BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Bimmercode - How to use rear lights as signal lights.
      06-28-2020, 10:50 AM   #23
SDriver18i
SDriver18i's Avatar
No_Country
80
Drives: BMW X1 s18i 2019
Originally Posted by Takabo View Post
Hi SDriver18i,
It's blinking like this.
Not bad! You're a genius as always. Send me the code. I wanna try it out and see how it is!
Takabo49.00
      06-28-2020, 11:02 AM   #24
Takabo
Takabo's Avatar
Japan
49
Drives: G21 320d xDrive Touring MSport
It is unknown whether the codes are the same for X2 (F39) and F48.
Please try (^_−)−☆
BDC_BODY >3065 LceLampMapping4, ED>
MAPPING_BRAKEFORCED_2_L_OUTPUT = 18 (Initial state: off = 00)
MAPPING_BRAKEFORCED_2_L_FUNCTION = 06 (Initial state: bfd = 0D)
MAPPING_BRAKEFORCED_2_L_PRIORITY = priority_2 = 02 (Initial state: priority_1 = 01)
MAPPING_BRAKEFORCED_2_L_FIXED_PWM = fixed = 01 (initial state: pwm = 00)
MAPPING_BRAKEFORCED_2_R_OUTPUT = 19 (Initial state: off = 00)
MAPPING_BRAKEFORCED_2_R_FUNCTION = 07 (initial state: bfd = 0D)
MAPPING_BRAKEFORCED_2_R_PRIORITY = priority_2 = 02 (Initial state: priority_1 = 01)
MAPPING_BRAKEFORCED_2_R_FIXED_PWM = fixed = 01 (initial state: pwm = 00)
BMW 320d xDrive Touring M Sport(G21)
Production Plant: Munich, Production Date: 2021-02-25
wcs2229170.50
      06-28-2020, 12:53 PM   #25
SDriver18i
SDriver18i's Avatar
No_Country
80
Please try
And it works! I also have fog lights as brake lights, which is pretty cool.
Takabo49.00
      08-25-2020, 01:44 AM   #26
ZZZZ
50
Drives: Z4 3.0i winterbeater
Just curious.. On the pre-lci X1 where are the brake force lights?
In my 2017 X1 I noticed in bimmercode the regular brake lights are halogen but brake force is LED. I don't see any LED's in my tail light units except for the running lights though?
Zzzz
      08-27-2020, 02:54 AM   #27
SDriver18i
SDriver18i's Avatar
No_Country
80
Zzzz
What do you mean? You don't see the settings?
      08-27-2020, 03:48 AM   #28
ZZZZ
50
No I mean physically on the car. The outer tail lights house the turn signal at the top and brake bulb at the bottom. The inner tail lights house the reverse bulb and a rear fog light bulb. All these are halogen. There is also the parking light which is the LED light tube.
But where is the factory brake force display LED bulb? I'm talking about the factory function where a second LED bulb engages along with the regular halogen brake light bulb under hard deceleration that BMW has had on their cars for the past 20 years. Not the flashing lights that can be coded.
When I check the factory coding it says my brake force display is LED. But I don't know where it is in the tail light housing.
      08-28-2020, 09:55 PM   #29
SDriver18i
SDriver18i's Avatar
No_Country
80
No idea. Everything is LED in mine.
      08-30-2020, 11:14 AM   #30
kavatski
147
Drives: 2023 X3 30iX
I think you're looking for something that isn't there. I replaced all the halogen bulbs with LEDs, so I've had a good look at the taillights as well. The only LED element in the pre-LCI taillight is the light tube, and then you've got the four halogen bulbs per side that you already know about. The rear fog lights do double duty as the brake force display lights (in North America, they come on solid instead of flashing).
      08-30-2020, 11:44 AM   #31
ZZZZ
50
Yep, you're right. I read up on the documentation. It's strange that my car was factory coded as "LED" for the brake force lights when it's clearly halogen. I did some testing with my wife driving to get the brake force bulbs to light up. In the end, decided to run LED for regular brake lights but halogen for brake force. The slight delay for the brake force halogens to light up fully draws additional attention compared to running full LED. Almost as if the brake lights are lit two times in succession instead of one. I guess the reverse of how it worked on my Z4 where regular brakes are halogen but brake force were factory LED.
