BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Tdi-tuning crtd4 multi channel with rpm petrol tuning box chip
      09-23-2020, 12:27 PM   #23
xcelir8bmw
xcelir8bmw's Avatar
402
Drives: 2022 BMW M240ix
Christmas came early.
Booklet Guide...
      09-23-2020, 12:29 PM   #24
Rosa's keeper
Rosa's keeper's Avatar
17
Drives: Chevy Bolt, X2 M35i
Hurry up! LOL
      09-23-2020, 12:29 PM   #25
xcelir8bmw
xcelir8bmw's Avatar
402
I also have an Email out to them....
TDI Tuning -
Hello. I just received my package via DHL for my BMW X2 M35i, Order #xxxxx.
Everything looks in order.
However, the pictures (albeit similar B48 engine) are not 'EXACTLY' my 2019 X2 M35i variant (see my engine picture attached)
I just want to make sure that the appropriate tune/maps were burned into the unit for a:
BMW X2 M35i AWD 302 BHP / 306 PS / 225 KW / 450 NM / 332 LBFT - From 2019
Please advise and thank you!
      09-23-2020, 12:30 PM   #26
xcelir8bmw
xcelir8bmw's Avatar
402
Once I get a reply from the email ^^, I'll install it all and 'hide' the brain under the plastic. Looks like I should be able to definitely be stealth with this setup and Bluetooth functionality.
      09-23-2020, 01:07 PM   #27
Rosa's keeper
17
I keep refreshing this page! *Sending good thoughts/praying to the modding gods that we actually have a solution*
      09-23-2020, 01:41 PM   #28
//TMT
//TMT's Avatar
129
It's evening in the UK, you might have to wait for tomorrow
Interesting that it can do this with only two air pressure sensors, and one cam position.
      09-23-2020, 04:38 PM   #29
xcelir8bmw
xcelir8bmw's Avatar
402
Yeah, I'm well aware of the time.
Tomorrow we shall see. Pretty confident all is good at this point. Optimism.
      09-23-2020, 06:34 PM   #30
xcelir8bmw
xcelir8bmw's Avatar
402
Update. Here is where we are at:
Email #2 (follow up to Email #1) TDI-Tuning...
Technical support,
As a follow up to my last Email, I successfully installed the system into my BMW X2 M35i AWD 302 BHP / 306 PS / 225 KW / 450 NM / 332 LBFT as I ordered it this way. I also installed the Bluetooth Application and have everything up and running.
I spent about a half hour driving and validated that the functionality of maps 1-7 do cycle through on the vehicle while watching my Boost Gauge.
THERE IS A PROBLEM.
Stock Boost is 22.48-22.8 PSI peak readings regularly without the tuning box installed. With the tuning box installed and system OFF, I read 22.6 PSI max boost - which is close enough to Stock Boost peak readings.
When I turn the system ON, in Maps 1-7, I have varying boost of 18.1-20.5 PSI peak readings. In other words, the box is working fine, but the MAPS ARE WRONG. I do not have increased power, rather I now have DECREASED power.
With that being said, through the iOS application I submitted a request for Map Update and the message said 'No tuning map update required'.
For now, the system is turned off until you can come back to me with a solution.
Please help.
Thank you!
      09-23-2020, 06:35 PM   #31
xcelir8bmw
xcelir8bmw's Avatar
402
Now we wait...
      09-23-2020, 06:36 PM   #32
xcelir8bmw
xcelir8bmw's Avatar
402
Oh, BTW - there was no way, without cutting plastic, to hide the Tuning Box. And doing so would change the look of OEM if I removed the device. Therefore, it is what it is.
      09-23-2020, 07:23 PM   #33
Davy Jordi
Davy Jordi's Avatar
106
Drives: F39 X2 M35i
you mounted it in the same location that i placed my bms unit.
might have to bite the bullet and give ol' bms a try if this company doesn't work out...
Alpine White BMW X2 M35i
      09-23-2020, 08:30 PM   #34
//TMT
//TMT's Avatar
129
Originally Posted by xcelir8bmw View Post
THERE IS A PROBLEM.
Wait - you're reading the value from the car, or do you have a boost gauge?
If you're reading the value from the car, you are reading the *shifted* boost value that the TDI box has remapped. This type of box intercepts the actual value and changes it, to lie to the engine controller to fool it into producing more boost, etc. So, the engine controller's is (by definition) not accurate!
