07-04-2022, 09:24 PM | #1 |
Wheelmaster
Rep 445
X2 rear foglight..almost
Today i hacked in on my light switch to see if i can activate my rear fogs just like what i did on my old E90 rear fogs. Unfortunately, BMW decided not to pre-wire the rear fog bulb on the rear hatch (cost-cutting on USDM versions again!)...bummer. There is one wire missing on the lens assembly electrical plug on the hatch door.
Remove the tabs: I just did a jumper wire to activate the rear fog bulbs to light up as my park light/running light since BMW deleted the 4th wire on the plug. Last edited by jon328i; 07-04-2022 at 11:52 PM.. |
07-11-2022, 11:14 AM | #2 |
Rep 1,079
Emmm... did you look at the other threads on rear foglight? I just coded mine on a month or two ago.. The switch is there and just needed a shave. I have a 2019 model fyi. Well.. you got it to work either way.
07-11-2022, 07:46 PM | #3 |
Wheelmaster
Rep 445
Yes i did shaved/trimmed the tabs on the blank button shown on my pic above, rear fogs did not light up, found out the rear fog light module was not pre-wired (missing 4th wire on the plug) by BMW therefore it won't light up whether you code it or not.
11-18-2022, 05:46 PM | #4 |
Rep 24
jon328i when you coded did you have any issues with warranty? Or is this type of coding irrelevant to warranty? Mine warranty through 2026 so I do not want to mess with anything up until then.
11-19-2022, 12:24 AM | #5 |
2025
Rep 2,808
Drives: F33 430 and F39 M35i
I coded my ‘19. Shouldn’t affect warranty.
Last time I was in for the telematics recall they told me they would have to update the software and all my coding would be gone and I would have to recode. Didn’t take long. |
