BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Tire recommendations - non-run flat
      02-26-2021, 05:40 AM   #45
chowser51
chowser51's Avatar
2025
Drives: F33 430 and F39 M35i
You have a pic of it from behind?
I was looking into 235/45/19 for a little more width and height. The 245/40 would be wider but shorter?
      02-26-2021, 05:51 AM   #46
pfdaxe
22
Drives: 2017 BMW X1 xDrive28i M Sport
Originally Posted by Bcborn59 View Post
Those the original DWS06's or the new 2021 plus version? Keep us posted on your experiences.
These are the original DWS06's as they haven't received stock of the plus yet. They are a matching set all with date code 3120 which is nice.
      02-26-2021, 05:55 AM   #47
pfdaxe
22
Maybe hard to tell from the pics (245's on top), but they are definitely wider and you really cannot notice the 3mm shorter height. I too was looking at the 235/45, but I was more interested in width versus height.
chowser512025.00
      02-26-2021, 12:48 PM   #48
Bcborn59
18
I like the look the 245/40's and 45's provide, you will like the performance gain too.
245/45's would give you a little more life due to it's larger circumference.
Both will work on an 8" wheel
      02-26-2021, 01:52 PM   #49
Shagohod
18
Drives: F48 X1
I like the look the 245's provide, you will like the performance gain too.
The shorter 3mm height will effect gas mileage slightly as you will require higher revs to achieve 60 mph. The accuracy of the speedo at 60 mph will be off slightly, You will actually be doing 58.5mph, this will save you on speeding tickets lol.
Let us know if the .7" extra width effects road spray down the side of the vehicle in wet weather. Does the extra width make contact with the front inner fender when turning lock to lock?
My speedometer already reads a couple mph faster than my actual speed. Been trying to figure out if it is my car or both my friends Subaru's that are off. Pretty sure BMW just wants us to give them a better name by driving reasonably haha.
The tires do look great though. Had Michelin A/S 3+'s installed recently and they're a world of difference from the stock RFT Pirelli's, and a veritable steal as far as cost. I'm sure the DWS's are even more comfortable on the road. Dang chain stores though, all that money plus an alignment and they don't even bother to air up the tires before handing me back the key.
      02-26-2021, 05:31 PM   #50
pfdaxe
22
Correction;
245's are taller and wider, 1.6 mph faster than displayed in the odometer.
Mine are 245/40, not 245/45, so the speedo is not off by much
Attached is also a pic I took of a couple of random brand tires showing the difference between the 2 sizes.
      04-11-2021, 11:32 PM   #51
///Makis
///Makis's Avatar
55
Drives: BMW 128i
The speedometer is off, I believe it's done by bmw to something like speedometer speed is 6% higher than actual speed or something like that. I can't recall which forum or where I read it but I know the speedometer reading is higher. In Carly app you can code it the car to read actual speed. You may have to also code wheel / tire size to be more exact. Check on waze your reported speed vs speedometer speed to verify.
      04-20-2021, 06:34 PM   #52
scadagawd
scadagawd's Avatar
47
Drives: BMW M2 2018
Originally Posted by allinon72 View Post
Stock RFT Goodyear's are finally worn out, thank god. Horrible tire. My plan currently is to switch over to Michelin Pilot Sport AS3. Only thing I'm slightly worried about is tire life - not looking to replace them again in 20k. Are there any other tires I should consider?
Had the AS3s for over 2 years now. They're an awesome tire, long life, great handling and quiet.
BMW M2 2018 LBB
BMW X1 2016 PSM
Audi S4 2014 SMG
      04-20-2021, 11:53 PM   #53
chowser51
chowser51's Avatar
2025
How many miles?
I'm still running factory continental runflats and am at 9100 miles. Lots of treadlife left.
I'm looking into either the Michelin CrossClimate2 or the Nokian WR G4 tires since I'm not going to bother with a dedicated snow setup.
guessing I need to take some long vacations that are far away to wear these out.
I had the AS3+ on my F33 and they were phenomenal! Didn't test longevity since I traded it in.
      04-22-2021, 11:15 AM   #54
scadagawd
scadagawd's Avatar
47
Drives: BMW M2 2018
How many miles?
