11-30-2020, 10:37 AM | #1 |
158
Rep 458
Map Update for UK/Europe Navigation - EUROPE Way version 2020-4
Available now via the BMW Download Manager app, on Mac OS or Windows, is version EUROPE Way 2020-4.
A 16GB USB dongle should be sufficient to transfer the update into your X1. This has always worked for me after formatting the USB dongle as indicated in the app. This version does NOT work for X1 drivers in North America but, as in the past, is only for UK and Europe X1s with EUROPE Way mapping. If you do not have it already, the BMWDownload Manager App can be accessed by signing in to your BMW ConnectedDrive account and go to 'Remote Cockpit' then 'Control'. The Map Update link for the App is then towards the lower part of the page. You should not need to do this stage if you already have the App on your Mac/PC. So far as I am aware, there is no link to download this via iOS to iPhone or iPad and it can only be actioned via a laptop/desktop Mac or PC. Last edited by oakey46; 11-30-2020 at 10:48 AM.. |
12-01-2020, 08:59 AM | #2 | |
75
Rep 383
Everthing goes to Entropy in this Age.
12-02-2020, 05:10 PM | #3 |
27
Rep 156
Drives: 2016 X1 F48 xdrive xline 2.0 d
Cheers but when I check the map that is available for me is called
EUROPE WEST ROUTE 2021-1? Why the difference? Is it different maps for the "bigger screen" - my car is a 2016? |
12-03-2020, 02:53 AM | #4 |
158
Rep 458
I think that is possibly because your 2016 X1 has a different iDrive software setup to later models with iDrive 6 and EUROPE Way mapping (my X1 is 2018). No doubt someone will be able to confirm that for you, but if the download you mention is a 2021 version and you are still within your BMW ConnectedDrive subscription period, what do you have to lose?
MJE60678.00 |
12-03-2020, 05:03 AM | #5 | |
678
Rep 910
Unfortunately for Entrynav owners, with business nav mapping called route (as opposed to Way for Entrynav 2), it is only updated infrequently (looks to be annually or less) as opposed to quarterly for Entrynav 2. Screen size is not relevant, Entrynav HU can have CDU upgraded to 8.8” also. |
oakey46157.50 |
12-04-2020, 02:45 PM | #6 |
27
Rep 156
I downloaded the map, put it onto USB and plugged into car.
I have done several map updates since I got the car but this was the first time I was asked to put the validation code in. Once I i did this it started transferring and I think it was still doing it 30 mins later whereas it normally just takes a few minutes. Had to stop and unplug the USB, its now saying it can't run the sat nav and to re-insert the USB but when I do that it seems to be just "hanging". Will try again tomorrow but hope I haven't screwed this up somehow! |
12-06-2020, 08:46 AM | #7 |
25
Rep 80
Drives: BMW F48 X1 xDrive20i Sport B48
Thanks for the notification oakey46. Each time one of these appears I am continually puzzled why our Oct 2019 car automatically did an over-the-air update shortly after we got it but hasn't since, as far as I know. Instead, I have manually done the complete download & install process for a couple of the new updates, deliberately missing one of them to see if the OTA update kicked in (no). I know the OTA updates only cover the country in which the car is located, but I asked BMW why they didn't seem to be working and they appeared to think they would be...but I'm not sure that they understood the question. I would have thought an OTA update for my country (UK) would take place around the time you identify that a new total map download is available, but maybe not. Anybody got any idea how I can check if OTA updates are working (or have worked without me noticing!) please?
12-06-2020, 09:44 AM | #8 | |
Air Vice Marshall
256
Rep 1,639
2012 BMW 320d Sport (F31). 2013 BMW X3 xDrive 30d M Sport (F25). 2020 BMW X1 xDrive 2.0i MSport (F48). 2022 MB EQB 300 4MATIC AMG Line Premium |
12-07-2020, 06:35 AM | #10 |
117
Rep 212
What validation code? Where do you find such a code?
My BMWs
02/2017 - 10/2019: X1 F48 18i sDrive X-Line Platinum Silver with Android 10,25 Aftermarket Screen 11/2019 - Present: X1 F48 LCI 18i sDrive Connected Advanced Mineral White |
12-07-2020, 07:11 AM | #11 |
Air Vice Marshall
256
Rep 1,639
Not sure about this, but I would have thought it would not happen again until new data needed to be transferred to the car.
12-07-2020, 07:44 AM | #12 | |
158
Rep 458
12-07-2020, 10:32 AM | #13 | |
Air Vice Marshall
256
Rep 1,639
Normally a code is required if you are outside the warranty period that includes paid-for map updates. When you pay for a map update you get an FSC code that the car asks for in the iDrive. That is how I used to do it on my X3.
BMW used to charge an arm and a leg for map updates along with an FSC code update. This has changed drastically since clandestine sites used to supply them very cheaply along with maps. See.... Quote:
https://www.google.com/search?rlz=1C...fmPAMcQ4dUDCA0 and: https://fscmap.com/#whatisfsc
2012 BMW 320d Sport (F31). 2013 BMW X3 xDrive 30d M Sport (F25). 2020 BMW X1 xDrive 2.0i MSport (F48). 2022 MB EQB 300 4MATIC AMG Line Premium Last edited by Peter_R; 12-07-2020 at 10:39 AM.. |
12-07-2020, 11:04 AM | #14 | |
678
Rep 910
If you logged in and downloaded via BMW connected drive using their software then it will have asked for your car VIN or required you to confirm vehicle and an fsc file/code will have been included and may have been corrupted. If this is the case I suggest downloading again, you should see in the unpacked folder a file titled fsc. If you downloaded from a non BMW source or are using a download from someone else then the fsc folder may be missing or if present will not be for your car hence the problem. Your HU is now locked until a genuine FSC code is entered. If you want nav back you will have to get a BMW main dealer to do an update or purchase a genuine download with fsc code via BMW connected drive. If you did purchase and use a genuine download and it still hangs I would try a different usb dongle and download again, the dongle may be faulty and corrupting the update. Good luck I hope you sort o.k Last edited by MJE60; 12-07-2020 at 11:30 AM.. |
12-07-2020, 02:10 PM | #15 |
27
Rep 156
Hi, next time I went out to car I put the USB in again and it continued the download from around 76% or thereabouts. Would appear that my half hour journey hadn't been long enough to accomdodate the update!
Re the validation code, yes I took out an extended subscription for the maps update so that will be why I got an activation code this time! |
