2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum BMW 2 Series M Performance Parts Revealed
      12-02-2013, 11:50 PM   #89
Aust350z
Aust350z's Avatar
Australia
243
Drives: F87 M2
^^ Agreed. Shame such an expensive option when Benz have them standard and only a AUD$2k option in Golf R...
      01-17-2014, 05:47 PM   #90
triplezoom
triplezoom's Avatar
Drives: 2015 AW M235i
Music to the ears!
http://distilleryvesper10-10.ak.inst...af9d7e_101.mp4
      01-17-2014, 08:20 PM   #91
Aust350z
Aust350z's Avatar
Australia
243
Drives: F87 M2
Originally Posted by triplezoom View Post
WANT!!!!!!!!!!!!!!!!!!!
      01-17-2014, 08:25 PM   #92
thomps
Drives: 2015 M235i
Must. Have.
Also must see that diffuser on different colors. I should probably avoid these sights, though, as cost will probably be a prohibitive factor once I'm done shelling out for the LSD.
      01-17-2014, 08:31 PM   #93
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
kind of weird that DSC needs to be off for the LSD to be active....
You would be turning of DSC all the time :-s
      01-17-2014, 08:51 PM   #94
Greenkirby21
Vrooom :)
Greenkirby21's Avatar
314
Drives: C7 Stringray
Where does it say that?
I thought LSD was always active. DSC just engages at a different point. LSD is part of the car mechanically, I don't think it can be turned off or not? At least that is my understanding.
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
      01-17-2014, 08:53 PM   #95
pikcachu
pikcachu's Avatar
1403
in the press release
"A highlight in the suspension area is the BMW M Performance limited-slip differential available for the BMW M235i Coupé. When the dynamic stability control function DSC is deactivated, the torque-sensitive mechanical limited-slip differential in the rear axle ensures traction-optimised distribution of drive torque between the rear wheels. It reduces the slip that occurs on the wheel with less grip by transferring more drive power to the other wheels using a blocking effect. This converts engine power into forward momentum as effectively as possible so as to be able to accelerate out of a bend even more dynamically, for instance."
      01-17-2014, 08:59 PM   #96
Greenkirby21
Vrooom :)
314
Ah okay. I saw this and I assumed it would be very similar
Without LSD: 1 wheels slips then DSC gets activated.
With LSD: 1 Wheel starts to slip, other wheel grips, both wheels slip then DSC gets activated.
I added an LSD in my GLI and every body was curious about traction control.
Now traction control gets activated after both wheels brake loose.
LSD increases traction, improves handling, increases stability and causes DSC to cut-in later when also fitted. Guess the delayed cut-in of DSC is because the LSD is preventing the traction slip in the first place.
Thus it appears both LSD and DSC do work together ok.
But yes, to fully have the benefits of the LSD, everything must be turned off
      01-17-2014, 09:10 PM   #97
Aust350z
Aust350z's Avatar
Australia
243
Drives: F87 M2
Wait so does DSC need to be deactivated to allow the LSD to do its thing? Or will the LSD delay the engagement of DSC until BOTH wheels begin to slip??
      01-17-2014, 09:11 PM   #98
pikcachu
pikcachu's Avatar
1403
when the LSD is on, the DSC is off no matter how many wheels slip... that's what i understand from the press realease
So if you manage to get both wheels slipping with the LSD on, start praying :-)
      01-17-2014, 09:12 PM   #99
pikcachu
pikcachu's Avatar
1403
Seems like it from this
DSC is on when you start the engine. (LSD off)
DTC activated if you press the DTC button. (LSD off)
DTC & DSC off when pressing and holding DTC button for 5 seconds (LSD on)
      01-17-2014, 11:10 PM   #100
vinny84
vinny84's Avatar
292
Drives: 2005 BMW X5
A highlight in the suspension area is the BMW M Performance limited-slip differential available for the BMW M235i Coup. When the dynamic stability control function DSC is deactivated, the torque-sensitive mechanical limited-slip differential in the rear axle ensures traction-optimised distribution of drive torque between the rear wheels. It reduces the slip that occurs on the wheel with less grip by transferring more drive power to the other wheels using a blocking effect. This converts engine power into forward momentum as effectively as possible so as to be able to accelerate out of a bend even more dynamically, for instance.
So it will be activated when in Sport+?
Or we have to have it in Sport+ and hold down the traction button for 5 seconds?
Also, M Performance exhaust is a must. Sounds amazing
      01-17-2014, 11:18 PM   #101
w3rkn
10
Drives: BMW 135is
You cannot turn a LSD on, or off... It is a mechanical device. Always working.
      01-17-2014, 11:33 PM   #102
Greenkirby21
Vrooom :)
314
+1
I think what the press release is saying, is that once you turn off all the nannies, the LSD is fully active and at your disclosure.
That is,
A) No LSD
One wheel slips, DTC/DSC turns on to cut power
B) LSD
Both wheels slip, DTC/DSC turns on to cut power
Basically, DTC/DSC should be activating less with an LSD, but it will still cut in if the wheels are losing grip out of spec.
      01-25-2014, 09:02 PM   #103
Spitfi-r
Drives: m235i
1+
My guess is that DSC kicks in long before the LSD would have any impact.
Turn off DSC, then get a little loose and you'll see/feel the LSD working.
      02-24-2014, 08:45 AM   #104
Ghetto2315
831
Drives: 16' BMW i8
Anybody know when this will be available and pricing for the US?
      02-24-2014, 08:55 AM   #105
M.barnes
41
Drives: 123d
still no pricing on LSD or performance body parts. Pricing has come out for interior trim, exhaust and steering wheel (digital display and non digital display).
No delivery times or prices on LSD and carbon spoiler though
      02-24-2014, 05:59 PM   #106
GolfProGiff
GolfProGiff's Avatar
Drives: 2012 e92 335is
I spoke with a very tight lipped BMW employee in charge of educating the sales people. After some badgering about getting my parts done at port vs dealership he said with my order it would all be dealer. The best he'd tell me is "Summer". I saw performance parts come out for I believe the X5 4 months after release. This would match this same time frame. Nobody at BMW seems to want to talk about it so we wait... My dealer said he can order it when it appears on the website so I guess they find out when we do.
      02-24-2014, 06:17 PM   #107
M.barnes
41
Drives: 123d
My dealers ordered the performance exhaust. Will be here for 8th march
      02-24-2014, 08:12 PM   #108
GFK007
376
Drives: 2014 m235i
Has to be because you are based out of the EU.
Here in the US you can only get the shifter, mirror covers and steering wheel.
MG on CR M235i, mods to come...
(gone but not forgotten) 2011 e90 M Sport - M-Tech Carbon Diffuser, OEM Carbon Trunk Spoiler, 20% tint, black reflectors, black OEM grille, LUX white Angel Eyes.
      02-25-2014, 04:51 AM   #109
M.barnes
41
Drives: 123d
well he ordered it based on the parts number someone posted from the ETK or whatever website on here lol
2addicts
