04-16-2019, 04:04 AM | #617 | |
Rep 21
The fact is that I have F56, officially 5DF is not stated for it, but they say it can be encoded as F48. But I don’t know how to do it. |
04-16-2019, 05:21 AM | #618 | |
678
Rep 910
For the F48 ACC is only available (may vary by market but certainly was the position for Europe & US) as part of driving assistant plus 5ATA package but if you look at VIN factory FA build it shows S5ATA and 5DF separately. If you had cruise control with braking function (option S544A) it needs to be removed and replaced with 5DF. This is called VO coding and has to be done with E-Sys. Whilst it should be possible to make all individual Ecu code changes using Bimmercode (fdl coding), I have not seen a list assembled for F48 and the tools to help you identify such changes is imo unreliable for F56/f48. My best advise is go to Bimmerfest coding forum and ask for assistance, namely a recommendation on who to use to do the VO coding for you. Other option is search the internet for BMW coding services. The coding can be done remotely, there are people with the expertise. In addition to changing your car FA through VO coding, you may also find that some of the parts fitted (SAS module for example) might need updating (CAFD updating for your car Istep - software version). Finally when you say you have all the parts fitted to make ACC work, My list of necessary parts would include -new steering wheel switch -wiring loom patch for SAS module -SAS module (acc works through this module) - new DSC Unit (or additional pressure sensor fitted into existing DSC - the SAS module and HU need brake pressure readings to control braking function as it is routed completely differently to option S544a. The DSC for option 5DF is modified). There is a reason why BMW have not protected 5DF with an fsc code, the reason is that it requires a lot of replacement/additional parts. Good luck, Hope it works for you, let us know. Last edited by MJE60; 04-16-2019 at 05:31 AM.. |
04-16-2019, 01:25 PM | #619 |
Rep 21
04-20-2019, 02:50 AM | #620 |
Rep 3
Hi guys,
I'm new in car coding. I tried to add Extended Apple Support in HeadUnit because I read on the web that it would enable me to change selected iPhone app from the iDrive (for instance, switching from connected drive to Spotify and vice-versa). This of course didn't work and now I don't have any "Connected Services" anymore. lol So, basically all the other coding (like keeping in memory the drive status and so on) worked perfectly. But now I would like to get back my BMW Apps and Connected Services as they were before (it was present when they delivered my car). Any suggestion what I might have changed? I tried restoring HeadUnit backup but still, no luck. Might be, this setting is coming from another ECU, I don't remember having changed anything related to online services or BMW Apps in any other ECU BTW... Last information: I'm using bimmercode on an iPhone with a WiFi ODB2 connector. Thanks for your help and compliments for the great forum. Bye! M |
04-20-2019, 08:10 AM | #621 | |
678
Rep 910
Did you keep a record of the exact changes you made? I have included a link which may help with future bimmercode adventures. https://f48.bimmerpost.com/forums/sh....php?t=1587508 Last edited by MJE60; 04-20-2019 at 08:16 AM.. |
04-20-2019, 11:09 AM | #622 | |
Rep 3
Problem is: When the BMW Apps disappeared I did a few trials and errors and there I lost track of my changes. Point is: looks like even restoring the very first HU backup I have is not solving the issue. Question, then, is: Do someone know the entries I should check to ensure BMW Apps / Connected Drive services are enabled? Most probably I have a faulty backup or there is another entry in a different ECU than HU I have changed and I forgot. You know: in the beginning you're scared and you keep track of everything: all goes well. Then you feel confident and you start doing actual mistakes. |
04-20-2019, 11:33 AM | #623 |
159
Rep 458
As I’ve indicated recently, my knowledge of coding is zero, so this is essentially an off the cuff response and may not work for you.
I use an iPhone 7 with my Connected Drive and looking at the App and going into the ‘More’ tab and on to the FAQ page, there’s a response to ‘How can I fix the connection between my phone and my vehicle if it stops working.’ Perhaps going back to basics might be worth a try, so long as you appreciate there may be some risk involved. MJE60 might have thoughts on that approach. |
MJE60678.00 |
04-20-2019, 01:39 PM | #624 | |
678
Rep 910
04-20-2019, 06:24 PM | #625 | ||||
Rep 3
Basically sometimes when flashing HU_NBT you lose those services. Just go there and click "update". In a few seconds, all the usual apps and services are back! Thanks guys for your support, hope this could help someone else which is in the same situation. Byeeee |
04-25-2019, 01:13 AM | #628 |
Rep 4
Hi Community!