      12-31-2020, 06:10 PM   #32
pfdaxe
22
Drives: 2017 BMW X1 xDrive28i M Sport
How did you get the rear fogs to work with brake lights? I tried the codes listed by Takabo and nothing changed
Thanks
BTW: I have a US 2017 XI idrive
      12-31-2020, 07:09 PM   #33
SDriver18i
SDriver18i's Avatar
No_Country
80
Thanks
I just used the same code he provided and it worked!
Btw, I need to update this. My right LED DRL started to dim, I got it fixed since I still have my warranty but I'm assuming its because of this. So, I will no longer recommend coding the DRL's, the fog however is just a quick change led bulb.
      12-31-2020, 07:35 PM   #34
pfdaxe
22
UGH. I even checked the codes after restarting the ECU and all those codes did was activate the brake light as a turn signal...it didn't activate the fogs as brake lights.
      12-31-2020, 08:25 PM   #35
SDriver18i
SDriver18i's Avatar
No_Country
80
Found it!
BDC_BODY
3065 LceLampMapping4:
MAPPING_BREMSL_2_L_OUTPUT = nsl_l
MAPPING_BREMSL_2_R_OUTPUT = nsl_r
      01-01-2021, 12:38 AM   #36
pfdaxe
22
Found it!
BDC_BODY
That worked my friend!
Cheers and Happy New Year
      07-28-2021, 09:43 AM   #37
djadam
Italy
28
Drives: X1 F48
As you guys seem to be pretty well informed on tail lights, I have a question for you: I have replaced rear halogen lights with leds but am missing a wire for the outer DRLs, do you think it would be possible (until I have time to install the missing wire) to use the "normal" rear light wire by swapping the pin in the connector?
They're all already coded to LED anyway...
Thanks for any help
      08-03-2021, 02:22 PM   #38
djadam
Italy
28
Drives: X1 F48
Thanks for any help
Ok quick update on this. I have in fact managed to use the rear standard tail light pin to illuminate the LED part. A couple of caveats: 1. They only turn on when the lights are actually on (either by the switch or when it’s dark on auto) and 2. They only turn on around 50% brightness, they go to 100% when the brake pedal is pressed.
Any ideas on how I can work around this?
I was thinking fog lights as brake lights and rear tail lights always on…
I will try coding above for fog lights as brake lights.
Does anyone know how to code rear tail lights always on?
Thanks
      08-04-2021, 07:36 AM   #39
SDriver18i
SDriver18i's Avatar
No_Country
80
Thanks
Enable rear daylight:
Daylight left tail light
BDC_BODY> 3064 LceLampMapping3, F7>
MAPPING_TAGFAHRL_1_H_L_OUTPUT = sl_l = 14 (initial state: off = 00)
OPTIONS (sl_l = 14, nsl_l = 1C, bfd_l = 1A, off = 00)
Daylight right outtail light
MAPPING_TAGFAHRL_1_H_R_OUTPUT = sl_r = 15 (initial state: off = 00)
OPTIONS (sl_r = 15, nsl_r = 1D, bfd_r = 1B, off = 00)
Daylight left inner tail light
BDC_BODY> 3065 LceLampMapping4, ED>
MAPPING_TAGFAHRL_2_H_L_OUTPUT = sl_2_l = 16 (initial state: off = 00)
OPTIONS (bl_l = 18, sl_2_l = 16, off = 00)
Daylight right inner tail light
MAPPING_TAGFAHRL_2_H_R_OUTPUT = sl_2_r = 17 (Initial state: off = 00)
OPTIONS (bl_r = 19, sl_2_r = 17, off = 00)
I think this is what I used to keep the rear DRL always on.
      08-04-2021, 08:08 AM   #40
djadam
Italy
28
Drives: X1 F48
Ok quick update on this. I have in fact managed to use the rear standard tail light pin to illuminate the LED part. A couple of caveats: 1. They only turn on when the lights are actually on (either by the switch or when it's dark on auto) and 2. They only turn on around 50% brightness, they go to 100% when the brake pedal is pressed.
Thanks
I'm guessing the first 2 are what I'm looking for?
I have already coded DRLs always on, this would code the standard tail light as a drl if I understood correctly?
Thanks
Attached is current state, when the lights are on when it's dark I also have the inner standard bulbs always on, would be good to turn these off too.
Thanks for all your help!
      07-19-2022, 06:49 PM   #41
Renan
Drives: 320i f30
Please try (^_−)−☆
Sorry for reviving the post, but i did this code but my brakes doesn’t light up with the signals, only working the priority mode if the turn signal are on the brakes are off until the turn signal is off, any tips about ? I did too the light bars that worked fine.
