BIMMERPOST Universal Forums General BMW News and Cars Discussion Do you warm up your modern-day BMW before driving off?
      01-20-2019, 02:53 AM   #23
ItsGary
ItsGary's Avatar
1457
Drives: 2009 E90 M3
Originally Posted by omera60 View Post
I also don’t, I only wait for the revs to go done which is 30sec and then drive off. The main idea of setting off after the revs go down is to let all of the driving components such as the transmission, differential, brakes etc. to warm up together with the engine itself. If you warm up while idling the engine will be ready to give out what it has but other components are simply not ready to handle the load. Also bear in mind that a proper warm up of the transmission is at least 20-25km of driving as the transmission fluid is very hard to heat up and cool down. If you start putting pedal to the metal before that I can guarantee that it will give you headache on the longer run.
A lot of cars have high idles to warm up the CATs
'09 ///M3 Sedan - Jerez Black/Fox Red Ext.
'09 335i Coupe - Alpine White/Black - SOLD
      01-20-2019, 06:09 AM   #24
cmyx6go
cmyx6go's Avatar
15581
Drives: 2022 X6///M Comp
2019 X6 ///M  [10.00]
I don’t understand the auto starts on cars these days. I have always read that idling to warm the car is actually bad for the engine. I just let the rpms drop after start and drive off but go easy at first.
      01-20-2019, 07:37 PM   #25
Germanauto
Germanauto's Avatar
9666
Drives: Alfa Romeo Giulia, Rosso
Only if its below 15-20 degrees out. And only then I'll sit for a 30 secs.
      01-20-2019, 09:14 PM   #26
JAK
JAK's Avatar
Drives: Space Grey M3
I always warm up my car don’t care about wasting gas, otherwise I’d be driving a different car. I can’t believe that letting a car idle is bad for the engine when it’s one step up from the least amount of stress you can induce on it. Sitting in traffic must be hell on my car if that’s the case
Dackelone10512.00
      01-20-2019, 09:29 PM   #27
evanescent03
evanescent03's Avatar
1031
Drives: '24 M3 CS; '22 GT4
I warm my car up gently ... but getting in, pushing start, putting it in D and pulling out. I think if you're driving at barely above idle speeds it's probably not much different than letting it sit and idle. Great time saver so I don't have to speed on the highways. (Yes, if you let your car idle, you automatically need to make that time up on the road and you are totally unsafe! /trolling)
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
      01-21-2019, 12:46 AM   #28
BNTLY
Master Chief
54
Drives: F34
Warm-up by driving conservative until the engine heats up. Then throw it sport+ an gooo
      01-21-2019, 05:49 AM   #29
cmyx6go
cmyx6go's Avatar
15581
I broke my rule this morning and let it warm for a bit. I got to the highway and my temp gauge was barely at 160. Damn it's cold.
      01-21-2019, 05:57 AM   #30
aaaaah
354
Drives: Nuggets
If it hadn't snowed, right now I would do it for a minute then drive slowly, but only because it's -20C outside.
If it has snowed I'll start it and have it run while I'm clearing the snow. I only wish it didn't have a clutch lockout switch.
      01-21-2019, 05:58 AM   #31
sdk8103
43
Drives: 2014 X5 X35i
I've always done what someone else mentioned and started the car, did the seat belt, turn on the radio, and then go, going easy on it until it warms up a little. I was taught that the sooner the engine goes above idle speed when it is cold, the quicker the oil gets to the places where it has settled from while sitting. Everyone has their own beliefs, but I have a 4Runner with 250,000 miles and I have never had to add oil between changes, and have other cars with similar results, so I must be doing something right.
Steve
2014 X5 xDrive35i
1983 320i (many years ago, but it's good to be back in a BMW)
      01-21-2019, 06:57 AM   #32
V-Eight
V-Eight's Avatar
792
Drives: MY22 M3 G80 Comp.Xdrive
Mee too, usually, when the car is really cold, I just wait it to low automatically the rpm, then I drive away (about 30/40 seconds). Then when it's barely warm (maybe the engine is still warm, I start and drive quiet for a couple of miles, then let the party begins :-D
      01-21-2019, 07:05 AM   #33
mojobmw_e90
380
Drives: 2014 E63S
Me personally i let it sit for 10min or so idling before driving of. Reason being is highway is 3 blocks away from my house so driving a cold car at 65 70mph surely isn't good for the engine
Dackelone10512.00
      01-21-2019, 07:49 AM   #34
Wolf 335
Wolf 335's Avatar
2339
Drives: 2007 E92 335i
This is interesting because when I did my transmission fluid change I idled the car until the tranny fluid temps raised for proper fill level. So to say that transmission doesn't warm up during idle is not correct.
