10-22-2019, 03:24 PM | #1 |
441
Rep 650
Anyone with Aftermarket Wheels?
I'm looking around at how to setup the X2 M35 for optimal handling and the thought of getting lighter wheels crossed my mind. Anyone on here with aftermarket wheels on their car? Would love to see some examples as the TireRack site makes most wheels look good which we all know isn't the case lol.
10-22-2019, 07:51 PM | #2 |
10
Rep 64
Same here. After months of research I've finally decided on a set of winter wheels/tires from tirerack for my X2 M35i to replace the 20" summers it came with. FWIW, through research and calling many many dealers (even a few in Canada), I've learned that the only OEM wheels that will fit and clear the calipers are the 715m style (19") for about $3,000 for the set. Tirerack only recently added the M35i variant to their website after they finally got heir hands on one to test out. They guarantee all the wheels listed there will clear the calipers. I'm going with a set of 18" BBS with the Sottozero 3 tires.
10-23-2019, 08:05 AM | #3 | |
441
Rep 650
11-13-2019, 01:32 PM | #6 |
129
Rep 419
Yes to seeing pics but also can you measure "barely"? For winter use it's important to have a decent clearance between the caliper and the outer flat surface of the rim.
11-13-2019, 04:46 PM | #7 |
298
Rep 1,079
Here are some pictures.. tight as in a few millimeters. I've certainly seen stock tires this close such as my e60 stock 17 inch wheel was pretty darned close. I rotated it and it moved freely without binding anything. Next couple of pictures are the stock wheels and how much more room there is.
One other neat thing to notice, is that the m35i had different brake shields. They were made out of a different aluminum colored (vs regular steel) and they were sharp. I mean sharp in terms of most brake/dust shields are bent with a lip, this was literally a straight piece of metal.. "maybe" to let air straight into the brake discs? Also here are my winter wheels.. they are pretty aggressive in terms of offset. 19X8.5 with an offset of 25. Tires are 255/35r19. It does stick out from the fenders just a shade, I got them used as a set with everything in them and I'll run them for a couple seasons and throw on skinnier winter tires. First stop at the grocery store someone commented on it which is odd because as a "stock" car I've literally had nobody ask me about it. Could be just luck? I'm working on getting a good pair of center caps.. stock ones are mercedes one and I'd rather go with an empty socket than a mercedes star |
King_Leonard159.00 |
11-17-2019, 06:59 AM | #10 |
10
Rep 64
Those look great. The black wheels are a nice compliment to the blue.
united251200280.00 |
11-18-2019, 06:38 AM | #11 |
56
Rep 151
11-18-2019, 09:55 AM | #12 |
159
Rep 174
11-18-2019, 10:01 AM | #14 |
79
Rep 230
Ride quality difference was huge improvement over RTF and much less tire noise.
11-20-2019, 09:51 PM | #17 |
298
Rep 1,079
I put my torque wrench at 120 ft/lb myself. Usually I just do it by my own judgement since I've been doing it for a while. In the past I've tried exactly 100 and the nuts still came loose. Could be my calibration is off on the torque wrench though..
11-30-2019, 09:27 AM | #18 |
1418
Rep 2,560
Drives: Rapidly from A to B
What wheels are these? Are the center caps factory or did you have to order them special from a 3rd party?
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
11-30-2019, 12:10 PM | #19 |
56
Rep 151
11-30-2019, 12:16 PM | #20 |
298
Rep 1,079
That's kind of a not so true statement.. I can tell you that my AG wheels did not fit my E60 center caps. I just ordered a set of blanks for mine and CF wrapped it. I'm thinking of ordering some BMW vinyl stickers for them.
Pyrat 21417.50 |
11-30-2019, 11:13 PM | #21 |
1418
Rep 2,560
You are understating the situation. I've been searching for wheels that accept the stock centercaps and haven't found any other than oem. The older 120 spacing BMW wheels did have many 3rd party wheels that accepted factory centercaps. The 112 spacing, not the case.
11-30-2019, 11:14 PM | #22 | |
1418
Rep 2,560