How does the car actually feel? Does your butt dyno tell you it's different? Can you try any 1/4 mile testing?
      09-23-2020, 08:32 PM   #35
xcelir8bmw
xcelir8bmw's Avatar
402
Reduced Power for sure. Butt dyno slow. Wrong maps. Various tools I use and even BMW dashboard on power and torque suck. Feels like a civic.
      09-23-2020, 09:09 PM   #36
Will Pwr
eM Power Me
Will Pwr's Avatar
749
Drives: '23 AW i4 eDrive40 M Sport
I was about to comment the same in regards to boost measurement via the OBD II and how that would be an altered reading.
Only way to get a true measurement would be the more analog route of a boost tap.
Have you noticed or measured any other changes to the behavior of the engine or car? e.g. performance gain/loss, rough idle, hesitation, etc. Are the issues/symptoms the same as with your Dinan unit?
Any other mods on the car? mechanical or electrical?
Will -
'23 Alpine White G26 ///i4 eDrive40 M Sport
'23 Brooklyn Grey G20 ///330e M Sport
'20 Alpine White F97 ///X3MC
'20 Alpine White F39 ///X2 M Sport X
      09-24-2020, 06:45 AM   #37
//TMT
//TMT's Avatar
129
Ok, again, the dashboard display and any OBD-II type tool will be reading fictional values. Don't go by them, when this device is in the loop.
Feels like a civic.
Same in all the maps 1-7? Does it change at all?
What happens if you turn the device off completely?
      09-24-2020, 06:57 AM   #38
xcelir8bmw
xcelir8bmw's Avatar
402
Emailing with TDI.
Measurements aside with OBDII and BMW gauge, car is functional but feels slow when unit is on. When off feels peppy again. Counting acceleration similar to get up to speed and location.
Dinan just didn't even work.
This product seems to.
Going to turn off my BMS pedal tuner to see if it helps. Maybe the maps are so good and smooth that the peppy feeling of being thrown back into seat is a false sense of power. Maybe the BMS is part of the problem which I hope so.
Fresh start today.
Optimism.
      09-24-2020, 07:26 AM   #39
xcelir8bmw
xcelir8bmw's Avatar
402
Just got off the phone with Ward @ TDI out of the UK.
Confidence is high that the map I have for this vehicle is right.
Going to retest everything tonight with the BMS pedal tuner box off and uninstalled. Going to test harder, longer, faster then I did yesterday.
Depending on those results, I'll drop TDI an Email with how things appear and feel and worst case they'll work on a re-map and I can download and install it via their app. I hope that's not the case, hope it's the BMS and/or shitty stock factory mapping where the car is now just smoooooooth with power.
Like I said, that's where we are at with optimism.
Stay tuned.
      09-24-2020, 10:21 AM   #40
Rosa's keeper
17
Good Luck!
      09-24-2020, 01:04 PM   #41
xcelir8bmw
xcelir8bmw's Avatar
402
In between meetings, BMS is now removed back to stock.
Later tonight we'll see...
      09-24-2020, 01:21 PM   #42
xcelir8bmw
xcelir8bmw's Avatar
402
Wait - you're reading the value from the car...
TDI does say something similar. However, out of curiousity, testing tonight.
Why wouldn't the OBDII boost specs show 22.8 MAX, while the TDI unit pushes more above it?
Why would 22.8 show reduced if the OBDII is 20.xx, would the TDI be adding 5 PSI as an example.
I found this:
http://www.p3cars.com/bmw/p3-boost-tap-bmw-b48-b58/
But I think it is the wrong MAF sensor shape for the M35i (looking later).
Cause honestly, besides a DRAGY or tapped boost gauge, I want 'real' measurements.
      09-24-2020, 02:00 PM   #43
billnchristy
1604
Drives: 2022 M440xi GC
Really it should always show under max because mac should be 0 extra. 20.8 would be +2 etc
      09-24-2020, 02:04 PM   #44
xcelir8bmw
xcelir8bmw's Avatar
402
So in Map 1, I get say 18. 22.8 minus 18 is 4.8. Map 1 is supposed to be low HP.
So in Map 7, I get say 20. 22.8 minus 20 is 2. Map 7 is supposed to be high HP.
Can you provide me clarity on your statement? Trying to understand yah.
Search this Thread:
Advanced Search
