BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Wheel compatibility for 2016 X1
      06-24-2016, 09:45 AM   #1
3s-a-charm
3s-a-charm's Avatar
135
Drives: 2017 Tesla Model X
2007 BMW X5  [0.00]
Hello, I'm wondering if anyone knows what other BMW wheels are the same offset and bolt pattern as the 2016 X1? Because this vehicle is fairly new there aren't a lot of used wheels available but if the previous gen X1 or the current X3 have the same wheels then I may be able to pick up a winter set used. Thank you.
17 Tesla Model X 90D (I've been converted!)
PAST: 14 Tesla Model S P85D, 16 X1, 13 X5 M-sport, 04 M3 Cab, 08 E92 M3, 08 535xiT, 07 X5 4.8i, 06 E90 325i, 87 E30 325i, 85 E30 318i
      06-24-2016, 09:55 AM   #2
Vogit
93
Drives: X1 xDrive 20D xLine
Only the 2 Series Active & Grand Tourer, I'm afraid - different bolt pattern & centre diameter. Some Mini wheels might fit.
      06-24-2016, 02:50 PM   #3
simon.
922
Drives: F48 25D mSport
Oh balls. Have a set of winters on 18's from my F31 that I was hoping to use
      06-24-2016, 08:58 PM   #4
bmwnorge
Drives: E70
F31 should have 72.56mm center bore. F48 uses 66.6mm bore. go to a tire shop and ask for hub rings so you can use the F31 rims.
offset might be different but you can ask the tire/wheel shop for info and please report back.
i'm in the market for replica rims for my new F48 as well!
      06-25-2016, 01:21 AM   #5
serge2609
serge2609's Avatar
Netherlands
Drives: BMW 220 Active Tourer (F45)
I own the 2 series active tourer (F45) now and i ordered the X1.
So I hoped my winterwheels (589) could fit the X1. Sadly it doesn't because the centerbore is a bit smaller. I will have to look for a new set of winterwheels.
      06-25-2016, 01:56 AM   #6
simon.
922
Cheers. I'll do some research
Serge. Did you read the above post? Spigot rings might well sort it so they fit.
      06-25-2016, 03:23 AM   #7
serge2609
serge2609's Avatar
Netherlands
The wheels of my F45 has a smaller center than of the F48. So spigot rings do not work. If I want to fit my current winterwheels I will have to make the holes bigger to fit the F48..
      06-25-2016, 01:09 PM   #8
3s-a-charm
3s-a-charm's Avatar
135
2007 BMW X5  [0.00]
Thanks for the info. Would be nice to hear if anyone successfully uses wheel from another BMW on their X1 and posts what spacers or hub-centric rings they used to make it work.
      06-25-2016, 02:51 PM   #9
simon.
922
Will look @ mine when the car comes (September) & post up how I get on.
      06-25-2016, 06:16 PM   #10
ttimbo
ttimbo's Avatar
282
I guess if you're prepared to go to spacers and hub adapters, you can make quite a variety "fit". But there's an inherent problem due to the centre bore and PCD of the F48, which is different to other BMWs except the 2 series Active Tourer (and maybe the MINI)...VW/Audi might be a better source...
Peugeot T9 308 GTi 270
