09-23-2021, 03:08 PM | #1 |
Rep 6
Replacement for 2016 X1 - Suggestions?
I'm planning to replace my 2016 X1 with a new SUV shortly. This was my third BMW X1, but I've been the most disappointed with this version.
My two biggest gripes have been: 1. Lack of cupholders. I know it sounds trivial, but I use this car for "road trips" around the midwest and south, and this has been a continual problem. 2. Noise. I have found the 2016 very noisy on the highway. It's likely somehow part of the "run-flat" tires (which I mostly hate) but it overall just has seemed very noisy. I seriously doubt that a redesigned 2022 X1 will be any less noisy. Any ideas? |
09-23-2021, 05:26 PM | #2 |
329
Rep 1,024
If they are the only reasons your changing then you could solve both problems very cheaply. On the other hand if your changing due car age and you want a new vehicle then ignore below.
The front wheel arch liners can be sound proofed by professionals for under $500 and according to others that have done this it makes as huge difference, the wheel arch liners not having proper sound proofing behind them is where that highway noise comes from. https://m.facebook.com/mahihisoundpr...30415730311227 https://www.nkgroup.co.uk/fitting-guides/bmw-2/bmw-x1/ https://www.carousell.sg/p/bmw-x1-4-...ng-1030774282/ As for cup holders what exactly is the problem your experiencing? You have two in centre console, two in rear armrest and the doors can hold bottles. Do you need more than that or are they not large enough? You could try an extra vent mounted one. |
09-23-2021, 08:28 PM | #3 | |
248
Rep 613
OMG! You just added another item to my DIY list, hahaha!
I didn't know it was possible to isolate the front wheel's arch, but I will definitely do it sometime. It also looks easier than the rear wheels and the trunk. I installed my rear camera, and it was a pain to disassemble and reassemble everything. Quote:
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
09-24-2021, 07:57 AM | #4 |
329
Rep 1,024
I'm tempted to do it on my wife's X1 but keep putting it off as I rarely drive it and see she is immune to the road noise.
The kits you can buy seem good value for self install and are more than just the wheel arches but it's definitely the main source of noise. The motorway road noise is my only issue in her 2016 X1 m sport we have had since new if I'm honest. (And a single annoying rattle in the B pillar I'm tracking this weekend to keep me busy) I tried non RFTs and not much of a difference in road noise. |
09-24-2021, 09:36 AM | #5 | |
248
Rep 613
I also have a rattling on the B pillar, passenger side. Mine started after installing the rear camera, so I believe I didn't adjust everything as well as I thought, no matter how perfectionist I am. Now I'm tempted to buy new clips and replace them all.
For the noise isolation, I'm going to buy the 'raw' material, you know, some pieces of Dynamat or similar and do a custom job. Quote:
09-25-2021, 09:33 PM | #7 |
65
Rep 244
GF just leased a 2021 Mazda CX-5 Grand touring reserve. The road noise is so much better compared to the X1, much more comfortable ride and no run-flats. If I was sticking to a small SUV, this would be my next one.
2016 F48 X1 -> 2020 G20 M340i
09-25-2021, 11:57 PM | #8 |
329
Rep 1,024
So solved the rattle that seemed to be from the B pillar by my ear by thoroughly cleaning all seal using baby water wipes, drying with a micro fibre cloth and applying copious amounts of gummi pflenge to any seal I could see on the doors and door areas.
On the lower door trim outer moulding on our M sport I noticed they were loose at the rear of the door so took out the retaining screw and put double sided clear tape just at the rear edge and replaced screw. Also moved the door lock strikes in a mm or two on all 4 doors both sides and the noise is gone. Only noise left in the car is a very low buzzing that's been there since new in the passenger door just below the arm rest which I can recreate by banging the door with my fist and occurs on rough road surfaces, will remove the door card and try figure that one out maybe tomorrow if I have time but it's so low in volume that it can't be heard unless the radio is switched off completely and never increases in tone with speed to surface so isn't that annoying in general. QUOTE=CnSky;28071738]Will let you know if I find the source it's a rattle right at my ear and a buzz also sometimes. Bought a stethoscope to identify where it is.[/QUOTE] |
09-26-2021, 08:46 AM | #9 | |
2628
Rep 4,259
I'm not knocking BMW, been driving them for many years but they and their dealerships have gone downhill in terms of customer care from my experience which is causing me to look elsewhere. Not having even looked at other brands in a loooong time, I was impressed with the CX-5 for a small around town runabout that could also carry stuff when going to Lowes/Home Depot. |
