BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Stock Pirelli P7 RFT
      11-09-2020, 05:14 AM   #1
adi555
21
Drives: F48
I'm on the stock Pirelli P7 RFT that come along with the car. Have done 35k kms so far. Can someone here help me understand how long can these go?
P7's are known for long life as per the company
      11-09-2020, 06:52 AM   #2
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
There are large differences in wear with the car type be it an S Drive or an X Drive. Also with driving style and whether it is Gasoline or Diesel engine.
Just be aware fast cornering and aggressive driving that uses DSC means more breaking and accordingly more brake and tyre wear.
Is it an S Drive?
Is it Petrol (Gas) or Diesel?
Town or motorway style driving?
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      11-09-2020, 06:54 AM   #3
adi555
21
Drives: F48
This is S drive. But looking at the current wear level. How many more kms can this tyre go? The odo is at 35k right now
      11-09-2020, 06:57 AM   #4
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
You need to provide a close-up photo using a tread depth gauge.
BMW recommends that you change your tyres when they reach 3mm tread depth, as tyres below the 3mm recommendation are worn by up to 78% and will greatly affect the overall braking and cornering performance of your vehicle.
      11-09-2020, 07:03 AM   #5
adi555
21
Drives: F48
These tyres are at 3mm. But Michelin says it's too early to change tyres at 3mm because once the tyre starts wearing they provide better dry grip, breaking and also make less noise.
https://www.automotiveworld.com/news...l-environment/
      11-09-2020, 08:43 AM   #6
Skyline2.0
137
Drives: 2018 BMW X1 xDrive
adi555, your tires have a wear bar found in the valleys of the tread to help visually determine how close you are to the minimum depth. Once the face of any tire reaches close to that point, you should strongly consider getting a new set.
From your 2nd photo, it looks like you're close to the wear bar indicator, but it's hard to tell. Legal minimum tire depths are set by locality, but there's nothing stopping you from getting a new set sooner. Handling characteristics in wet/snowy conditions may be compromised if you're driving on tires that have reached the minimum depth level or are close to it.
I've attached a close up of mine. I regularly rotate my tires ~5-6k miles and check tire pressure pretty regularly about once a month, which helps maximize tire life but maybe not necessarily handling characteristics. I'm currently at ~42k miles. I expect at least another 5-10k miles before I consider new tires.
Regardless of what the manufacturer recommends, I wouldn't delay getting new tires if you've reached the legal minimum depth, hit the tread depth indicator level or feel there's compromised handling characteristics.
MJE60678.00
      11-10-2020, 12:16 AM   #7
suniltada
Indian
India
Drives: BMW X1 sDrive 20d Expedition
Time to change / upgrade tyre
Hello, My 2016, F48 is on the Bridgestone Potenza RFT that come along with the car. Now it has clocked 50K (Being a smooth driver I didnt mind clocking 10-15K extra ), It is high time to change / upgrade them. Now a day most of my run is on highway only.
As stock RFT (225/55/R17) tyre are very very noisy after reading all positive feedbacks of tubeless, i am inclining towards tubeless. any suggestion is welcomed
      11-10-2020, 02:16 AM   #8
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
They are all tubeless! Surely you mean Run Flat Tyres? It is a trait of the X1 that most tyres are noisy. In quite a few cases it is the road surface that contributes to the noise.
In the UK all new X1s come with NON-Run Flat Tyres. With these, you need to carry a mobility repair kit incase of a puncture or carry a space-saver spare wheel.
      11-10-2020, 02:35 AM   #9
adi555
21
Drives: F48
Attaching some close up. Please suggest how much more life left. The tyres have done 35000 kms so far.
      11-10-2020, 04:16 AM   #10
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
It is impossible see the tread depth from your photographs across all the tread on all four tyres.
Please read the advice given in the previous posts given above. In India Google search states:
In India, when tread has deterred to the minimum tread depth of 1.6mm the tread wear mark appears, it is suggested to refrain using the tyre after even one tread wear indicator emerges. Because in wet weather/water logging conditions, due to least grip, there is a risk of hydroplaning involved.22 Nov 2019
https://www.google.com/search?rlz=1C...=1264&bih=1290
      11-22-2020, 05:52 AM   #11
kvndng
Drives: 2017 bmw x1
How do you like those tires?
I have the continental run flats right Now but I'm pretty close to needing new tires soon
