ZPOST
  TireRack
      05-10-2024, 07:45 AM   #1
spielnicht
Petrolhead
spielnicht's Avatar
445
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Pressure Plate Rattle
I can't remember where I read this, but seems like manual Z4s suffer from a pressure plate rattle noise when the clutch is disengaged. I usually notice it only when I switch the engine off, but yesterday I was idling while waiting at the drive through and couldn't believe how much louder the noise is when it's bouncing off the wall. Needless to say, felt a little embarrassed between all the other cars there and had to keep my clutch engaged to shut it up.
Is there an easy fix, or is this something you just suck up and live with?
2024 X3 M40i
2014 550i
2008 Z4 3.0si 6MT
2011 Z4 35si (sold)
      05-10-2024, 08:50 AM   #2
Steeler
Steeler's Avatar
2430
Drives: Built not Bought 04 Z4 VF. E70
Could also be throwout bearing.
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
      05-10-2024, 10:42 AM   #3
pungo
pungo's Avatar
900
Drives: Z4MC-X3-35i-525i, Corrado G60
My E86 3.0si made a rattling sound I could barely hear, typically only in the quiet garage, in neutral, clutch not depressed, when pressing on the clutch pedal, the rattle would go away. This was with < 5k miles on the car. After much research and talking with a very knowledgeable master BMW tech, the rattling sound is typically caused by the duel mass flywheel and some vehicles are more noticeable than others due to the tolerances in the part.
AFAIK, there's no fix short of replacing the flywheel and even then it may or may not completely eliminate the rattle. Though if yours is so loud it's embarrassing, maybe it's something else or the tolerances of the flywheel assembly are at the extreme end. I've read of people switching to a traditional flywheel.
Without the clutch pedal pressed, the throwout bearing should not be spinning and should be pulled back away the the clutch a few millimeters, kinda just sitting there doing nothing.
A bad throwout bearing typically makes noise only when pressing on the clutch where it actually starts spinning.
zpost
