BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) BMW E-sys coding for the f48 x1
      05-23-2019, 11:16 PM   #639
StefanJ
StefanJ's Avatar
68
Drives: BMW X3 G01 xDrive 20d
Hi,
My car is an F48 sDrive 18d 2016, LHD for European market.
It has only one central locking switch, on the front left driver's door.
Yesterday I added a central locking switch on the front right door, but is not functional (only the lights inside are working).
Does anyone know if there is a coding for making functional the central locking button on the right door ?
The F48 for the US and China markets has this button functional.
      08-05-2019, 01:32 PM   #640
MauroSte
MauroSte's Avatar
Croatia
Drives: BMW F48 X1
Hi,
I have F48 X1 sDrive 18d (02/2018), with 6.5" ENTRYNAV2 and 6UN nav, without AUX input, under the arm board.
If I understand well, retrofitted ApplePlay or Android device route the sound through the AUX port. How can be provided in my case ? AUX still exists on the head unit ? Can be opened by coding?
Mauro
      08-05-2019, 11:17 PM   #641
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by MauroSte View Post
Hi,
Mauro
BWM's Carplay is BT/Wifi handshake. It does not use a tethered phone.
If you retrofit, it would depend on solution used.
      08-05-2019, 11:26 PM   #642
MauroSte
MauroSte's Avatar
Croatia
Drives: BMW F48 X1
Hi,
Mauro
Hi,
can you be more specific, for example the ACP Unique and Android AVIN device like:
http://www.audicom.it/index.php?id_p...roller=product
When I spoke with the dealer, they proposed this solution:
Maybe the AUX still exists on the head unit, but need to be unlocked ?
Mauro
      08-06-2019, 12:14 AM   #643
Almaretto
Almaretto's Avatar
2374
Hi,
Mauro
Carplay is wireless and does not need Aux input for audio. Both audio and video are transmitted via wifi.
If you want AUX for some reason, yes, you could use USB adapter.
      08-06-2019, 12:28 AM   #644
MauroSte
MauroSte's Avatar
Croatia
Drives: BMW F48 X1
Hi,
Mauro
Ok, and how you will route the Avin / Android device sound ?
In my case, ACP dongle will be plugged in Android USB port.
      08-06-2019, 08:31 PM   #645
Almaretto
Almaretto's Avatar
2374
For that, I am unsure. Do you know if website has more information about product or installation?
      08-07-2019, 06:48 AM   #646
MauroSte
MauroSte's Avatar
Croatia
Drives: BMW F48 X1
Hi,
dealer recommended AUX to USB dongle (link above).
Thought that AUX can be accessed/unlocked on the head unit.
Mauro
      08-09-2019, 12:27 PM   #647
Takabo
Takabo's Avatar
Japan
49
Drives: G21 320d xDrive Touring MSport
Originally Posted by MJE60 View Post
Yes, einausstiegshilfe IS easy entry (the word is German for entry exit assistance). You have activated easy entry. Congratulations.
If you still want to adjust how much the seat moves back then other two settings can be adjusted. If you are struggling to find settings in E-sys then consider using Bimmercode.
Hello.
Changed the amount of seat adjustment.
Section 3012 has no settings.
However, there is a setting in section 3015.
I got information from here.
BIMMERCODE
ECUs → Seat Module Driver (CFAS_PLX_1) → Expert Mode
→ 3015_0_1_255 → 0x3C(Default:0x3C)=EAH_VERFAHRWEG_SLV_PHYS
→ 3015_4_5_255 → 0x37(Default:0x64)=EAH_SCHUTZFREIRAUM_HINTEN_SLV_P HYS
Let's share this information.
Thank you very much.
Appreciate 2
MJE60678.00
Douggie142.00
      09-04-2019, 08:39 AM   #648
kkk09
Drives: BMW x1 F48
First hello for everyone. Sorry for my englisch. I have x1 f48 from usa and i need to recode to EU. I have e-sys and i have already recode lang and some other, but i dont know really what should recode to have all in eu. Maybe somone can help me. Not working for me from start sign recognition, i have still on my HUD (---). Help guys
      09-04-2019, 11:30 PM   #649
Almaretto
Almaretto's Avatar
2374
Do not code all to EU as that can cause issues as hardware may be different.
      09-05-2019, 02:09 AM   #650
kkk09
Drives: BMW x1 F48
i dont have eu map - could this be a problem?
