BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Carplay: Get ID6 or bimmertech MMI?
      08-10-2022, 12:58 AM   #1
cpu_
Drives: X2
I own a 2019 X2(second owner). Unfortunately, it didn't come with Carplay nor has a WiFi antenna port in ENTRYNAV2 head unit(confirmed by reading ECU data).
As I read online, there are 2 options:
  1. Get an ID6 head unit (with Carplay activated, VIN recoding etc.).
  2. Get a MMI bimmertech module.
I have discussed this with 2 guys. One says that ID6 should be straightforward to install (almost plug and play) and that bimmertech's MMI is just another cheap Chinese device. And the other states that bimmertech is the optimal solution for my case, and it will not be easy to change the head unit (new cables, some incompatibilities may appear with other car units).
Which one would you recommend?
Thank you!
      12-16-2023, 09:38 AM   #2
Ryan Emad
Drives: BMW X2 18i
I’m in the same boat, update me with what you have decided please.
      12-17-2023, 07:54 AM   #3
jmc777
21
Drives: 2020 X2 M35i
I added an MMI to my wife's 2015 X3. Not particularly difficult to install and it works very well. I purchased it from Andream which is significantly cheaper than bimmertech.
