Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > IS THERE SOMEONE RUNNING 18x9.5 ET35 ON e91???
      03-12-2024, 07:43 AM   #1
pufcis
Drives: e91
Hi
I have read tons of forums and i cant find anything about 9.5j et35. Is there someone who could give me some advice if there will be problems fitting those rims on a stock suspension e91 pre lci…especially the front. Im planning on running 235/40/18 tyres…maybe some wider tyres on the rear. Will there be any rubbing without spacers?
      03-12-2024, 10:39 AM   #2
whyzee125
1704
Drives: Dinan stage 2 335i
Originally Posted by pufcis View Post
Hi
Rear will fit no problem, the front is doable but will be very tight. If you're running coilovers you'll likely need a few mm spacer to clear the strut and that will increase the need for negative camber to avoid the fender.
      03-12-2024, 10:56 AM   #3
pufcis
Drives: e91
Thumbs up
Thanks, I dont have coilovers...stock suspension.
      04-03-2024, 03:59 PM   #4
RoarinForeign
36
Drives: 2011 e92 335i xdrive
I’m not positive but you might hit the spring perch.
I’m currently in the process of fitting 17x9.5j on my e92 lci x drive. 9.5 is kind of a pain in the ass in the front and 9in would be better, 8.5 no stress. I’m not very familiar I with the differences between rwd and awd front struts but they are different. Based on my experience, the 9.5 needed 8mm of spacer and maxed out camber on my coilovers with linear springs on the lowest settings.
When I had h&r coils with progressive springs (similar to stock diameter) the 9.5 wouldn’t fit. With the HRs I wasn’t much lower than a sport rwd suspension, but maybe stock height gives more space? The other difference between our cars, is I believe my front fenders are plastic and yours are metal so you have the ability to roll them I would think.
Check out apex wheel figment guides. They’re probably more helpful than anything I’ve said. However, I will make a post with my wheel set up after I get my alignment done. Hopefully next week.
pufcis0.00
      04-03-2024, 04:21 PM   #5
pufcis
Drives: e91
Yeah ur right, I ended up getting 18x8.5j all round with 225/40 tyres and they fit great, but its pretty tight in the front. If i had 9.5j im pretty sure the fronts would rub or not fit at all.