On my AS3 for 2 years, I've only driven 25k km. Still lots of tread life left.
BMW M2 2018 LBB
BMW X1 2016 PSM
Audi S4 2014 SMG
chowser512025.00
      04-27-2021, 06:24 PM   #55
jrveron
jrveron's Avatar
Argentina
266
Drives: 2023 X3 m40i
I thought it wasn't recommended to fit a 245/40 tyre in an 8" wheel: https://www.tyresizecalculator.com/c...rim-size-chart
I also want to ask if you had trouble mounting a non-RFT tyre with the OEM 19" wheels since I believe it's prepared for RFT tyres.
Thanks!
2023 X3 m40i Brooklyn Grey
      04-27-2021, 08:53 PM   #56
pfdaxe
22
Thanks!
245/40 is fine and calls for up to 8" wheel. I wanted 255's, but they require minimum 8.5"
No trouble mounting...the wheel doesn't know the tire is not a RFT.
      04-28-2021, 11:18 AM   #57
jrveron
jrveron's Avatar
Argentina
266
Thanks!
My understanding was that RFT tires have different 'lips' for mounting. That's why I thought rims need to be special.
      04-28-2021, 11:20 AM   #58
pfdaxe
22
Thanks!
Nope. No different, no issues
      04-28-2021, 01:16 PM   #59
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Unfortunately, this is not always correct. There is a user on another forum who for some reason has 2 wheels sets that look exactly the same but have slightly different part numbers. One part number will take normal tyres and Run Flats, but the other will only take Run Flats.
The best option is to check the part numbers with BMW and see what can be fitted.
2012 BMW 320d Sport (F31).
      04-28-2021, 01:23 PM   #60
pfdaxe
22
"Some" wheels maybe. I've never had an issue with any vehicle I have swapped from RFT to non-RFT.
From Tire Rack:
Many drivers are uncertain whether they can put non-run-flat tires on wheels that originally came with run-flat tires. The short answer: yes.
Run-flat tires and regular tires that are the same numeric size will have the same physical dimensions, and can fit properly on the same wheels. The only difference with run-flat wheels is they usually have an extra hump behind the bead seat. This hump would help keep the run-flat tire in its proper place on the wheel while driving without air pressure. It does not affect the performance or compatibility of the non-run-flat tire.
      04-28-2021, 01:54 PM   #61
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
"Some" wheels maybe. I've never had an issue with any vehicle I have swapped from RFT to non-RFT.:
No matter what tyre rack say, or your experience, the person concerned DID have the problem, hence the reason I posted the statement.
It is BMW who made the original statement and is NOT made up.
      04-28-2021, 01:58 PM   #62
pfdaxe
22
Well, we'll just agree to disagree. 😉
      04-28-2021, 02:18 PM   #63
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
      04-29-2021, 12:04 PM   #64
jrveron
jrveron's Avatar
Argentina
266
Thanks!
And you didn't even need wheel spacers, did you? No rubbing whatsoever with your current 245/40 setup.
      04-29-2021, 12:17 PM   #65
pfdaxe
22
Thanks!
No spacers and no rubbing. Ride is much smoother and handles better. I always ditch RFT's if a vehicle has them. All of my expert tire guys are against RFT's.
      04-29-2021, 12:46 PM   #66
Xorbitman
47
Drives: 2018 BMW X1
I have 19" Niche Aftermarket wheels with Toyo non-Run flats....I hate run flats. They're expensive up here in Canada and with our pot holes, crevices. cracks, sunken man hole covers and expansion joints on our shitty roads in Quebec, I've heard a lot of bad stories of exploding tires and replacements costing up to $800 per tire! So I used the original wheels that my 2018 came with and use them for winter with proper winter tires that is the law here in Quebec and I bought Toyo Extensa XP 245/40/19 and very happy with the look, performance and low highway noise. I have no spare and instead I have a flat tire bottle/bong that has a stem/hose that screws to the valve stem of the tire and fills it up and seals the hole...up to a point of course except if it's a catastrophic failure of the side wall which has never happened to me. The puncture repair is good enough to make it to the garage in time for a replacement or repair.