      09-05-2019, 09:11 AM   #651
ejw2011
ejw2011's Avatar
94
Drives: x3 F25 35i, x1 F48 28i
Try this:
KAFAS>Country_coding_display=ECE_WHITE
      09-05-2019, 09:32 AM   #652
kkk09
Drives: BMW x1 F48
Originally Posted by ejw2011 View Post
Try this:
yes, i have it that
      09-05-2019, 09:39 PM   #653
Almaretto
Almaretto's Avatar
2374
Navigation map region will not be an issue.
It is more things like drivetrain, lighting, airbags, etc.
      09-06-2019, 05:58 AM   #654
kkk09
Drives: BMW x1 F48
one guy who worked at the bmw service told me I had to have a map eu if i drive on eu. I have hu_entrynav2
      09-06-2019, 06:00 AM   #655
kkk09
Drives: BMW x1 F48
i have business way maps, and he told me "only service bmw"
      09-29-2019, 09:30 AM   #656
Takabo
Takabo's Avatar
Japan
49
Changing the default distance of Adaptive Cruise Control
Originally Posted by Takabo View Post
Hello!
Have you tried changing the default distance of ACC and easy entry of the power seat with the X1 (F48) / X2 (F39) manufactured in 2018?
Hello!
Changing the default distance of Adaptive Cruise Control(3 to 2 frames)
ECUs -> SAS -> LDM_Abstandsstufe_init -> Werte = 02 (default: Werte = 03)
Let's share
      09-29-2019, 10:44 PM   #657
Xorbitman
47
Drives: 2018 BMW X1
Originally Posted by Shubha29 View Post
Hi Vogit,
Today was my first coding session, I was successful in coding following:
1. Close windows, sunroof & mirror from key fob. (Tested OK)
2. Change Triple-Blink Count to blink 5 times. (Tested OK)
3. Enable Illumination of Exterior Door Handle LEDs when in Reverse. (Tested OK)
4. Set cell phone ringer as primary. (Tested OK)
5. Enable Video Files from USB (Need to know the supported formats to play one).
6. Add GPS Current Location to Navi Menu Items. (Not sure where to see for it).
7. Air Re-Circulating (But actually wanted to set to Manual Re-circulation, probably settings should be changed 3003MEMORY_UMLUFT -> nicht_aktiv ?)
8. Add Digital Speed to LCD Display via BC button.(Tested OK)
9. Turn on Brake Force Flashing with Hard Braking (Yet to test).
10. DVD-in-Motion activated (But don't believe F048 can read DVD so unable to test).
11. Close/Open Rear Hatch from Fob & Kick Panel. (Tested OK)
12. Enable Curb and Grass Detection for Lane Departure Warning System (Not sure what extra feature will this add to the lane departure - yet to test, will it monitor grass instead of white lines? ).
13. Enable Rear-View Camera at all Speeds (Not sure how to use it, as rear camera is shown only on Reverse Gear).
Following was coded but didn't work:
1. Enable Turn Signals in HUD. (HU: 3001HUD_TURNSIGNAL set to: aktiv)
2. Turn off MMI when door is opened -> BDC : 3020  TCM_LOGIC_R_OFF_DOOR = aktiv 01
This function was not found at all:
1. Unlock Doors on Engine OFF -> BDC: 3040  VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK = aktiv 01 (Did anyone else found it in F048 ?).
Next: Curious to learn about the HK equalizer settings, hence saved the CAFD files into my laptop and need to know if there is any software available to read the CAFD files in offline mode, to do research on the Harmon Kardon Equalizer settings.
Thanks in advance for your help!!!
Did most of these. My fob closes the tail. FOB Lock: Closes everything including mirrors except tailgate. Convenience handle lock closes everything except tail...maybe I didn't hold it long enough though....
      10-16-2019, 04:15 PM   #658
TaenKarth
Drives: BMW X1
Hi guys! Love this thread. Allowed me to do a lot of coding on my own so far.
Question.
Has anyone gotten the following two settings to work?
1. Power on car without using foot pedal
2. Single press power on car
On my 2016 X1 when I code those options from the cheat sheet my car will no longer start at all. I have to code them back to get it to start again.
Thanks!
      10-16-2019, 04:56 PM   #659
TaenKarth
Drives: BMW X1
Also after coding some standard options there is now a Brake System warning...
I have ran Transmitter and cleared all DTC and it still pops up. Any thoughts?
Thanks!
      10-17-2019, 01:11 AM   #660
Douggie
142
Drives: BMW X1, X3
Hello.
BIMMERCODE
Thanks! Great information!
Takabo49.00
