12-22-2017, 04:54 AM | #2 |
Rep 39
Drives: X1 F48 25i
Not enough room between tyre and shock absorber.
You can put Thule Summit K44
12-22-2017, 08:54 AM | #4 |
Rep 39
Drives: X1 F48 25i
Mince alors
Pourtant autorisées en France
12-24-2017, 12:30 PM | #5 |
64
Rep 261
12-27-2017, 04:49 AM | #6 |
Rep 17
12-27-2017, 10:52 AM | #7 |
Rep 39
Drives: X1 F48 25i
I have them for my BMW 570´s rim and they are not damaged with the Thule Summit.
And I don’t want to damage them .... You can’t put conventional snow chains due to the lack of space. They are saling almost the same http://www.accessoires-bmw.fr/access...l#.WkPPoyTfuf0
01-23-2018, 06:21 AM | #8 |
37
Rep 153
As we are just about to set off for the Alps in my new toy, I researched this and found no one could provide chains thin enough here in the uk for the 225 /50 R18 tyre. I ended up buying a set of BMW winter wheels and winter tyres instead (205/60R17) and managed to source some budget chains to fit.
I did try and buy a steel set of wheels and budget tyres in Germany but the suppliers would not help. Closed shop? At least as BMW winter wheels there shoul not be an issue with the insurance. |
01-23-2018, 06:49 AM | #9 | |
Rep 39
Drives: X1 F48 25i
Musher antiglisse They are B26, allowed on snow roads like winter tyres and you have some video on YouTube. They look not bad https://www.musher-antiglisse.com/?g...hoCskMQAvD_BwE
01-08-2019, 10:57 AM | #11 |
37
Rep 153
Bite the bullet and buy BMW winter wheels and winter tyres (205/60R17). I wasted a lot of time trying to source chains for the larger 225/50R18 wheels and tyres. I run on the smaller wheels from January through to early March. This is partly because we head for the Alps in February and they work really well when the temperature is constantly below 8 degrees C.
I searched on EBay and found a BMW dealer shifting stock, as they felt they were unlikely to sells these in Southern UK. |
01-09-2019, 05:22 PM | #12 |
30
Rep 83
01-13-2019, 11:45 AM | #14 |
Rep 4
Mount chains on front or rear? Manual kind of says front but the grammar could be misinterpreted... BMW genius at the dealer says rear... What is the real world experience?
01-14-2019, 05:05 AM | #16 |
282
Rep 1,491
Yes, mount on the front (actually, IIRC, you can only use chains with 17" wheels, but that may be old) and activate Dynamic Traction Control (per manual)
Peugeot T9 308 GTi 270 Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182. |
01-16-2019, 02:54 PM | #18 |
37
Rep 153
My winter wheels and winter tyres are on the car ahead of a trip to the Swiss Alps next month. Seeing the amount of snow in the Alps at the moment I will also practice with putting my snow chains on. The X drive is brilliant with winter tyres, but I may still need to put the chains on.
02-21-2022, 02:58 PM | #19 |
Rep 1
good evening, I reconnect to this discussion .... reading and trying to find out about it, I seem to have understood that the problem of chainability (and therefore the fact that certain tire sizes cannot be chainable) is not so much due to the fact of possible internal rubbing (suspension arms, or other ...) but the difficulty of passing the hands to hook the steel cable behind the tire inside the wheel arch. If you succeed with this, I think that, with the modern fine-link chains on the market, the size 225 50 r18 can be chained; chains that I would like to use exclusively in an emergency, opting for an x-drive and high-end 4-season tires
for example the konig k-slim have a 7 mm mesh ... that is ... take a ruler and see how much 7 mm it is ... it is impossible that there is not such a space / encumbrance around the tire ... look at the photo below the grip of the chain I was talking about on the tire ... |
amxrt0.00 |
02-25-2022, 11:04 PM | #20 |
855
Rep 1,553
The Konigs fit. I have a set for 235/50-18's that I run. Key is offset of the wheel. I pushed the wheels out 6-10 mm's depending on which wheelset I am running on the vehicle. My winter wheels were OEM diameter/width with an additional 6mm spacing. I now run all season on OEM 18" wheels with 10mm spacers. I think overall I prefer the 6mm spacing.
02-25-2022, 11:09 PM | #21 |
855
Rep 1,553
Pics of when I did the test fit up with the snow tires. There was approx 10mm of spacing on the backside of the tire but this wheel is pushed out 6mm from OEM.
01-04-2023, 02:53 AM | #22 | |
Rep 1
cesarone77 Any suggesstions on which konig k-slim should I choose for the tire size 225 50 r18?