      01-21-2019, 07:53 AM   #35
Wolf 335
Wolf 335's Avatar
2339
The clause in bmw manual that states you shouldn't warm up your car seems more like the German government speaking rather than the manufacturer.
jjasonSU194.00
      01-21-2019, 08:09 AM   #36
King Rudi
King Rudi's Avatar
13152
Drives: Meat Suit
I only allow mine to idle for a few moments if the temp is below freezing.
      01-21-2019, 08:27 AM   #37
FlaPatsFan
749
Drives: 2011 328i wagon
I give mine a minute or so to let the idle drop to its sweet spot. Not sure if being “catless” affects this.
I then speed off like a bat outta hell....lol
      01-21-2019, 09:42 AM   #38
Megabrode
He's experimenting with something...
Megabrode's Avatar
335
Drives: 2011 e92 M3
Originally Posted by glennQNYC View Post
...If it's cold I hit the seat heat with my pinkie at the same time I activate the starter...
Advanced driving skills! Impressive.
Related topic: After 55 years driving in CA and FL, I sometimes struggle with the first (manual) shift in cold weather. Shifting "normally," I grind first to second quite often -- maybe 10 times so far this winter, my first in a snowy climate. Gear oil is obviously thick as molassas in Saskatoon. If I shift slowly, deliberately, no problem. Old habits die hard. I'm hoping my gearbox doesn't die early.
Analog 2011 e92 M3 | Jerez Black | Black Novillo | 6MT | CF roof | No iDrive, Nav, M button, ZCP, EDC, or center hump | ZHP shift knob | OMP 1010 pedals | K&N filter | Dinan engine tune | OEM exhaust mod (bypass) | EAS exhaust tips | shaved front bumper | 19" Apex EC-7 | 12 mm rear spacers
      01-21-2019, 09:52 AM   #39
Animal Farm
93
Drives: BMW F30/Volvo XC90II T6
I let my cars idle 2-3 mins for the first start of the day.
      01-21-2019, 10:06 AM   #40
Dogeeseegod
Dogeeseegod's Avatar
189
Drives: 2009 Blue Water 128i-6
I live on a hill, so I just start the car and idle down the hill in second gear. By the time I get to the interstate the auto climate control is blowing hot so I feel comfortable pushing the go button. Average daily temp this winter is 28F
      01-21-2019, 10:20 AM   #41
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
2595
Drives: 11' 335is DCT
I sure do when it's -20c outside.
One thing I find very weird is when it's like -15c or colder the car doesn't "cold start" it idles at 1k for like 2 seconds then idles down to the usual.
      01-21-2019, 10:24 AM   #42
TheMidnightNarwhal
2595
Dude I also encounter similar shifting issue. The resistance I understand. But shifting 1st to 2nd make this weird winding noise, no grinding. If I wait in neutral for 1 seconds before completing the shift it shift normal that I am not worried.
But we just hit our firsts -20c of the year and my first winter with this car and my tranny started doing a new noise. It literally has a metal cracking when shifting and goes away after 5 mins of driving.
I aswell hope our transmissions don't die early. I replaced the fluid with OE spec maybe I should have listened to the threads and get the Redline D6 ATF stuff... IDK.
I think I'll just let it go and see how it goes.
Here's the noise
      01-21-2019, 10:44 AM   #43
jjasonSU
194
Drives: 650i, NSX
I crank it up and go. Just take it easy the first few miles. Red lights assure that happens anyway
      01-21-2019, 01:06 PM   #44
The Libertine
The Libertine's Avatar
1231
Drives: 2021 Porsche Macan
Originally Posted by orangeglim View Post
I typically wait for the initial cold start revs to lower back down to normal idle (~30seconds? I dunno, I've never timed it), then I put it in gear and get moving. I keep mine in the garage pretty much year round and it never gets below 50F in there during the winter, no matter how cold outside it is.
Same. I wait for the RPMs to drop then drive off.