In the past I just looked over the shoulder of a friend who coded my E91 LCI After my wife owned a brand new F48 I looked into the "new coding" with e-sys and I mean it's pretty simple compared to NCS. Therefore I decided to do it on my own. As informations about F48 coding are very rare in the web I really want to say thank you for this thread - it helped a lot! Especially the posts and knowledge of Almaretto. But as allways I have still some questions: 1. I read somewhere else that I have to deactivate MSC and VCM update in E-Sys options, to avoid some "flags" which BMW could read and warranty would disappear. Is that true? 2. Every KOMBI-coding will cause an error - is that true? 3. With E-sys 3.33.1 I have no EDIABAS or INPA to read/delete the FS - any ideas where to get it? Download links I found are all invalid. 4. Is there a way to code US-sidemarkers (dimmed turn lights) for adaptive LED lights? I found some options But the provided values didn't tell me which should work. Thank you guys! |
04-25-2019, 05:17 AM | #629 | |
678
Rep 910
Your questions require fairly lengthy answers so I will take one at a time. 1. Update of VCM & MSM- disable in settings. Short answer is yes. The reason is that E-sys is BMW oem software and you really do not want a detailed audit trail of your coding being sent back to Munich computers for analysis. The long answer is that there are occasions where you do want to update the VCM (vehicle configuration) however you should only do so manually and if you understand what and why you are doing it. As an example I changed my car configuration from S6UN to S6UP and updated the Build configuration in VCM, the reason is that I wanted my retrofit to be permanent and recognised by BMW dealer software whenever the car is updated. However, I made sure I used genuine BMW parts that were correct for my car build date. In other words the car was correct to factory specification, this way, the dealer software will not throw up error codes. In summary, only update the VCM if your retrofit/coding changes and parts are correct for the car model and correct for build date. Last edited by MJE60; 04-25-2019 at 11:44 AM.. |
Demonaz3.50 |
04-25-2019, 09:31 AM | #630 | ||
Rep 4
So what I am supposed to do now? Is it too late? |
04-25-2019, 10:02 AM | #631 | |
678
Rep 910
None of the changes you made should have any impact on warranty but I would still disable VCM & MSM update after TAL execution in the E-sys settings. Last edited by MJE60; 04-25-2019 at 10:08 AM.. |
Demonaz3.50 |
04-25-2019, 10:13 AM | #632 |
678
Rep 910
With regard to E-sys 3.33.1 I am not sure why you are using this version or what version of Launcher you are using with it but only source of reliable download links I would trust are from Shawn Sheridan, I suggest you PM him and ask.
Demonaz3.50 |
04-25-2019, 10:39 AM | #633 | |
Rep 4
I will PM Shawnsheridan thanks! |
MJE60678.00 |
04-25-2019, 10:53 AM | #634 | ||
30
Rep 78
04-25-2019, 02:18 PM | #635 | |
52
Rep 105
I get his reasoning behind making that decision but I feel it could have/could be handled a bit better; especially for those of us who are following his directions and attempting to legitimately use it versus trying to profit off of it. |
04-25-2019, 10:11 PM | #636 | |
2374
Rep 8,364
04-26-2019, 02:01 AM | #637 |
101
Rep 228
Climate Control Temp Increment Coding
Is it possible to code the climate control temperature setting to increment by 1 degree instead of 2 degrees, e.g. 62, 64, 66, etc.?
05-09-2019, 07:57 PM | #638 |
49
Rep 69
E-Sys Launcher PRO 2.8.2
Hello everyone.
Did you read this blog? https://tokenmaster.blogspot.com/201...r-pro-282.html I coded with BIMMERCODE, but also installed E-Sys Launcher PRO 2.8.2. Thank you. |
MJE60678.00 |
