08-05-2022, 12:09 PM | #1 |
48
Rep 140
Replacement X2 keyhole cover thingie?
Hey all, not sure how it happened but the tabs holding the little plastic cover that goes over the hidden keyhole on my drivers door broke off. So I need to get a replacement, but I'm not sure what it's actually called so I'm having trouble finding a place online that sells them.
Anyone know the part number or what it's called, or better yet a place that sells them? Thanks, this one stumped me!
2020 M35i
08-05-2022, 06:10 PM | #2 |
2025
Rep 2,808
Drives: F33 430 and F39 M35i
08-05-2022, 11:00 PM | #4 |
Retired from BMWNA
198
Rep 184
Here’s what you might want to try… A small dab of GE silicone II on the inside of the cover -pencil eraser size- that would hold it on. It’s under no stress. But with a good tug, it would come off again Without any damage.
Glen
Ft Lauderdale '23 228i GC Last edited by Glen e; 08-05-2022 at 11:22 PM.. |
08-08-2022, 11:43 AM | #6 |
298
Rep 1,079
You could try a metal welder? Or get some injenuity, heat up a paper clip and jam that sucker onto the tab.
I just re-read this and I meant plastic welder.. which just heats up a metal piece that you melt into the plastic to hold it together... hence the hot paperclip Last edited by rice_rocket88; 08-08-2022 at 01:15 PM.. |
08-08-2022, 01:02 PM | #7 |
48
Rep 140
So far it looks like the silicon is holding better than I expected. But I'll keep the paper clip trick in mind if it doesn't work out.
2020 M35i
08-08-2022, 04:18 PM | #8 | |
129
Rep 421
I like the dab o'silicone idea though! |
09-19-2022, 09:23 AM | #9 |
140
Rep 256
Matches per realoem:
05 Covering primend left 51217396541 05 Covering primend right 51217396544 https://www.realoem.com/bmw/enUS/sho...diagId=51_1134
Current:
2019 911 targa 4 | GT Silver Metallic 2019 X3 M40i | Glacier Silver Past: 2013 911 C4S | 2019 X2 M35i | 2015 M5 Comp | 2013 M5 | 2013 640i | 2010 535xi | 2007 525xi |
