BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Low Lighthouse and Angel Eye in 100% brightness
      05-30-2020, 11:34 AM   #1
samuelbpereira
Brazil
Drives: BMW X1 25i 2019 F48
Hello, does anyone know how to make the bimmercode with the angel eye stay with the maximum power when turning on the beacon? When I turn on the angel eye it gets weaker, I would like to keep it at 100% brightness. Thank you
      05-30-2020, 12:24 PM   #2
ejw2011
ejw2011's Avatar
94
Drives: x3 F25 35i, x1 F48 28i
Look at the Front Electronic Module (FEM) and set angel eyes to 100%
      05-30-2020, 03:19 PM   #3
samuelbpereira
Brazil
Hello ejw2011, I think it must be somewhere in the expert mode to keep the angel eyes at 100% with the low beam, because in the nomal mode in the program this Angel eyes brightness low beam is 100%, but when I turn on the low beam the angel eyes reduces the brightness to about 50%.
      05-30-2020, 04:56 PM   #4
ventjock
65
Drives: 2020 M340i
Following
      05-30-2020, 05:39 PM   #5
ejw2011
ejw2011's Avatar
94
There are two code settings for angel eyes I used and have no problems. But then again I have angel eyes to dim 80% when turn signals invoked. There is also daytime light intensity setting. Try but I don't remember I needed to set.
      05-31-2020, 11:46 AM   #6
samuelbpereira
Brazil
I've tried everything, but even so when I put the low beam on, the angel eyes reduces the light even though everything is 100%. Another thing that I was unable to do at all and wanted very much, is to make the fog light turn on with the headlight control being at 0, in the position where the red arrow is. My BMW is the X1 F48 25i 2019.
      05-31-2020, 06:41 PM   #7
ejw2011
ejw2011's Avatar
94
Did you try coding the daytime running lights to 100%?
As far as the front fog lights to be on at position 0, you can't code
afaik. You probably need to rewire.
      05-31-2020, 08:06 PM   #8
samuelbpereira
Brazil
It is a pity that there is no way to turn on the fog light in position 0. Yes, I put everything at 100%, but when I put it in the low light position that is shown in the image, the angel eyes halves the luminosity. Something is crashing and not letting it stay at 100% even though the Bimmercode informs that they are 100%.
