BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) How many psi do you have on your tires?
      12-29-2019, 01:04 PM   #1
X1604M
X1604M's Avatar
56
Drives: 2018, F48 28i
2018 BMW X1 F48  [0.00]
I have my 2018 f48 28i for abt a year now. I have 32 psi on all tires. Most of the time my front right side tires was hitting hard when ever I drive over a small or big port hole even at a slow speed. It's very annoying to feel that. The impact was very hard follow by the banging sound. I always check my tire pressure. I have stock Goodyear eagle sport RFT tires. Last week I make all tires to 34psi and the ride quality is improved and the bang is not that hard now. I want to know if it's only me or any of you experience similar effect.
      12-29-2019, 03:38 PM   #2
Skyline2.0
137
Drives: 2018 BMW X1 xDrive
32 psi all 4 corners. I stay within 32 to 33 psi all year around as I personally dont see a reason to go beyond the factory recommended level.
I also hear/feel a loud thunk when going over speed bumps even slightly faster than I probably should.
I've read in other threads that some owners of our generation have had lower wishbone arm/bushings go bad, causing a similar noise while taking speed bumps at a somewhat fast speed.
X1604M55.50
      12-29-2019, 04:03 PM   #3
kavatski
147
Drives: 2023 X3 30iX
I started at 32 all around but wasn't happy with the way it felt a bit soft when cornering. Bumping it up to 36/32 F/R (similar to what's recommended for the X1 in overseas markets) brought a noticeable improvement. No sign yet (6200 km) of any unusual noise when going over bumps, though.
X1604M55.50
      12-29-2019, 08:35 PM   #4
wcs2229
wcs2229's Avatar
171
Drives: 2018 BMW X1 F48 xDrive28i
I go with 33 all around in Summer and 34 all around in Winter, so as to average out lower when tires gradually lose air over time. Winter starts higher because pressure can drop with temperature fluctations due to cold snaps in my area.
X1604M55.50
      12-30-2019, 10:13 AM   #5
MattBrandCars
32
Drives: X1
33!
X1604M55.50
      12-30-2019, 03:17 PM   #6
rice_rocket88
No_Country
298
Drives: E60 F48 F39
36 on all my cars.. and yes it seems to run a lot nicer. I have a lot of potholes down my street.
X1604M55.50
      12-31-2019, 12:52 AM   #7
X1604M
X1604M's Avatar
56
I don't know abt the recommended psi for overseas market. A month ago I brought the car to dealership to replace the water leaked pax side headlight. When I got the car abck I found all tires are at 36 psi. I was surprised and reduced to 32psi. Thanks all for your feedback.
      12-31-2019, 09:02 PM   #8
wcs2229
wcs2229's Avatar
171
Originally Posted by Oktober man View Post
I don't know abt the recommended psi for overseas market. A month ago I brought the car to dealership to replace the water leaked pax side headlight. When I got the car abck I found all tires are at 36 psi. I was surprised and redused to 32psi. Thanks all for your feedback.
Same thing happened to me at dealership for oil change. I reduced also at home.
X1604M55.50
      01-01-2020, 08:39 PM   #9
Kansai12
Drives: 2016 X1 xDrive 25d M Sport
Over here in the UK, I have mines on 35 psi in the front, and 32 psi in the rear on the stock 18" wheels for the 25d
      01-02-2020, 02:45 PM   #10
BMWZ4
BMWZ4's Avatar
1908
Drives: '23 X1/'23 Allroad Progressiv
Whatever the values are in the door jamb. Those Goodyear RFT's is where the harshness is coming from, IMO
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
      01-03-2020, 12:37 AM   #11
X1604M
X1604M's Avatar
56
I agree with you 100 %. To me those are the worst tire I ever have. When I see any uneven surface on the road I kind of expecting and ready for the jerk or hard bounce off feeling.
BMWZ41908.00
      01-06-2020, 04:10 AM   #12
Jorix
73
Drives: BMW 120d, BMW X1 xDrive20d
Any1 else having issues with their tires depressurizing quite quickly? I feel like mine drop about 0.5 bar per month (7 psi).
      01-06-2020, 08:30 AM   #13
Skyline2.0
137
7 psi per month is a lot from my experience. I lose about 0.5 to 1.5 psi, at most, per month throughout the year. You may have a possible slight bent rim or small puncture - both problems I've had in the past that resulted in the tire pressure loss that you're seeing.
Another possibility is a leaky Schrader valve. To rule this out, spray some soapy water on the valve stem after removing the valve cap. If you see any bubbles form at all, you have a leaky valve.
However, a quick change in temperature (on average, you'll lose 1 psi per 10° Fahrenheit drop) + not airing up your tires for even a month or two could result in what looks like drastic tire pressure loss.
You should closely inspect the problematic wheel and tire for any obvious punctures. The bent rim issues I've had is usually on the inner side, so you should look closely on the inner side.
      01-06-2020, 08:31 AM   #14
X1604M
X1604M's Avatar
56
It doesn't happen to me. Like that. That's a lot. Is it happening to all 4 tires or just one or two. How abt the weather of the area u live in.
      01-06-2020, 11:19 AM   #15
oakey46
159
Drives: BMW 2 A/T 220i Lux Auto 1.5
That seems very unusual. Are you sure you aren't losing a lot of air when you unscrew the inflator connector, if you do put air into the tyres (UK spelling!) yourself. And, presumably, a drop of that magnitude will show a warning from your TPMS.
I find that using my foot pump (or a rechargeable electronic inflator I carry in the car for emergencies), it's too easy to release air when unscrewing from the tyre valve and the pressure drops quite a lot. Otherwise the only time I notice any real difference, and only by 1 or 2 psi, is when there are outside temperature variations.
Otherwise I keep mine to the pressures on the door jam label.
      01-06-2020, 01:21 PM   #16
Beagler
75
Drives: Sept 2019 Facelift X1 MSPORT
If the tyre is checked after inflation with a good accurate tyre pressure gauge it would eliminate air pressure drop after disconnecting airline.
Everthing goes to Entropy in this Age.
      01-07-2020, 02:05 AM   #17
Jorix
73
Well, the funny thing is that all the tires are loosing pressure equally . To be honest, it did become a lot colder in my country last month, so it might be the weather. I'll observe them this month as well, and if they drop again I'll take the car for inspection.
      01-07-2020, 04:42 PM   #18
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
Temperature is the culprit
A temperature drop of 10°F will reduce tyre pressure by about 1psi
(Sorry — I started to do the °C : Bar conversion, but it did my head in!)
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
Jorix72.50
      01-08-2020, 05:52 AM   #19
Beagler
75
One reason you don't do tyre pressures on a sunny day with one side of car in bright sunshine and the other in the shade. There can be a few psi difference.
      01-09-2020, 03:34 PM   #20
CajunBMW
CajunBMW's Avatar
1289
Drives: BMW 340i and X1, Chrysler Van
For my X1 I follow the door suggestions for the installed run flats. I also have a 340 and I do a 36 lb square, which for the front adds 4 extra pounds. This was suggested by BMW to avoid the excessive wear that occurred on the first set of tires. Set 2 looks to have almost double the life span.
X1604M55.50
      01-09-2020, 03:35 PM   #21
CajunBMW
CajunBMW's Avatar
1289
Agreed. Can make a huge difference.
Beagler74.50
      01-10-2020, 09:06 AM   #22
kavatski
147
I’ve been happy running 4 extra psi in the front on our X1, but I’ll be even happier if it also extends the lifespan of the tires given the FWD bias and weight distribution. I’ll be rotating the tires regularly and keeping track of tread depth.
X1604M55.50
