BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Blowing smoke on cold start?
      05-25-2020, 01:36 AM   #1
paulosportz
15
Drives: MY16 F48 BMW X1
Hi all,
Can anyone advise if the smoke coming out of my exhaust is an issue? I have a feeling it is, please see video below.
This only happens when i start the car for the start of the day. Subsequent restarts have no smoke.
I also notice more smoke comes out when the car is not driven for longer periods. So more smoke would come out if car not used over 2+ days.
No smoke comes out at any other times. Only at cold starts.
BMW wants 300-400$ to diagnose but wanted to see if anyone has experience this.
The car is 4 years old.
TIA
      05-25-2020, 11:25 PM   #2
djeieidhds
run it
Oman
Drives: dhudeuehhrhdhehee
turbo leaking oil
      05-26-2020, 12:32 AM   #3
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
What is the mileage?
2012 BMW 320d Sport (F31).
      05-26-2020, 01:14 AM   #4
paulosportz
15
approx 50,000 km
      05-26-2020, 02:10 AM   #5
oakey46
158
Petrol or Diesel engine?
I found, when I had various Diesel engine cars, that if I used supermarket fuel it would blow out more smoke from the exhaust both when cold and on accelerating. It was actually rather embarrassing, but immediately noticeable how much difference there was on changing to proprietary brand fuel, which didn’t emit clouds of black smoke.
I haven’t seen any problem with petrol, although I’m currently using Shell V-power petrol to try and judge if that results in improved fuel consumption. As things stand, after a couple of tank fills, I’m not altogether convinced the additional cost at the pump is worth it.
      05-26-2020, 02:14 AM   #6
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Originally Posted by paulosportz View Post
approx 50,000 km
Is it a petrol or diesel vehicle?
Have you had the vehicle since new?
How long has it been exhibiting this problem?
Do you know the complete history of it and the oil changes?
As well as the possibility of a problem with oil leaking from the turbo (stated above) and being burnt, there is also the remote possibility of piston ring wear/breakage or even cylinder bore wear, where oil leaks into the cylinders and gets burnt.
With respect to the previous poster, Supermarket fuel comes from the same refinery as others do and MUST adhere to the same high standards, and should be discounted as being a contributor to the problem.
      05-26-2020, 02:35 AM   #7
paulosportz
15
It is petrol. I am only owner since new. Its always serviced by bmw. I noticed it after my recent major service. Not sure if coincidence.
      05-26-2020, 03:21 AM   #8
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
There is a remote possibility that the engine has been overfilled with oil!
You should go back to the dealership and make them aware of your observation.
      09-12-2021, 04:45 AM   #9
Simon609
Drives: F48 xdrive 20i
Hello!
I have exactly the same symptoms in my 2016 X1 with 2.0i B48 engine.
There is white/blue smoke for 5-10 seconds after cold start. In addition, the engine runs unevenly. After few seconds everything is gone and works perfect until the next day.
Did you solve this problem? or maybe someone knows what is wrong?
      09-16-2021, 10:01 PM   #10
///Makis
///Makis's Avatar
54
Drives: BMW 128i
Did you ever get this sorted or figure out the problem?
That certainly looks like white/blue smoke which could be oil or coolant, and not gas or water steam.
What was the major service you had before this started happening
      09-17-2021, 06:00 AM   #11
Jorix
73
If its cold outside it's normal
      09-17-2021, 06:22 AM   #12
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Reviewing the video again, there is no doubt that it is burnt oil. As previously suggested it could be overfilling. This type of behaviour is also synonymous with oil leaking through the turbo, or past the piston rings.
Because it will not do it until the next day/morning, I would suggest you post the video to your dealer, or leave the car overnight with the dealer, but, make sure it is not started until you are present.
Definitely not cold air/condensation trait.
      09-18-2021, 09:48 AM   #13
Jorix
73
Burnt oil is black. I didn't see any black smoke, but to be honest I am slighlty colorblind, so I may be mistaken.
      09-18-2021, 10:19 AM   #14
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Burnt oil IS normally blue smoke. Unburnt diesel (or severe over fuelling on gasoline engines) is black. White smoke is normally coolant or condensation in very cold weather.
      09-29-2021, 08:31 AM   #15
TommyB
Drives: X1 F48
I have the same engine (B48) same problem. It doesn't happen every morning. It has to stay 2-3 days and then it does. Definitely oil burnt. I had to fill up with 1 litre.
      09-29-2021, 08:34 AM   #16
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
When you say it has to stay 2-3 days, do you mean the engine has not started in that time?
      10-01-2021, 04:39 AM   #17
TommyB
Drives: X1 F48
Exactly.
      10-01-2021, 06:09 AM   #18
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
In this case it seems likely that there is some kind of slow oil leakage into the induction side of the system. Possibly from the Turbo.
      11-12-2021, 08:25 AM   #19
ravid007
Drives: 320i Sport
Hi, did you figured out what is the problem? I have the same issue also with B48 from 2016.
Thanks.
