BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) BMW E-sys coding for the f48 x1
      05-27-2020, 01:58 PM   #683
samuelbpereira
Brazil
Drives: BMW X1 25i 2019 F48
Originally Posted by dmnc02 View Post
My wife picked up a X1 a few days ago, and I have started coding it (which is why I have been checking this thread). Here are the things I found useful coding so far on her US-spec-car:
  • Adaptive headlights: The "LED headlights with extended features" on the X1 support what BMW calls Static adaptive headlights:
    At speeds between 45 km/h and 70 km/h the cornering light is used as a "static Adaptive Headlight". The LEDs, which are responsible for the cornering light, are activated in order to illuminate the cornering area. This function is called a static Adaptive Headlight because the headlight is not moved.
    This is disabled by default on US cars to comply with outdated US regulations. It is nowhere as useful as the no-dazzle high beams on my M4, but still worth enabling IMO. To be clear: this is different from the cornering lights functionality, since the cornering lights are activated even when the car is not cornering in order to provide a wider illumination of the road.
  • Brighter halos: The halos in the headlights are dimmed by default to 46% on both US and EU cars when used as position lights (i.e., when the low beams are on). They did not look as bright as on my M4, so I increased the intensity to 70%.
  • Allow fog lights on with high beams: This is standard on EU cars, but disabled on US cars.
  • Close trunk with keyfob: This is disabled on US cars and requires keeping the button on the remote pressed on EU cars. I coded it so that it opens with a single press of the remote button.
  • Unlock doors at ignition off: This is disabled on US cars and it only works on EU cars if the doors were automatically locked. I coded it so that the doors always unlock.
  • Change speed limit information in HUD and instrument cluster: I really dislike the US white square sign and changed it to EU display.
  • Standard stuff: Remove iDrive legal disclaimer, shorter seat belt reminder, etc.
Hello, my trunk doesn't close with just one touch on the control, opening it opens with just one touch, can you tell me where I can make it close with just one touch instead of having to hold it to close? Thank you
      05-27-2020, 02:30 PM   #684
SDriver18i
SDriver18i's Avatar
80
Drives: BMW X1 s18i 2019
Look in the Tailgate function in Bimmercode.
      05-28-2020, 05:35 AM   #685
Takabo
Takabo's Avatar
Japan
49
Drives: G21 320d xDrive Touring MSport
Hello, help me with the doubt I'm having, this change causes the bank to retreat when unlocking the car and when I start the car it goes back to the original position or do I have to click on the memory button to get it back? My BMW is an X1 25i 2019
Hi,
My latest settings are:
ECUs → Seat Module Driver (CFAS_PLX_1) → Expert Mode → EINAUSSTIEGSHILFE → Modus_FA_SLV (default: nicht_aktiv)
→ 3015_0_1_255 → 0x3C (default: 0x3C):EAH_VERFAHRWEG_SLV_PHYS
・ ・ ・ Default 60mm (3C) back distance
→ 3015_4_5_255 → 0x37 (default: 0x64):EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS
... Change the protection distance from the default 100mm (64) protection to 55mm (37)
BMW 320d xDrive Touring M Sport(G21)
Production Plant: Munich, Production Date: 2021-02-25
      05-30-2020, 11:56 AM   #686
samuelbpereira
Brazil
Originally Posted by oreoOozZz View Post
Here is my rough copy of all the coding I've done so far on my newer I-Step F48. It was just for my records, not an official copy at all. Everything here does work for me 110% though unless otherwise listed.
