07-27-2018, 06:37 AM | #1 |
96
Rep 254
Folding rear backrest sticking?
Hi,
I have a 2018 X1 with the electronic fold rear backrest. However when I pull the button to fold the right hand 40 section (looking into the boot) it does not fold and has to be manually pushed down. The motor (or whatever it is) does make a noise as if it should activate. If I firstly fold the 40:20 section on the left side (which does fold correctly on pull of the button then the right 40 section does fold on pull of the button. So I'm not sure if it is set up that the 40:20 section has to be folded first or that there is something wrong/sticking with the mechanism. Any suggestions folks? |
07-27-2018, 08:03 AM | #2 |
Rep 15
I also have a 2018 x1 with exactly the same problem as yours, I have not taken the car back to the dealers because have not had the time, and the fact i do the same as you (lower seats from left to right) i think some how the small seat must rub on the centre seat.
07-27-2018, 09:57 AM | #3 | |
96
Rep 254
07-27-2018, 10:18 AM | #4 |
922
Rep 2,559
I always fold the right hand side, just habit & both sides work every time for me.
Right goes down then the entire section first for the left side then far left. Try that to see if it works. Otherwise, guess dealer visit is in order. |
07-27-2018, 10:33 AM | #5 |
96
Rep 254
Just tried it again but firstly slid the seat base forward and it worked. So definitely the problem is the size of the seat back rubbing up against the side of the middle section. I had hoped the sides would also be leather and that perhaps a bit of polish would do the trick but unfortunately one side is material.
Looks as you say a trip to the dealer to get seat adjusted. |
martinx15.50 |
07-27-2018, 02:07 PM | #6 |
159
Rep 458
For what it may be worth, mine started to stick, but on the left side and with a few seat back ups and downs it seems to be operating, via the release buttons, as it should.
I do, however, have a different issue, this with the hatchback door, from where there is a fairly light but, once it starts, persistent and annoying rattle that seems to be from the lower area of the door. I have noticed that sometimes when I close the hatch it makes a fairly 'tinny' noise on closure. The rattle can be heard either immediately on moving off from standstill, or it can start when I've driven a few miles. I have tried emptying the boot/trunk, including moving the emergency warning triangle from its holder, but to no avail. My wife sat in the rear seat and she thought the sound came from the lower area at the back, possibly near to the closing point. Tap the rear light units and they also ratttle/vibrate. Overall, I'm not impressed by the quality of the hatchback, especially as the spoiler also sees to be constructed from rather flimsy plastic and, if you touch it, you can feel how thin it is. Similar to the lights, it also rattles if tapped. Not what I'd have expected from a 'premium' vehicle. So it looks as though I'll be off to see the dealer - 60 mile round trip! Last edited by oakey46; 07-27-2018 at 02:15 PM.. |
07-27-2018, 02:43 PM | #7 | |
96
Rep 254
07-28-2018, 08:56 AM | #8 |
110
Rep 339
Drives: G20 330ix M Sport
There's a service bulletin #SI B52 02 18 regarding the rear seats not folding down due to the backrests are closely spaced and rub against each other. The backrest need to be adjusted.
martinx15.50 |
07-28-2018, 10:57 AM | #9 | |
96
Rep 254
Not a critical issue so I'll raise it with the dealer next time I'm passing. Thanks |
09-20-2019, 01:23 AM | #10 | |
Rep 1
I can’t find it anywhere. Regards |
09-20-2019, 11:26 AM | #11 |
159
Rep 458
The remedy I've used to fix this, but only on leather seats, is to apply some leather cleaner/balm to the sides of the rear set backrest with a soft clean cloth. I have TurtleWax leather cleaner (from the principal UK motorists store chain), which seems to work,as well as generally keeping the light beige leather clean and in good condition. The only caution is to be careful not to apply where the backrest sides are of fabric (centre armrest + other parts). I have also applied sparingly to the black plastic trim against which the outer sides come into contact.
Seat backs now drop immediately from either side, just as they should, so I hope that’s a lasting remedy - we’ll see! Last edited by oakey46; 09-21-2019 at 02:39 AM.. |
09-22-2019, 09:49 AM | #12 |
Rep 11
Posted a comment on this some weeks ago (Sticky Seats). Still have the problem but seems intermittent. As you have mentioned, you can hear the relay/solenoid operating but seat stays put. It does seem better if the left hand seats ( facing boot) are operated first but should definitely operate more smoothly than it does. May try the seat polishing fix and will report back if I have any success.
09-27-2021, 08:29 AM | #13 |
Rep 41
I've just bought a 2017 X1 with this very same problem. The Left and Centre sections fold down fine electronically, but the Right hand seat back will not move, unless operated manually by pulling the tab. The solenoid actuates, and the seat back does move by about 3/8 inch but then stays put. Happens regardless of weather seat is slid forwards or back, or the state of the other seats/centre section.
Update: Just tried rubbing a bit if furniture polish on the sides of the seat backs. This seams to have cured the problem. Here's a link to the sticking seat bulletin referred to, which suggested altering the seat positions: https://www.tsbsearch.com/BMW/SI-B52-02-18 Last edited by Wadadli Cooler; 09-29-2021 at 09:59 AM.. |
