BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos What size trailer should I buy for my DD Camry?
View Poll Results: What size trailer to buy for my 07 Camry
4x8' 0 0%
5x8' 1 11.11%
5x10' 3 33.33%
Dont tow with your Camry! 4 44.44%
Other - disclose in comments below 1 11.11%
Voters: 9. You may not vote on this poll
      09-15-2019, 07:05 PM   #1
natedog7700
natedog7700's Avatar
658
Drives: 07 335i RB's 625whp
Long story short, ive been borrowing a small 4x8 utility trailer that i haul with my Camry, since i dont have a truck/SUV. Im in need of a trailer more and more these days and im going to pick one up but the question is, what size do i get? Ideally i would get a 5x10 but i may go with a 5x8 since my camry can only tow a couple thousand pounds. Buying a 4x8 has also crossed my mind but it can be a bit small sometimes. What do you guys think?
      09-16-2019, 05:41 AM   #2
2000cs
3497
Drives: Potato
What are you putting on the trailer?
      09-16-2019, 06:55 AM   #3
CTinline-six
Hoonigan
CTinline-six's Avatar
6825
Drives: '09 328i, '98 Wrangler
Is this a V6 Camry or 4 cylinder Camry?
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park
      09-16-2019, 07:54 AM   #4
2000cs
3497
Drives: Potato
The trailer needs to be safe and sized for the loads (weight and dimensions) being carried.
The tow vehicle needs to be able to safely tow and control the trailer.
So, if you’re pulling more weight than the Camry is rated to handle, you need a different tow vehicle. The smallest trailer is usually the easiest to pull and control, but it has to handle the load you’re putting on it. So I would start with the loads being carried and work forward, so to speak, to the trailer and tow vehicle.
      09-16-2019, 08:15 AM   #5
Maynard
3848
Drives: 228iX & M2C
Go big or go home - 40' duallie with onboard brakes should do the trick. You can mount the 5th wheel in the trunk where the spare tire well would be.
Appreciate 2
upstatedoc7559.50
Red Bread4463.00
      09-18-2019, 10:43 AM   #6
natedog7700
658
Some loads will be light, under 500lbs. Others will be 2000+ and all shapes/sizes.
      09-18-2019, 10:44 AM   #7
natedog7700
658
4 cylinder ftw!
      09-18-2019, 10:46 AM   #8
natedog7700
658
My hitch/reciver is rated at 3500lbs, 350lb tongue weight so I'm good there, but the manual only says 1,000 towing capacity. I'll push that to 2-3k though I think it'll be just fine for the short distances I'll be going. I
      09-18-2019, 10:55 AM   #9
grocerylist
268
Drives: BMW M235i
2016 BMW M235i  [0.00]
Trailers can be expensive. It might be cheaper and more useful to buy a small beater truck.
      09-18-2019, 10:57 AM   #10
9krpmrx8
Clean is the new cool, keep it that way.
9krpmrx8's Avatar
808
Drives: 11' Alpine White 335i Sedan
I have a 2002 Camry 4 cylinder and it can barely move itself let alone a trailer. Don't do it, use your head.
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive
      09-18-2019, 11:04 AM   #11
grocerylist
268
Drives: BMW M235i
I don't think using your head is a good idea either but it appears some people are into that.
https://youtu.be/OL7KyIgXb6k
      09-18-2019, 11:07 AM   #12
natedog7700
658
Registration, insurance and maintenance adds up and the fact I would only be using it to haul stuff a few times a year makes it hard to justify.
      09-18-2019, 11:09 AM   #13
TomHudson
658
Drives: 2011 E90 M3
Since we can triple tow ratings; my ml320 CD I can tow 21,600 lbs
Thank you !
      09-18-2019, 11:10 AM   #14
natedog7700
658
I've already towed over a 1,000lbs with it no problem, it'll be just fine. Mine is a 2007, my old 2001 was wayyyyyy weaker. I did a 0 to 60 run with my draggy performance meter and ran 10.9 seconds in the old camry, and 8.2 in my new camry, if that doesnt tell you anything then idk what will lol
      09-18-2019, 11:15 AM   #15
grocerylist
268
Drives: BMW M235i
In that case you might look into the Home Depot $19.99 truck rentals.
      09-18-2019, 11:18 AM   #16
grocerylist
268
Drives: BMW M235i
That's pretty impressive, better than Ferrari Mondial 8 times!
      09-18-2019, 11:33 AM   #17
9krpmrx8
9krpmrx8's Avatar
808
Okay. Derp.
2015 X5 35i Xdrive
      09-18-2019, 01:48 PM   #18
KenB925
1124
Drives: ZL1, Raptor
Its not so much the towing as it is the stopping and changing directions in a hurry.
The bigger the trailer the heavier it will be by itself, a decent 5' x 10' will probably be at you max tow rating before you put anything on it.
      09-18-2019, 01:57 PM   #19
JM98
391
Drives: 2009 135i
5x8 is perfect for towing 2000lbs or less. I've been using one on my 1 series and honestly you barely feel it unless it's super windy, just make sure to drive defensively.
      09-18-2019, 02:30 PM   #20
Deebo
247
Drives: 2011 AW E90 ZCP
This. My father in law got rid of his F-150 tow vehicle used 2-3 times a year to launch his boat and we now rent from Uhaul instead. We may look like total noobs towing and launching the boat, but it was an ingenious solution.
9krpmrx8808.00
      09-21-2019, 11:26 PM   #21
GenXer
1363
Drives: Like a bat out of hell.
It's not the size of the trailer but the weight. If you are buying a trailer, I would get a slightly bigger one since most state registration cost the same but I would caution not to overload the trailer with more than your transmission can handle. The wider trailer will give you the ability to haul bulkier and longer items.
If you are only hauling for short distance or on occasion, I would suggest renting from Home Depot or Menards instead.
      09-24-2019, 01:38 PM   #22
9krpmrx8
9krpmrx8's Avatar
808
If the OP had a truck.
2015 X5 35i Xdrive