      07-20-2022, 12:04 AM   #42
Renan
Drives: 320i f30
Can you help me activate the brakes, only the bars are blinking,
What function was coded
      07-20-2022, 03:11 AM   #43
SDriver18i
SDriver18i's Avatar
No_Country
80
I don't remember which codes do what but try these, this is all I found in my notes:
+Remember, with the bars code there's a high chance of failure of the LED module.
FOG as brakes:
BDC_BODY
OTHER CODES
++ Daylight left tail light
++ Daylight right outtail light
++ Daylight left inner tail light
++ Daylight right inner tail light
Turn signal of rear daylight
MAPPING_UNIVERSAL_5_OUTPUT = UNKNOWN = 14 (Initial state: off = 00)
MAPPING_UNIVERSAL_5_FUNCTION = UNKNOWN = 06 (Initial state: off = 00)
MAPPING_UNIVERSAL_5_PRIORITY = UNKNOWN = 00 (Initial state: priority_3 = 03)
MAPPING_UNIVERSAL_5_PWM_1 = 100% = 64 (Initial state: 0V = 00)
MAPPING_UNIVERSAL_5_FIXED_PWM = fixed = 01 (Initial state: do not touch)
MAPPING_UNIVERSAL_5_ DIMMED = not_active = 00 (Initial state: do not touch)
MAPPING_UNIVERSAL_6_OUTPUT = UNKNOWN = 15 (Initial state: off = 00)
MAPPING_UNIVERSAL_6_FUNCTION = UNKNOWN = 07 (Initial state: off = 00)
MAPPING_UNIVERSAL_6_PRIORITY = UNKNOWN = 00 (Initial state: priority_3 = 03)
MAPPING_UNIVERSAL_6_PWM_1 = 100% = 64 (Initial state: 0V = 00)
MAPPING_UNIVERSAL_6_FIXED_PWM = fixed = 01 (Initial state: do not touch)
MAPPING_UNIVERSAL_6_ DIMMED = not_active = 00 (Initial state: do not touch)
MAPPING_UNIVERSAL_3_OUTPUT = sl_2_l = 16 (initial state: off = 00)
MAPPING_UNIVERSAL_3_PART_OF = off = 00 (Initial state: WLH_FMH_RL = B0)
MAPPING_UNIVERSAL_3_FUNCTION = blinken_l = 06 (Initial state: off = 00)
MAPPING_UNIVERSAL_3_PRIORITY = UNKNOWN = 00 (Initial state: priority_1 = 01)
MAPPING_UNIVERSAL_3_PWM_1 = 100% = 64 (Initial state: 0V = 00)
MAPPING_UNIVERSAL_3_FIXED_PWM = fixed = 01 (Initial state: do not touch)
MAPPING_UNIVERSAL_3_ DIMMED = not_active = 00 (Initial state: do not touch)
MAPPING_UNIVERSAL_4_OUTPUT = sl_2_r = 17 (Initial state: off = 00)
MAPPING_UNIVERSAL_4_PART_OF = off = 00 (Initial state: WLH_FMH_RL = B0)
MAPPING_UNIVERSAL_4_FUNCTION = blinken_r = 07 (initial state: off = 00)
MAPPING_UNIVERSAL_4_PRIORITY = UNKNOWN = 00 (Initial state: priority_1 = 01)
MAPPING_UNIVERSAL_4_PWM_1 = 100% = 64 (Initial state: 0V = 00)
MAPPING_UNIVERSAL_4_FIXED_PWM = fixed = 01 (Initial state: do not touch)
MAPPING_UNIVERSAL_4_ DIMMED = not_active = 00 (Initial state: do not touch)
      07-20-2022, 10:50 PM   #44
Renan
Drives: 320i f30
FOG as brakes:
BDC_BODY
OTHER CODES
Thanks for response
I tried the fog as brakes and nothing happened, also I forgot to tell i have a F30. Maybe need some adjustments to work
The rear daylight turn code will blink the bars or the brakes ? My bars already coded to blink like the video, i searched a lot but can’t make the brakes blinks too.
I saw that you used a universal mapping, just map the number “14” that means the number is related to the brakes or led bars?
Maybe the member Takabo knows how it works? Sorry for many questions, thanks in advance.
