08-28-2018, 04:37 PM | #24 |
60
Rep 173
My concern was that I would throw a code if I just unplugged the electrical connection so I just loosened the 3-10mm bolts holding the actuator assembly just far enough so that I could remove the spring clip that couples both assemblies. Then I bent a piece of welding electrode (flux removed) that matched the width of the slot on the valve shaft into a "Z" shape, slid it into position in the valve's slot after fully opening the exhaust flap, then secured the ends of the wire to the mounting bracket by bending. Oh, save the spring clip that you've removed - it's $10 to buy if you ever want to revert to OEM.
08-29-2018, 08:38 AM | #25 | |
14
Rep 40
and eventually a muffler exhaust system if i "need" more sound - assuming more than one or two exhausts are on the market at that time. |
08-29-2018, 08:46 AM | #26 | |
14
Rep 40
08-29-2018, 02:42 PM | #28 | |
180
Rep 375
Drives: 2020 M2C DCT
08-30-2018, 12:13 AM | #29 |
180
Rep 375
I did some looking and found something interesting.
The actuator on the X1/X2 is used on quite a few BMWs. Here is a link: Actuator drive, exhaust flap I found this article: 440i - Exhaust Flap Mod - The Proper Way... It refers to this part: Dummy flap actuator This seems to be a way to disconnect the actuator and not have a code. |
08-31-2018, 06:15 PM | #30 |
14
Rep 40
pulled the clip out, switched the valve open, and my buddy welded the bottom turning part underneath the exhaust so the valve doesn't turn. took a total of 30 seconds to pull the clamp spring out and 30 seconds to weld.
09-01-2018, 11:11 PM | #31 | |
180
Rep 375
09-02-2018, 09:50 PM | #32 |
14
Rep 40
Just FYI I've had no codes with the valve open. And that doesn't shock me if the car doesn't know that it's open (or that it didn't shut).
and my 335i stock muffler exhaust had the valve flap, and i upgraded to the PE exhaust which has it removed - so i guess i might not be that offensive to the engine anyway. |
10-27-2018, 05:35 PM | #33 |
180
Rep 375
I found another piece of the puzzle.
Universal socket housing uncoded This is the connector that goes into the exhaust flap actuator to protect it from corrosion. This part number doesn't include the cavity plugs. I'm trying to find a part number for the cavity plugs, but you could use silicon caulking. |
01-12-2019, 06:57 PM | #34 |
98
Rep 266
Simplest way to do this mod is to open the flap in Bimmercode/Carly, unplug the connector from the flap under the car, tape up the connector to protect it from outside elements secure the connector under the car. There will be a stored code but no CEL.
04-10-2019, 11:49 PM | #35 |
137
Rep 310
Hey folks,
From pictures, videos and posts on this mod, is disconnecting the actuator really necessary? Cant you just remove the C clip joining the actuator to the flap and then securing the flap in open position without disconnecting the electrical connector? I was going to buy the dummy flap and connector covering but was hoping this mod can be done without having to disconnect the actuator motor. Also, it should prevent any shadow codes from being stored. Any thoughts or can anyone confirm this mod can be done this way? Thanks. |
04-11-2019, 07:02 PM | #36 | |
98
Rep 266
04-11-2019, 08:53 PM | #37 | |
855
Rep 1,553
I ran it like this for a couple of months and honestly performance wise I couldn't tell any difference. The sound was a bit louder on startup. Eventually I reinstalled the actuator and clip to run the flap OE style. I like having the quiet ride as the X1 is the family vehicle and the only quiet vehicle we own. |
04-13-2019, 02:38 AM | #38 |
137
Rep 310
Proper and knightarmor, feedback is much appreciated! I'm going the safety wire tie down route, too. Probably the cheapest and most reliable way of holding the flap open short of welding it.
04-15-2019, 04:10 PM | #40 |
1363
Rep 1,031
Drives: Like a bat out of hell.
Is this why the left exhaust pipe is a lot dirtier than the right?
It seems like using Bimmercode and disconnecting the plug are more elegant solution. Last edited by GenXer; 04-15-2019 at 04:14 PM.. Reason: added message |
04-15-2019, 04:50 PM | #42 |
98
Rep 266
100% much easier and cleaner, just be sure to electric tape up the connector really well to prevent any water and road dirt/grime getting into it than just zip tie it up and out of the way so it doesn't hang down.
04-15-2019, 06:33 PM | #43 |
137
Rep 310
Which category is this option under in Bimmercode? I looked recently and didnt see any preset options to have flap open all the time.
04-15-2019, 07:08 PM | #44 |
98
Rep 266
