F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
ARMA SPEED
      08-31-2019, 05:49 PM   #1
kern417
Cheapskate
4464
Drives: 2018 440i |2016 340i | 2010 X5
Introductory guide to logging your BMW:
Recommended Logging Method:
1. Shift to the appropriate gear (8AT Users: Use 4th, 5th, or 6th Gear; 6MT Users: Use 3rd or 4th Gear)
2. Start at 2000-2500rpm
3. Floor it (8AT Users: Don't press the kickdown under the pedal)
4. Stop at 6500-7000rpm
Recommended Logging Parameters:
Accelerator Pedal Position
Throttle Angle
Engine Speed
Boost Pressure (Target)
Boost Pressure (Actual)
WGDC
Intake Air Temperature
AFR/Lambda (Target)
AFR/Lambda (Actual)
Ignition Timing (Target)
Ignition Timing #1 (Actual)
Ignition Timing #2 (Actual)
Ignition Timing #3 (Actual)
Ignition Timing #4 (Actual)
Ignition Timing #5 (Actual)
Ignition Timing #6 (Actual)
Ignition Timing #1 (Correction)
Ignition Timing #2 (Correction)
Ignition Timing #3 (Correction)
Ignition Timing #4 (Correction)
Ignition Timing #5 (Correction)
Ignition Timing #6 (Correction)
HPFP Pressure (Target)
HPFP Pressure (Actual)
LPFP Pressure (Target)
LPFP Pressure (Actual)
LTFT
STFT
Knock Detected
Additional recommendations for BM3 Users, courtesy of alyabiev
https://f30.bimmerpost.com/forums/sh...postcount=1293
Code:
Accel. Pedal[%]
Actual brake pressure[hPa]
Ambient pressure[hPa]
Ambient temperature[В°C]
Boost (Pre-Throttle)[hPa]
Boost Pressure (Deviation)[hPa]
Boost pressure (Target)[hPa]
Coolant Temp[В°C]
Exhaust gas temperature after catalyst from model[В°C]
Gear
HPFP (Target)[MPa]
HPFP Act.[MPa]
IAT[В°C]
Intake air temperature before throttle measured[В°C]
Knock Detected[0-n]
Lambda[AFR]
Lambda Act.[AFR]
Load Act. (Rel.)[%]
LPFP Act. (Raw)[kPa]
LTFT
MAF HFM[kg/h]
MAP[hPa]
Oil pressure actual value (absolute pressure)[hPa]
Oil temperature after filter[В°C]
Oil temperature in the sump[В°C]
Raw cylinder head temperature[C]
Set temperature coolant
STFT
Temperature Raw value of the intake air temperature sensor 3[C]
Throttle Angle[%]
Transmission temperature[В°C]
Boost (Target Act)
Boost Setpoint
Distribution Factor (Turbine/Wastegate)
Engine Speed[1/min]
Ignition Correction (Total)[пїЅ]
Ignition Mode (Spool)
Ignition Target[пїЅ]
Ignition Timing Corr. Cylinder 1[пїЅ]
Ignition Timing Corr. Cylinder 2[пїЅ]
Ignition Timing Corr. Cylinder 3[пїЅ]
Ignition Timing Corr. Cylinder 4[пїЅ]
Ignition Timing Corr. Cylinder 5[пїЅ]
Ignition Timing Corr. Cylinder 6[пїЅ]
Ignition Timing Cylinder 1[пїЅ]
Ignition Timing Cylinder 2[пїЅ]
Ignition Timing Cylinder 3[пїЅ]
Ignition Timing Cylinder 4[пїЅ]
Ignition Timing Cylinder 5[пїЅ]
Ignition Timing Cylinder 6[пїЅ]
Load (Actual)[%]
Load (Limit)[%]
Load (Target)[%]
Relative Fuel Mass[%]
Target Mass Flow (Exhaust Manifold)[kg/h]
Target mass flow corrected for boost pressure control[kg/h]
Torque (Actual)[Nm]
Torque (Target)[Nm]
Torque for load (Target)[Nm]
Turbine (Actual)[kW]
Turbine Adder[kW]
Turbine Base[kW]
Vehicle Speed[km/h]
WGDC (Actual)[%]
WGDC (Adder)[%]
WGDC (Base)[%]
WGDC (D-Gain)[%]
WGDC (I-Gain)[%]
WGDC (P-Gain) [%]
Things to look for
Boost more than +/- 2PSI from target
More than 3° timing pull
AFRs increasing from target
HPFP Pressure decreasing from target
FAQ
Do I need to upgrade my charge pipe before tuning?
It is not needed for most setups. Stock charge pipes have been tested to over 600whp. Big turbo kits come with their own aluminum charge pipes for peace of mind. Otherwise, you can do it for looks and/or ease of adding a meth injection system.
Do I need to upgrade my intercooler before tuning?
