M2 Technical Topics > Suspension | Brakes | Chassis > Camber plates
      05-26-2018, 02:05 PM   #45
Twt
Twt's Avatar
634
Drives: 2017 M2
Originally Posted by gsrbri View Post
If you change the plate settings between street and track, no telling what your alignment (toe) is when switching to the mode you didn't align to. Plus, variations in toe will degrade tires quickly and also result in rear alignment variations. I'm driving Street and about 10 events/season and I am going to run -2.0 camber, up front, locked-in.
I drive mine on the street, but not my DD, and about 12 events per year. I leave my GC plates at -3.2 with no problems.
      06-25-2018, 12:57 PM   #46
Benef1cient
Benef1cient's Avatar
Poland
287
Drives: '18 LBB M2 LCI 6MT
Guys, will Millway Camber Plates fit together with M Performance suspension or any other out of the box?
I see them available on a DE site and could order them for my track duty.
      06-25-2018, 06:31 PM   #47
babym2
61
Drives: 18 M2 6MT
are new camber plates required when lowering?
can the car be aligned to within spec without camber plates when lowering?
      06-26-2018, 03:10 PM   #48
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
No
Yes
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      06-26-2018, 03:11 PM   #49
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Yes - you need to tell millway you are using OEM size springs when ordering
      08-07-2018, 01:03 PM   #50
Straight6Driver
38
Drives: F30 335i
Hi guys,
I'm ordering GC camber plates, what spring inner diameter do I select if I'm using h&r lowering springs? The springs are on order but I'm not sure of the diameter.
      08-07-2018, 06:00 PM   #51
HP Autosport
BimmerPost Supporting Vendor
3847
Drives: F80 M3
Originally Posted by Straight6Driver View Post
Hi guys,
OE or sport spring since H&R lowering spring is not a constant ID spring.
      08-08-2018, 02:02 AM   #52
Straight6Driver
38
Drives: F30 335i
Thanks! And 3 or 5 bolt strut tower GC is asking? I'm assuming 3 is the stock setup?
      08-08-2018, 03:05 AM   #53
pruettfan
1622
Drives: 2017 M2, LBB, DCT, Exec
M2 is 5 bolt strut tower.
      08-08-2018, 03:23 AM   #54
Straight6Driver
38
Drives: F30 335i
Thank you.
      04-13-2019, 05:05 AM   #55
Alessandr0
Switzerland
52
Drives: BMW M2
Originally Posted by MagnusT View Post
So we did the wheel aligment today. No problem setting front camber to 3 degrees which is what I wanted. There's a lot of room dialing in more. I didn't try out max but I'd guess in the neighborhood of 4 degrees.
In the rear (all stock) max what was possible seemed to be just over 2 degrees. We got max 2.0 on one side and 2,2 on the other.
For me 3 degrees in the front and 2 degrees at the rear is just fine.
digging this back up, but from your picture the damper nut seems to be barely screwed on your suspension? do you have better pics, im having the same issues with my v3's and mill way CPs
thanks
      04-13-2019, 03:14 PM   #56
MagnusT
MagnusT's Avatar
Sweden
538
Drives: BMW M2
Sorry, can't remember if the pics were taken during mounting or after, if the nuts were full on or not. I can take a peak an take a new pic.
      04-15-2019, 01:18 AM   #57
Alessandr0
Switzerland
52
Drives: BMW M2
If you can, that would help me a lot. Also, did the camber plates come with a specific lug nut ? mine didn’t and the one supplied with the Kw’s seems too chunky. Might have to use the OEM again.
Thanks again
      04-15-2019, 12:12 PM   #58
MagnusT
MagnusT's Avatar
Sweden
538
Drives: BMW M2
I remember we had some issue with the top nut seizing on one side, hell of a job to get it off and redo. I'm sorry it's a bit blurry, was a couple of years ago now. So I can't remember 100% exactly what we did then, but I think all parts were the correct ones, the other side was no problem.
      04-16-2019, 04:22 AM   #59
Alessandr0
Switzerland
52
Drives: BMW M2
spoke to millway, used oem lug nut with loctite 2 to secure the job
thanks
      04-16-2019, 11:33 AM   #60
MagnusT
MagnusT's Avatar
Sweden
538
Drives: BMW M2
So I'm a bit late
From today:
      04-16-2019, 05:30 PM   #61
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
So I'm a bit late
From today:
Hi Magnus
Are your M2 M'way CP's still noisy/clunky ?
Cheers BP
      04-17-2019, 04:07 PM   #62
MagnusT
MagnusT's Avatar
Sweden
538
Drives: BMW M2
They were never clunky. But road surface noise from the tires is louder due to the more stiff connection of the uprights/dampers to the car body. Here in Sweden we have very rough very very "noisy" asphalt due to an extreme high amount of small stones in it.
Appreciate 2
Bee Pee1779.00
kern4174449.50
      04-22-2019, 10:40 AM   #63
Proctor750
426
Drives: E30 M3
I went with the GC as I have had experience with them in the past.
The plates seemed odd at first because it appeared the stack height was different but it's not. Also where the center makes contact with the machined stepdown on the strut is further down than the stock hat. I thought this would cause a discrepancy BUT they have a special nut which has a sleeve that goes partway into that gap AND they provide different length bump stop so it appears to equal everything out.
Also the weight of the car is on the large diameter needle bearing and the center axial bearing doesn't take any of that weight which is an excellent design.
You can swap the inboard fillister head bolts to the other side of the plate to allow much more neg camber. Maxed out in "street" mode (bolts inboard) gave about 2.75 deg where as the Minimum in "race" mode netted around 2.9/3.0 deg so I kept it in race mode minimum. No swapping required can just loosen and slide in if needed.
Toe measured 0 deg before install, now it's right at about 1/32" toe out with the 3 deg setup.
Also - no increase in NVH or noise at all. Overall - do recommend.
Edit: Don't forget to put a rag over the 12v jump junction - pulling the aluminum cross member out is like playing operation if you don't..
Appreciate 4
gnx759.50
whoop_ass355.00
Kankles1484.50
JTO245276.00
      05-26-2020, 04:52 PM   #64
Proctor750
426
Drives: E30 M3
I take it back, there is a slight creakiness coming from the springs now when turning at a standstill. I don't really care though...
      05-26-2020, 06:02 PM   #65
mr_lab_rat
mr_lab_rat's Avatar
566
Drives: 2017 M2, 2018 X1
I just got Vorshlag plates and I'm really impressed. Built like a tank, same height as OEM, no noticeable increase in noise (I kept the rubber boots).
Bosozoku693.50
      05-30-2020, 03:00 PM   #66
Big Fabri
Big Fabri's Avatar
Italy
95
Drives: Lamborghini Huracan
i have millway street on my m2 competition very happy with it so far. no noises at all
m2
