BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Focal 8” under seat sub upgrade
      01-18-2019, 09:52 AM   #1
Mushy007
56
Drives: X3 2D MH M Sport 2021
I’ve just ordered these on eBay and should be here next week. As I have the base unit, these are 4ohms and direct replacement for the small crammed in 6” units.
I’ll report back once there fitted and can give them a good test.
      01-18-2019, 03:06 PM   #2
mustardman
15
Drives: 2017 X1
Does this fit the F48? The website says these are compatible with E84 only.
      01-18-2019, 03:23 PM   #3
Mushy007
56
Looked through a lot of the forums and the base sound system is the same across many models, I also read the install document and it has a lot of good quality pictures, that show the housing the same as mine. Not sure why the F48 is listed on a lot of upgrades when they are the same.
      01-21-2019, 07:34 AM   #4
Mushy007
56
Follow up to the above, I fitted these speakers into the OEM housing no problem at all. As the seats in the X1 are high you don't actually need to remove the sub housing.
I have pictures which I will upload later, the quality of the speakers vs stock was obvious, with a substantial weight difference. I got these at a reasonable price, which is good as they just don't IMO give a huge improvement over the stock units. Yes, you can feel and hear the bass much better, as I only have the base system, but I would guess if you have the HiFi system or HK, you would be really disappointed.
CliveL163.00
      01-26-2019, 12:21 PM   #5
d_am
d_am's Avatar
Greece
71
Drives: X1 sDrive 16d Modell M Sport
eBay link please..?
iceman7117.00
      01-27-2019, 12:56 PM   #6
Mushy007
56
Here you go.
https://www.ebay.co.uk/itm/Focal-IFB...IAAOSwR7BbiU~U
iceman7117.00
      01-27-2019, 02:49 PM   #7
d_am
d_am's Avatar
Greece
71
Thank you mate!
iceman7117.00
      01-29-2019, 09:36 AM   #8
Proper
Proper's Avatar
98
Drives: X1 M-Sport
These replaced the Harmon Kardon speakers?
      01-30-2019, 12:26 PM   #9
Mushy007
56
HK has an amp, so you need the same speaker but with 2ohms, not the 4ohms here for the basic system.
      01-30-2019, 01:20 PM   #10
Proper
Proper's Avatar
98
Drives: X1 M-Sport
Noticeable difference? The HK speakers sound pretty good.
      01-31-2019, 02:38 PM   #11
Mushy007
56
Here's some pictures taken while changing over the speakers.
      01-31-2019, 02:41 PM   #12
Mushy007
56
You do get a much better bass punch, which just wasn't there before, but the housings are so small, the benefits where going to be limited. Having not heard the HK system, I cant compare.
I did replace the door speakers with better units, with a combined tweeters the results, where very impressive.
      05-08-2019, 10:18 PM   #13
Xorbitman
47
Drives: 2018 BMW X1
Changing the door speakers will only change the sound. The existing door speakers are too small to be off any significance.
      05-09-2019, 05:15 AM   #14
Mushy007
56
Agree in principle re size, however the introduction of a tweeter, has made a big difference. https://www.ebay.co.uk/itm/263472405972?ul_noapp=true
      05-09-2019, 08:30 AM   #15
Jmhockey1920
Drives: 2018 BMW X1
Hey Mushy! What tweeter speakers did you get? Also, if you had the basic stereo, there are no tweeters included, right?
Off-topic...what a night for Liverpool FC on Tuesday!! I envy you if you were at the game or a pub in that area.
      05-09-2019, 12:36 PM   #16
Mushy007
56
I got Eton speakers from Germany, plug and play, with a tweeter in the centre. They also do an upgrade for the external tweeter setups. Yes, I have the base stereo so no amps or tweeters, listen with headphones to this to hear the difference
I’m from the blue side
      07-03-2020, 06:57 PM   #17
allwheelsdriven
#onelesssubaru
allwheelsdriven's Avatar
112
Drives: 16 BSM X1 MSport
Just installed the Focal subs in a 2016 f48 X1...wasnt easy or quick but they do fit.
      07-04-2020, 07:41 PM   #18
Tarekith
Tarekith's Avatar
48
Drives: BMW M35i
Good to know. I just did all the other interior speakers in my X2 with Focals, and was debating going all in on the subs too. I have the HiFi system and the subs are ok, but I think some of the extreme lows around 40Hz could be a little tighter still.
2020 M35i
      07-04-2020, 08:22 PM   #19
allwheelsdriven
#onelesssubaru
112
Yeah my next move is one of the plug and play amps.
Took me about a half hour to get the first one out. T50 to get the seat out, back and forth. Although raising it helped me to get the rear bolts. Unscrewing everything else including the two 10mm nuts that hold the whole enclosure in.
Once everything is out, I put down a square of FatMat just because...figured I had some and was in there, so. Others have talked about placing it inside the plastic enclosure. I also went without the sub gasket since it makes the whole package too thick to screw back together.
All in all its a nice improvement but really needs more watts to make it sing.