Our cars have an air-to-water intercooler that is integrated in the manifold. This, again, has been tested to over 600whp. Radiator upgrades are available but only really needed for track duty. Daily driving, 1/4 mile, highway pulls, etc. tend to not need it. Your best indicator will be logging IATs while racing to see if the system is getting heat soaked.
When is an upgraded fuel pump needed?
HPFP hits it's limit around 450whp. This can be reached easily with a downpipe and ethanol blend. If your logs show fuel pressure dropping at peak boost, then it's time to upgrade the fuel pump. More details on fuel pump options here:
Official B58 HPFP Options Thread
UPDATE: Tuners have released OTS maps that take advantage of HPFP upgrades. If you want to run a "Stage 2+" map, you need an upgraded HPFP.
When is an upgraded clutch needed?
The 6MT clutch is good for ~450 ft-lbs. This can be reached easily with a downpipe and ethanol blend. If you experience clutch slip, you can upgrade to the OEM clutch from an E90 335is/F10 550i for a cheap and easy to drive upgrade that will hold 500-600 ft lbs. For higher power applications, look into aftermarket options.
Originally Posted by umizoomi View Post
As long as 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
Youtube/Instagram/TikTok: @kern417
Appreciate 17
      08-31-2019, 05:50 PM   #2
kern417
Cheapskate
4464
91/95ron
93/98ron
95/102ron
E30 = 30% Ethanol/70% gas
Tune Baseline Info - Data provided at 6500rpm at WOT
OEM
Stock
Boost: 10.5 PSI
AFR: 14.0
Timing: 17.5° Advance
MPPSK
Boost: 14 PSI
AFR: 12.74
Timing: 8.5° Advance
Bootmod3
Stage 1 91oct/95ron v2.0
Boost: 17.2 PSI
AFR: 12.3
Timing: 10.0° Advance
Stage 1 93oct/98ron v2.0
Boost: 16.5 PSI
AFR: 12.7
Timing: 12° Advance
Stage 1 E30 v2.0
Boost: 16.5 PSI
AFR: 12.7
Timing: 15° Advance
Stage 2 91oct/95ron v2.1
Boost: 19PSI taper to 14PSI
AFR: 12.6
Timing: 11.5° Advance
Stage 2 93oct/98ron v2.0
Boost: 16.5 PSI
AFR: 12.6
Timing: 12.5° Advance
Stage 2 E30 v2.0
Boost: 20.1PSI Taper to 16.6PSI
AFR: 12.72
Timing: 16.0° Advance
Stage 2 E30 AGG v2.0
Boost: 16.5 PSI
AFR: 12.84
Timing: 16.5° Advance
Stage 2+ 93oct/98ron v2.1
Boost: 21PSI Taper to 17PSI
AFR: 12.2
Timing: 15.0° Advance
Stage 2+ E30 v2.1
TBD
MHD
Stage 1 91oct/95ron
Boost: 16.5 PSI
AFR: 12.5
Stage 1 93oct/98ron
TBD
Stage 1 95oct/102ron v3.0
TBD
Stage 1 E30
TBD
Stage 2 91oct/95ron v3.0
Boost: 18.1PSI
AFR: 12.5
Timing: 10.5° Advance
Stage 2 93oct/98ron
Boost: 17PSI
AFR: 12.5
Timing: 13.5° Advance
Stage 2 95oct/102ron v3.0
Boost: 18.8PSI
AFR: 12.5
Stage 2 E30 v3.0
Boost: 17.8PSI
AFR: 12.8
Stage 2+ 93oct/98ron v3.1
TBD
Stage 2+ E30 v3.1
Boost: 19.0PSI
AFR: 12.8
Timing: 18.0° Advance
Appreciate 14
      08-31-2019, 09:28 PM   #3
2013mingrey335i
21
Drives: 2016 340i
This is an awesome idea ! Thanks for starting it
How do you like the tune you have?
kern4174464.00
      09-01-2019, 01:35 AM   #4
kern417
Cheapskate
4464
I am running bootmod3 stage 1 and i like it so far. I switched to the OTS e30 map and realized I was starting from scratch again, so that + my general curiosity kicked off the idea for this thread. I have to run some logs to see what the differences are from the 93 map I was running originally. But it would ve nice to know what to expect without running logs on the street.
      09-01-2019, 08:30 AM   #5
j1980mac
263
Drives: 2018 X3 M40i
@kern417, what do you mean here?
"3. Floor it (8AT Users: Don't press the kickdown under the pedal)"
Are you referring to simply running in manual shift mode?
      09-01-2019, 11:55 PM   #6
fb58
30
Drives: 18' AT 340Xi
yup pretty much.
so go to m4 2500 rpm press gas pedal all the way down just before it clicks so it dosent downshift into second on its own.
unless you have xhp then you can disable kickdown
kern4174464.00
      09-02-2019, 04:11 AM   #7
jackstrath
Scotland
663
Drives: 16' F31 340i & 03' Focus RS
If your in sports+ Kickdown is disabled
kern4174464.00
      09-02-2019, 04:53 AM   #8
kern417
Cheapskate
4464
Originally Posted by fb58 View Post
yup pretty much.
