BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Brake fluid
      09-06-2021, 01:02 PM   #1
BobbyGrant
27
Drives: 2016 X1 F48 xdrive xline 2.0 d
Brake fluid
My local BMW dealer, Parks BMW in Hamilton, are looking to charge £99 for 5th year brake fluid change on my X1.
Anyone in UK had this done at a dealer and what was the rough cost?
I am assuming an indie will be much cheaper, is there a specific brake fluid BMW insist on (I have just taken out an extended warranty so want to make sure I'm complying with that).
      09-06-2021, 01:38 PM   #2
CnSky
Ireland
330
Drives: BMW 530E 2017
Can't comment on UK but I think I paid 115 Euro in Ireland so about the same.
No idea regards fluid type etc as I don't mess with the corrosive crap even though I'm a mechanic and could, I prefer someone else risk their sight, their tarmac driveway and ensure its fully bled hence was happy to have BMW do it.
Be careful if your doing it yourself that stuff is nasty.
      09-06-2021, 02:14 PM   #3
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Agreed...
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      09-06-2021, 02:39 PM   #4
Semi Retired
13
Drives: X1 2.0d Xline xdrive White
Hi I had the 5 year brake fluid change done on my 20d about a month ago. I said I would never have this done again but I relented, as the car had to go into the dealer for urgent software update due to idrive continually crashing, different story. Anyway booked car in for diagnostics and brake fluid change at a pre agreed cost of £89 fair does as others have said nasty stuff leave it to the experts!!! Anyway came to pay the bill and service wanted to charge me £103 queried this and apparently they have two tier pricing ie booked online via BMW app lower price less admin. So although £99 is not necessarily a ripoff there should be room for negotiation. Otherwise known as price matching 🤔Dealer is Rybrock Worcester. Hope this helps
      09-06-2021, 06:35 PM   #5
jrveron
jrveron's Avatar
Argentina
262
Drives: 2023 X3 m40i
Hi BobbyGrant,
Regarding the brake fluid, it must be a DOT 4 Low Viscosity.
I changed the brake fluid a few months ago, and I used the BMW Dot4 LV fluid (83132405977) for £12 per liter. Some others well-known options are ATE SL.6 DOT4 (low viscosity) and Pentosin DOT4 LV. But any Dot4 LV will do.
Talking about the procedure, you definitely need a pressure bleeder to do it right. I also changed to SS brake lines, so I did a DSC/ABS bleed using ISTA too.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD
      09-06-2021, 11:37 PM   #6
chowser51
chowser51's Avatar
2025
Drives: F33 430 and F39 M35i
I have a MOTIV kit that I used on my F33 with no issues. No leaks or drips. Flushed it all. Took longer to get each corner and tire up and off. I wish I had a lift.
      09-16-2021, 10:10 PM   #7
///Makis
///Makis's Avatar
54
Drives: BMW 128i
5 year brake fluid change?
As in it wasn't changed for 5 years?
100 quid doesn't seem bad, not sure how it is in the Uk but in the us it's sometimes hard to find a store or dealer to dispose of used brake fluid.
So it's worth considering if you don't have a pressure bleeder and computer with Ista to bleed the abs.
      12-11-2023, 06:45 AM   #8
Predki
Drives: BMW F48
Im due for a brake fluid change and I’m seeing that some flush ABS/DSC. I understand that doing this ups the complexity of the job quite a bit seeing as you need something like ISTA software.
My question is, when is it necessary to flush the ABS DSC? Should this be done with each brake fluid change?
      12-11-2023, 09:59 AM   #9
Skyline2.0
137
Drives: 2018 BMW X1 xDrive
Not sure how you "flush the ABS DCS" separately from doing a routine brake fluid change. BMW's procedure calls for flushing the lines in this order (assuming brake reservoir is on left-hand side): rear right > rear left > front right > front left > actuate emergency parking brake twice > rear right > rear left. I think the last 3 steps will take care of any old fluid in the ABS.
As jrveron mentioned, make sure to use low viscosity DOT 4. I had to do this service twice because the first time I used non-LV DOT 4 (specifically, ATE Typ 200 DOT 4) and it caused a squeaking noise when the pedal was pressed down. No change in braking performance, but the noise was annoying and unsettling. It's almost all gone now, so pretty sure non-LV fluid was the culprit.
      12-11-2023, 11:53 AM   #10
jrveron
jrveron's Avatar
Argentina
262
Hi Predki,
You only need to do the ABS/DSC flush routine from ISTA if, for example, you change the brake lines or if the regular bleeding leaves some strange feeling on the brakes.
So, generally speaking, just do a normal bleeding following Skyline directions. I highly recommend using a pressure bleeder.
Search this Thread:
Advanced Search
