F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Which brakes on my 435i?
proTUNING Freaks
      04-10-2024, 06:14 AM   #1
macsnjets
Drives: 2003 Z4 2.5
I feel like I’m beating a dead horse but I’ve read enough information on the different brake configurations to keep my head spinning for a week. My son’s car he just got is a 2015 435i gran sport. The front calipers are in red and four piston and have a “M” logo however measuring the rotor at 340mm. I was first thinking these are M Performance brakes but then shouldn’t it have the 370mm rotor? The vin decoders I try say nothing about the brakes. I know the previous owner could have easily painted the calipers or did an upgrade. To make sure we buy the correct pads how can I know what setup we actually are looking at? Will a part number on the caliper give a better clue?
TIA
      04-10-2024, 07:56 AM   #2
Dagstar
377
Drives: 2014 F31 M Sport
Take a look at the back of the caliper where the brake line connects. If there's embossed text that says 370/380 you have M performance calipers that'll only take 370mm rotors on your car. If it says 340 you don't, and they were most likely the grey Brembos painted red, which take 340mm rotors.
      04-10-2024, 08:25 AM   #3
oem.plus_440gc
oem.plus_440gc's Avatar
365
Drives: 2019 440i XDrive GC
Pads will be the same either way. They're the same caliper, just with a different offset from the hub to fit different rotors.
But more likely they are the stock m sport brakes painted red by a previous owner. Are the rears 2 piston or 1 piston? My guess, single piston floating caliper which would be the "base" m sport brakes, just painted red.
Nothing wrong with those brakes. Like I said, same front caliper, just different rotor size paired. So all the same pad options for the fronts from F8x brakes, M performance, THP brakes, and M sport brakes.
Current: 2019 440i xDrive Gran Coupe - Alpine White, Coral Red Dakota Leather, 8AT, MSport, THP, BM3; 2015 X5 35i xDrive - Mineral White Metallic, Mocha Dakota Leather; Previous: 2015 Subaru WRX - World Rally Blue, Premium, FBO+Tune
      04-10-2024, 08:41 AM   #4
macsnjets
Drives: 2003 Z4 2.5
That’s what I’m thinking. The rotor measures at 340mm. So I can use any pads? That’s good to know. I still have to look at the rear calipers when I get a chance. Thanks
      04-10-2024, 02:34 PM   #5
danb1979
Idiotic lifter of heavy stones...
danb1979's Avatar
1976
Drives: 2015 F31 325D M Sport touring
340mm discs up front, M Sport brakes - does it have standard calipers on the rear or Brembo?
If standard, probably the 330mm discs; if Brembo, 345mm discs
So you'll need the correct pads for the front (M Performance / M Sport etc); but rears is where you need to suss out what's fitted currently
I run OEM M Performance slotted/grooved discs on my F31 (370mm / 345mm) with OEM BMW pads; if you want an upgrade and still BMW, go with the F80 M3 pads
Part numbers on RealOEM FYI
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298
      04-11-2024, 06:34 AM   #6
macsnjets
Drives: 2003 Z4 2.5
Ok, here’s what I see. The front caliper backside has the 340 on it and the back caliper is single piston, sliding. That would be the standard brake set up, correct? Whoever had it before did a nice job on the calipers and even put an “M” logo on them.
danb19791976.00
      04-11-2024, 07:19 AM   #7
Dom147
98
Drives: 2014 BMW 228i, 2017 BMW M240i
2017 BMW M240i  [0.00]
Bimmerworld has a fantastic article going in dwepth on how to identify which brakes you've got and all the differences.
Here's the article: https://www.bimmerworld.com/About-Us...-Sport-Brakes/
danb19791976.00
      04-11-2024, 12:45 PM   #8
danb1979
danb1979's Avatar
1976
Yup; so 340mm discs
Pn.1 ending 223:
https://www.realoem.com/bmw/enUS/sho...49#34116792223
And yes; calipers will have been painted IIRC as they come in grey from factory
      04-20-2024, 08:13 AM   #9
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
I once 2013 made a post about the whole brake variant disaster they did to us.
Maybe this helps a bit.
https://f30.bimmerpost.com/forums/sh...d.php?t=858607
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
f30post