Seatbelt Reminder and Gong
Reverse door lights on
Inband Ringing (Cell phone ringer instead of car)
Foglights with parking lights
Foglights with high beams
British Voice For IDrive(Worked but made things funky with SAT radio and NAV so disabled)
No Horn on lock when car on
USB Video(did not work)
Trunk open and close with keyfob/kick panel
5 blink turn signal
Mirror fold/lock/windows up/sunroof close on keyfob lock
Iwelcome msg at startup disable
Disable Welcome 3 gongs seatbelt
M logo on startup IDrive
Brake light flashing(not working)
Unlock on ignition off(made weird things happen, car would shut off when drivers door ajar sometimes so disabled)
Digital Speed In Cluster
LED Foglight Error Check Disable (Cold/Warm)
Values
ACSM Module:
SeatBelt Reminder Lights OFF: set all to nicht_aktiv
3000>Gurtzustandsanzeige_Beifahrer_GFW_GZA_BF
3000>Gurtzustandsanzeige_Fahrer_GFW_GZA_FA
Disable Welcome 3 Gongs:
3000>Initialwarnung_GWF_IW = nicht_aktiv
SeatBelt Reminders/Sound OFF: set all to nicht_aktiv
3000>SBR_PreWarning_Fahrer
3000>SBR_PreWarning_Beifahrer
3000>SeatBeltReminder_SBR_Fahrer
3000>SeatBeltReminder_SBR_Beifahrer
BDC_BODY Module:
LED Foglight Disable Error Checks
3060>NSW_L AND NSW_R WARNUNGS
Horn Doesnt Sound When Locking From Keyfob With Car On
3040>VAM_HORN_AT_SECURE = nicht_aktiv
Lights Flash At Unlock And Lock
3040>VAM_REQUIRE_LCE_FLASHING_AT_UNLOCKING_SECURIN G = aktiv
Soft Blink = 5 Times
3069>PIA_DEFAULT_TIPPBLINKEN = tippblinken_fuenfmal werte = 02
Close Mirrors/Windows/SunRoof from FOB or CA – set all to: aktiv
3056>KOMFORTSCHLIESSUNG_FB
3056>KOMFORTSCHLIESSUNG_PA
3110>ASP_BEIKLAPPEN
3110>ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN
3110>ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN
Set Mirror Fold Delay Time to Instant upon locking
3056>KOMFORT_SCHLIESSEN = 00
Enable Illumination of Exterior Door Handle LEDs when in Reverse
3070>OVT_BEI_REUCKFAHRLICHT = aktiv
Fog Lights stay on w/ High Beams
3068>NSW_AUS_BEI_FL = nicht_aktiv
Fog Lights Stay On With Parking Lights
3068>NSW_EIN_AUF_LDS_STL = aktiv
HU_ENTRYNAV Module:
3003>INBAND_RINGING = aktiv
Change i-Drive Animation to ///M Logo
3001>STARTUP_EMBLEM = variant_01
Change Navi Voice to British English ---- CANT USE MESSES UP SAT RADIO TEXT AND ANYTHING USA TEXT
3000>LANGUAGE_ENGLISH_UK set to: master
3000>LANGUAGE_ENGLISH_US set to: nicht_aktiv
Remove Legal Disclaimers
3001>LEGAL_DISCLAIMER_TIME set to: kein_ld
3001>MACRO_CAM_LEGALDISCLAIMER set to: kein_ld
3001>MACRO_NIVICAM_LDISCLAIMER set to: kein_ld
Add Weatherband Radio to sources:
3002>RADIO_WEATHERBAND = aktiv 01
BKOMBI Module:
Show Digital Speed in MPH in Cluster
3000>BC_DIGITAL_V = aktiv
Change Startup Screen in SpeedoLCD to ///M Performance:
3000>BMW_LOGO = mpm
EDIT: I forgot to mention, this didnt work either and i figured out why. You need to have the expanded cluster. 6WA Kombi, i believe. Without this you can only code the iDrive to change startup video.
Set Clock via GPS:
3000>GPS_UHR = aktiv 01
HKFM Module:
Close/Open Rear Hatch from Fob & Kick Panel
3010>SCH_FBD set to: aktiv – werte=01
3010>SCH_TOEHKI set to: aktiv – werte=01
3010>TASTER_FBD set to: aktiv –
werte=01
Hello, did you manage to make the angel eye get 100% when you turn on the low beam?
      06-08-2020, 11:23 PM   #687
Wrightspeed
Drives: 2018 BMW X1 M-Sport
Does anyone know if it is possible to code the folding of the rear seat backs? Currently the left button in the trunk does the left seat and the middle while the right button does the right seat only, but I would love to flip that so the right button does the right & middle.
      06-19-2020, 11:02 AM   #688
MJE60
MJE60's Avatar
Originally Posted by Bluezed View Post
Did you see a code for the Auto Stop/Start remaining 'as was' when the engine is switched off?
I have to keep remembering to do it manually every time I switch on.
It is an easy change option using Bimmercode. It allows you to change default (in some countries) from On at start-up to “remember last setting”
      06-25-2020, 12:45 PM   #689
iVladimir
Drives: BMW X3 F25 xDrive 35i
Hello to all! Maybe someone can help me. I have a 2018 X1 F48. Basically, all I need is I encoded. But I could not find the encoding for closing the trunk with the remote control.
Always and in almost all cars it was in the HKFM Module:
The problem is that I do not have the HKFM module, but there is HKFM2. But it does not have any of these three meanings. Searched through E-SYS and in parts and as soon as possible. There are no these parameters there. Where to look for them? Or maybe in new models these parameters are called differently?
      06-25-2020, 04:05 PM   #690
MJE60
MJE60's Avatar
Are you sure it is not already set? You need to hold the tailgate button down (not just press it like when you open The tailgate). The reason for needing to hold the button down is safety so that you do not accidentally close the tailgate on someone.
      06-26-2020, 01:06 AM   #691
iVladimir
I am sure. I do BMW coding myself. I know very well how to check it for performance. Therefore, I am surprised that I can not find these functions for encoding.
      06-26-2020, 04:50 AM   #692
iVladimir
Everything went well. Thanks to Almaretto, Steve_M_Sport and Stylefr from another forum.
