07-09-2017, 12:08 PM | #1 |
12
Rep 13
Drives: 17' F48 M Sport
Exterior Bulb Replacement with LED
Anyone tried replacing the Bulb to LED without coding ?
The manual suggests: Front Turn Signal: Bulb: A2357 / 21W Socket: PY21W -> Is it same as BAU15S? Turn Signal / Outer and Inner Break Light: Bulb: P21WLL / 21W Socket: Is it BA15S? Fog Light: H8 / 35w This is not a concern. |
07-16-2017, 05:09 PM | #2 | |
126
Rep 243
07-17-2017, 12:42 PM | #3 |
80
Rep 241
I recently installed LEDs for the rear turn signals and back up lights. No error msg and no recoding necessary. Just plug-n-play. The only thing I noticed was that the LEDs would flicker on start up for about 5 sec. These LEDs were obtained from deAutoKey. I am awaiting the arrival of the front LEDs turn signals, as well as, the 4 LEDs brake lights. Will see if they produce any msg. My X1 is a 2017 if that makes any difference.
07-22-2017, 08:09 PM | #4 | |
126
Rep 243
07-23-2017, 01:36 AM | #5 | |
80
Rep 241
Much appreciate the info. Thanks!
08-01-2017, 04:43 PM | #6 |
12
Rep 13
Finally I got a solution...
Found something from AliExpress and changed my Front / Rear Signal bulbs. No error code / flicker etc so far - just plug-n-play. Front Signal: https://www.aliexpress.com/item/2pcs...311.0.0.ZeYIzi Rear Signal / Break: https://www.aliexpress.com/item/2PCS...311.0.0.FtYZxy |
08-01-2017, 08:04 PM | #7 | |
80
Rep 241
Hmmm, interesting. Will have to try this one as well. Thanks for the find
08-04-2017, 10:34 AM | #8 | |
17
Rep 29
08-11-2017, 03:52 PM | #9 |
12
Rep 13
Yea the I contacted the seller before and they're not able to confirm if the bulb has canbus / true compatible with F48 X1.
I just went ahead and ordered the Front signal & Rear Signal (same as break light). Installed the Front and try for 100km before installing the real signal. Confirmed that no flickers nor error code issue. I've driven that for 300-400km and no issue. I just ordered another set of rear light. Gonna leave the inner break as I'm not confident to take off the panel on the trunk. You may order the front signal first as shipping is free anyways! Just to mention that I dunno the seller and no commission for me. Last edited by mattlam; 08-11-2017 at 03:53 PM.. Reason: Update missing info |
08-11-2017, 05:32 PM | #10 |
80
Rep 241
You can do it! Just slide the panel off with a flat blade from inside the lift gate and you will see the bulb that needs to be removed. If you can change a tire, you can do this. It's much easier than tire changing .
Oh, BTW, did you have to remove the transformer/heat sink of the LED headlights to access the turn signals in the front? |
08-19-2017, 05:31 AM | #11 | |
12
Rep 13
08-19-2017, 12:48 PM | #12 |
80
Rep 241
08-20-2017, 01:22 PM | #13 | |
Rep 8
It seems that the inner brake lamps are H21WLL however you mentioned P21WLL. Is that correct ? Bulbs are quite differents, BA15S / BAY9S, i mean. |
09-07-2017, 04:28 AM | #15 |
80
Rep 241
It should blink w/o coding. Perhaps you have a defective one? I ordered the same ones and they blink w/o problem. No hyperlinks, no error messages. I went ahead and code it for LEDs thereafter for reassurances.
09-07-2017, 03:12 PM | #16 |
Rep 8
Any informations regarding my post ?
09-08-2017, 04:43 AM | #17 |
80
Rep 241
My apologies, I only ordered the front turn signals. As for the rears, I had those from DeAutoKey prior to the front ones. They're the 1156 OSRAM CREE LEDs. The 1156 functioned well too, except for flickering on start up. Using Bimmercode, I coded the rears to LED, and now no more flickering.
09-08-2017, 03:42 PM | #18 | |
Rep 8
09-09-2017, 04:59 AM | #19 | |
28
Rep 57
I tried coding front blinkers as led and I received an error message in esys when the coding process ended. They are not the same led bulbs you are talking about these are not error free led bulbs |
10-06-2017, 02:22 AM | #20 |
Rep 42
I'm going to order this for the rear turn signals: (Yellow/Amber color)
https://www.aliexpress.com/item/2PCS...816830049.html And this for the brake lights: (Red color) https://www.aliexpress.com/item/2PCS...816784975.html Are these the correct ones? Last edited by civciv; 10-06-2017 at 03:35 AM.. |
10-09-2017, 10:14 PM | #21 | |
80
Rep 241
1ittletofu1.00 |
