04-09-2024, 10:27 AM | #1 |
20
Rep 63
bad steering rack?
i have a 2015 428xi. ever since i’ve bought the car i’ve had very loose steering and a lot of play in the steering wheel. i used to have the notorious steering rack knock that everyone talks about with these steering racks and i had the thrust bushing replaced which got rid of the noise but the loose steering continued. i know it’s not my tires i’ve had all 4 replaced and had the issue before and after. does this sound like i need a whole new steering rack? maybe new tie rods or control arms? i just don’t want to have to spend 1,500$ on a remanufactured steering rack that will give me the same problem later down the line. is there anyone who has found a solution for this?
04-09-2024, 10:33 AM | #2 |
122
Rep 221
FCP Euro has a number of good youtube diy's and informative stuff for BMW F series. Of course they are selling but this may help:
f32christian19.50 |
04-09-2024, 10:47 AM | #3 |
20
Rep 63
keithyo88 i appreciate it. i just watched the video but it doesn’t really help me with my problem. he didn’t mention the steering rack, or the problems with the f30s steering racks
04-10-2024, 02:37 PM | #5 |
Idiotic lifter of heavy stones...
1997
Rep 2,183
Drives: 2015 F31 325D M Sport touring
Depends on the rack; if it's a ZF rack, you can undo the cap and try and tighten it down that way
If it's the Thyssenkrupp rack; you need the rack repair kit. BMW PN: 32106891974 https://f30.bimmerpost.com/forums/sh....php?t=1908892
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 |
04-10-2024, 03:10 PM | #7 | |
1997
Rep 2,183
What's it doing now? I know it does get to a point unfortunately where a replacement is the only fix But don't discount the arms, I had a knocking and turned out to the one of the ball joints on the main thrust arm / tension strut was failing & I'd get knocking that I couldn't suss out But I was also doing a complete suspension overhaul. That was done in Jan and now zero issues. Everything is tight as a drum
