did you mean to say shakes not shacks? If it only happen when I hit a hole I wouldn't have posted about the problem. The headlight shakes on any kind of minor change in the road. I do realize if I hit a hole it would move. |
06-06-2010, 09:43 PM | #16 | |
Dismembered Member
3613
Rep 9,213
06-07-2010, 06:33 AM | #17 | |
77
Rep 940
Where exactly are these screws that I should tighten? Back of the housing? Behind the bumper? |
06-07-2010, 12:25 PM | #18 |
Rep 66
My 2007 does it too. I see it if I make a not-so-smooth shift, or hit a bump in the road. Its my first car with Xenons, and I just figured it was normal. Now I wish I would have said something while the warranty was intact.
Oh well. I'll just pretend I didn't see this thread, and continue thinking its normal. |
06-07-2010, 01:06 PM | #21 |
Rep 902
take the bulbs out if you bringing it to dealer unless you have a good relationship with them....
91 MR2Turbo....07 335i....
06-07-2010, 01:11 PM | #22 |
Max Powers
29
Rep 271
there's a TSB out there for this problem. Had support brackets installed at dealer. Still shaking. Got all new headlights installed. Much better - still a little shaking though.
