BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Remove phone
      07-20-2019, 06:59 AM   #1
ramonE90-NL
Netherlands
35
Drives: bmw F30 320iA
Remove phone
How can i remove the phone from the idrive when everything is grayed out?
I cant do anything with phone settings.
      07-21-2019, 04:58 PM   #2
ramonE90-NL
Netherlands
35
I ended up with deleting all personal data from the idrive. Just like a reset.
My problem was that apps are not always showing and if they do they dont always work. Not even when i try to bluetooth stream media and not using the spotify app in the car.
But after this reset it is still not working, now i cant even check app's in the phone menu.
      07-21-2019, 05:44 PM   #3
oakey46
158
Have you tried deleting your phone from the car Bluetooth settings and re-installing it. I have used iPhone 7 and a new XR in mine without issue and Spotify works via spoken command. I can also send destinations remotely from the iPhone BMW Connected+ app to the car, although that facility expires next month and BMW want £25 to extend for 12 months.
      07-21-2019, 07:36 PM   #4
ramonE90-NL
Netherlands
35
Yes, with the idrive reset everyting was deleted. So i had to pair my iphone7 again.
I also have the bmw connected drive payed Subscriptions.
      11-08-2019, 09:44 AM   #5
ramonE90-NL
Netherlands
35
Again not able to do anything with the phone in settings. It even says i have carplay. But i dont have that option. It also says ASIA. And i live in holland[IMG][/IMG]
      11-09-2019, 08:24 AM   #6
//TMT
//TMT's Avatar
129
What happens if you select Telefoon instead of Bluetooth-audio? I bet it shows the full set of options, since that is the base device. Phones support multiple profiles.
      11-10-2019, 12:20 PM   #7
ramonE90-NL
Netherlands
35
I cant select anything. Everything is gray and not selectable.
I cant even remove the phone from the i drive or disconnect it. The only way to disconnect is to switch off bluetooth on the phone
      11-10-2019, 05:40 PM   #8
oakey46
158
This may seem obvious and I apologise if you have already done so, but have you tried doing it with the ignition turned on. Several actions can only be completed with the ignition on.
      11-10-2019, 07:07 PM   #9
ramonE90-NL
Netherlands
35
Yep, ignition on, engine running, even when i was driving
      11-11-2019, 05:28 AM   #10
oakey46
158
My Owners Manual (downloaded version) says:
Deleting a device
Via iDrive:
1. "My Vehicle"
2. "iDrive settings"
3. "Mobile devices"
4. Select the device
5."Delete device
Connecting a device is the same process, except No. 5 is "Connect device"
It also says under "Disconnecting a device" again, as above actions except No. 5 which says "Disconnect device". In this case, however, the device remains registered and can be "connected again".
I assume though all that comes up on your screen?
And I guess that if you've not found any solution, it's a trip to the dealer!
      11-12-2019, 04:22 AM   #11
ramonE90-NL
Netherlands
35
Yes the system is showing all of this. But i can not select anything. So a trip to the dealer it is
      11-12-2019, 12:58 PM   #12
ramonE90-NL
Netherlands
35
Didnt go to the dealer, but tried with my wifes phone (huawei p30 pro) With that phone i can do everything, uncheck bluetooth audio, apps, remove phone.
So my phone seems to be the problem. I have a iphone 7. I have already updated the i drive system with usb stick
      11-12-2019, 09:42 PM   #13
wcs2229
wcs2229's Avatar
171
Maybe borrow another later iPhone model to test it.
      11-28-2019, 03:37 AM   #14
ramonE90-NL
Netherlands
35
Went to the dealer yesterday. I had to remove the car from my phone and turn my phone off and on again.... like i didnt try that first....
Off course no luck.
They were able to remove everyting with the dealer computer and tried it with all of their phones. Now it works again. They said it had something to do with my provider. Dont know if that is true. But for now it works again
