BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) F48 instrument cluster
      09-06-2021, 03:42 AM   #1
pinco000
pinco000's Avatar
165
Drives: F48
Hi guys, my F48 has a few small cracks at the bottom of the front cover of the instrument cluster. Was wondering if anyone knows whether the cluster assembly ( pictured ) can have the front cover removed.
There are a few cheap units on fleabay for sale I could buy for this little repair. Thanks
      09-06-2021, 05:06 PM   #2
kubax86
kubax86's Avatar
No_Country
1786
Drives: M2
Yes, you can easily swap it.
pinco000164.50
      09-07-2021, 02:34 PM   #3
pinco000
pinco000's Avatar
165
Drives: F48
you mean the front plastic cover, not the whole cluster, right?
      09-08-2021, 01:04 PM   #4
kubax86
kubax86's Avatar
No_Country
1786
Drives: M2
Yes
Whole cluster can be swapped as well but needs virginizing.
pinco000164.50
      09-08-2021, 02:47 PM   #5
pinco000
pinco000's Avatar
165
Drives: F48
Yes
ok, thanks for the info mate
      09-17-2021, 08:54 AM   #6
pinco000
pinco000's Avatar
165
Drives: F48
Yes
few questions guys, but before.... note that I need only the front glass of the cluster. Idea is to just swap front glass from the purchased cluster for mine, which has cracks.
Prior to unplugging the cluster I will disconnect the neg. terminal of the battery. There wont be any errors, right?
Last question, I have found some well priced & good shape clusters on fleebay. They do however come from a F20.
To me they look identical, pls see pictures. Will the frint glass fit to my F48?
The print on the plastic has matching numbers.
Thanks
      09-17-2021, 11:10 PM   #7
///Makis
///Makis's Avatar
55
Drives: BMW 128i
Yes
Thanks
Did you check real oem?
If you find the part on real oem it will also say which other cars have the same part number. If it's the same my guess is the glass is probably the same too
How bad is yours cracked?
pinco000164.50
      09-25-2021, 08:15 AM   #8
pinco000
pinco000's Avatar
165
Drives: F48
Yes
Thanks
just got it fixed. F21/2/3/4, f46/8 all have tge same cluster. Managed to get one in excellent condition and removed tge fron cover.
Biggest pain is the static dust removal prior to assembly
Your advice greatly helped to open up more options to find the cluster in right condition. Appreciate it!
Some pics below
      09-25-2021, 08:19 AM   #9
pinco000
pinco000's Avatar
165
Drives: F48
pictures