Yep, I'm specifically referring to the "click." If you floor it, you can feel a second click underneath the pedal depending on how far you push down. That's the kickdown switch, and is the difference between accelerating in gear vs. the car down shifting for fastest acceleration. If you hit the kickdown switch, the car may downshift to 3rd/2nd. You want it to stay in the same gear for the whole pull.
      09-02-2019, 08:28 AM   #9
j1980mac
263
The only experience I have with logging (previous instructions by Terry Burger) is using M4 which indeed will not trigger the kickdown.
I hang on every word at face value, so I just wanted to make sure I wasn't missing anything.
      09-02-2019, 10:14 AM   #10
IMS-340C
IMS-340C's Avatar
Egypt
396
Drives: Self Tuned 340i 8AT RWD
Good idea for a thread.
At what RPM are these logs you posted below?
Originally Posted by kern417 View Post
Stage 1 93 v2.0
16.5psi
12.7AFR
12° Timing Advance
      09-02-2019, 10:58 AM   #11
kern417
Cheapskate
4464
Redline. They all progress graduallly from 3k-7k. AFR starts in the 14s and drops as RPMs rise, and ignition timing increases as RPMs rise.
Do you think it would be more helpful to post that kind of info? Without a screenshot of a full map editor, it would be hard to illustrate, so I just posted peak values.
      09-02-2019, 11:58 AM   #12
IMS-340C
IMS-340C's Avatar
Egypt
396
Yes definitely let's stick to a certain RPM close to redline like 6500 ?
kern4174464.00
      09-02-2019, 01:03 PM   #13
IMS-340C
IMS-340C's Avatar
Egypt
396
Here's mine at 6500 RPM
Car: 340i MPPSK, no other mods.
Fuel used: less than 91 Octane
Ambient Temp: 100F
Manifold Temp: 110F
Boost: 14 PSI
AFR: 12.74
Timing: 8.5 degrees
Knock Delta: -0.1
Low Octane effecting timing badly.
Appreciate 2
kern4174464.00
ImBlue30.00
      09-02-2019, 02:12 PM   #14
kern417
Cheapskate
4464
Ambient Temp: 100F
Manifold Temp: 110F
Boost: 14 PSI
AFR: 12.74
Timing: 8.5 degrees
Knock Delta: -0.1
Awesome, I'll add that. Please post logs as well if you have any
      09-02-2019, 02:49 PM   #15
GT500R
800
Drives: BMW X3M
You guys should add what gear you are providing log info for, 3rd vs 4th will show different values at the same rpm.
      09-02-2019, 03:17 PM   #16
kern417
Cheapskate
4464
Why would it? I want to focus on peak values but can add more detail across the rev range if it makes sense. But I don't have any differences between logging in 3rd gear and 4th gear other than the amount of time/data points across the log.
      09-02-2019, 03:19 PM   #17
IMS-340C
IMS-340C's Avatar
Egypt
396
4th gear is recommended with DSC off.
      09-02-2019, 03:25 PM   #18
IMS-340C
IMS-340C's Avatar
Egypt
396
I guess engine load is different in each gear ? MHD recommend 4th gear with DSC off.
      09-02-2019, 03:54 PM   #19
GT500R
800
Drives: BMW X3M
Load is different and therefore so will boost or timing.
      09-02-2019, 04:00 PM   #20
IMS-340C
IMS-340C's Avatar
Egypt
396
I guess with these logs a good tuner can estimate how much power the engine produce.
      09-03-2019, 04:48 AM   #21
enemigo13
249
Drives: F32 LCI 440xi citrineblack
mine at 6500 RPM :
Car: 340xi, software tune by me only.
Fuel used: 98RON.
Ambient Temp: 20 degrees of Celcius
IAT : 32 degrees of Celcius
Boost: 17.7 PSI
AFR: 12.6
Timing: 7.8 degrees
I would recommend to upload data from 6000-6300rpm range as most B58's make max power there.
kern4174464.00
      09-03-2019, 05:13 AM   #22
IMS-340C
IMS-340C's Avatar
Egypt
396
Not doubting your comments but most b58s dynos I saw power peaking around 6500 RPM
https://www.google.com/search?q=b58+...ih=945#imgrc=_
Also your timing advance is quite low I guess with a bit less boost or higher octane you will get better timing and more power.
That's what happened to me when I increased the boost timing retarded which resulted to lower top end power.
I learned that more boost not always equal more power, Ignition timing is the key, If we don't get a good combustion then the extra boost is useless.
Also how do you make your own tune ? I wish I could do that.
Originally Posted by enemigo13 View Post
mine at 6500 RPM :
Fuel used: 98RON.
Boost: 17.7 PSI
AFR: 12.6
Timing: 7.8 degrees
kern4174464.00
f30post