And so, for the HKFM2 module, a slightly different procedure for the driver’s door button and remote control button:
3008 USER_LOG_HKL_ROCKERSWITCHPOS1 -> HKL_ROCKERSWITCHPOS1_BUTTON_TYPE -> Right click on Werte=02 (second entry under "Ausgelesen"). Choose edit and in the entry box at the bottom of the screen change "02" to "05". It is for the driver’s door button.
300B USER_LOG_HKL_REMOTECONTROLLIFTGATEBUTTON -> HKL_REMOTECONTROLLIFTGATEBUTTON_BUTTON_TYPE -> Change Werte=02 to Werte=05. It is for the remote control button.
After coding, it is advisable to let the car fall asleep even for a minute.
      07-03-2020, 07:03 AM   #693
sambe002
Drives: bmw x1
Hello,
I want to code the SeatBeltReminder in my BMW-X1 (2019)
I use Esys 3.30 and psdzdate 4.24.12 and I see the next ACSM_4i screen:
3000 Gurtwarnung 32
Gurtwarnung_0_0_255
Gurtwarnung_1_1_255
Gurtwarnung_2_2_255
etc
So nothing looks like
Any ideas?
Thanks, henk
      09-14-2020, 04:48 AM   #694
hongkongloftus
hongkongloftus's Avatar
Hong Kong
17
Drives: 09/2016 X1 F48 18d
Originally Posted by sambe002 View Post
Hello,
3000 Gurtwarnung 32
Gurtwarnung_0_0_255
Gurtwarnung_1_1_255
Gurtwarnung_2_2_255
etc
Any ideas?
Thanks, henk
You can try 3001 SbrTWarnDurTr1 , original Werte=64 then the seat belt warning is 100sec, I set Werte=08 then the seat belt warning change to 8sec. In safe situation, I keep the warning on.
      10-13-2020, 10:42 AM   #695
shadowant
Drives: X1 F48
Retrofitted NBT EVO TMC
Hi!
Does anybody knows - is it possible to code TMC instead RTTI on NBT EVO?
      10-15-2020, 12:24 PM   #696
miss
Drives: bmw x1
did anyone try this?
HU_NBT_EVO> TELEFON_TELEMATIK_ONLINE 3003> WLAN_STATUS
HU_NBT_EVO> TELEFON_TELEMATIK_ONLINE 3003> WLAN_WIFI_DIRECT
HU_NBT_EVO> HMI 3000> ENT_MIRACAST
HU_NBT_EVO> HMI 3000> ENT_MIRACAST_DISPLAY_SETTINGS
HU_NBT_EVO> HMI 3000> ENT_MC_WLAN_STREAM_DMP
HU_NBT_EVO> HMI 3000> ENT_MC_WLAN_STREAM_DMP_COVERART
HU_NBT_EVO> HMI 3000> ENT_MC_WLAN_STREAM_DMP_VIDEO
They say that screen mirroring is activated on a NBT EVO.
      10-16-2020, 03:43 AM   #697
shadowant
Drives: X1 F48
Hi, the following will be enough for entrynav2 either to run screen mirroring
      10-16-2020, 06:53 PM   #698
maaii11
Drives: Mini F54
@shadowant Do you try this on your headunit? Because entrynav2 Headunit didn’t support screen mirroring
      10-21-2020, 12:16 PM   #699
shadowant
Drives: X1 F48
It was working on my entrynav2 HU. It was 09/17 and with WiFi module.
      10-21-2020, 12:19 PM   #700
shadowant
Drives: X1 F48
maaii11 by the way, do you know any OEM method to activate rtti on retrofitted nbt evo? Except connecteddrive portal (no rtti for my vin there)...
      10-26-2020, 06:25 PM   #701
omglol
Drives: F31
Does anyone know how to enable start/stop memory function using ESYS on F48? Thanks.
      10-28-2020, 08:16 AM   #702
slazak87
Poland
Drives: Bmw 435xi BMW F48
Hello
I need to code a new Bmw F48 LED head lamp, the connection does not work at all.
can anyone help?
      01-01-2021, 08:44 AM   #703
manyak
Romania
Drives: BMW X1(F48)
Hello,
I don't find that option named SbrTWarnDurTr1 on my list. Can you confirm that, this is the one(see attached pictures)?
Thank you!
      01-01-2021, 01:54 PM   #704
Patvictoria
Drives: BMW 2016 X1 Xdrive28i M Sport
coding my 16 X1 M sport
Originally Posted by Xorbitman View Post
Did most of these. My fob closes the tail. FOB Lock: Closes everything including mirrors except tailgate. Convenience handle lock closes everything except tail...maybe I didn't hold it long enough though....
I got through all the threads about how to codding X1 F48. but still doesn't know what kind of equipment and software that I need to do all this codding.
Can any one tell me how to do it will be very appreciate.
