10-16-2020, 01:13 AM | #1 |
Rep 15
Hey everyone, I have a 435i coupe xdrive. I really wanna kill the wheel gap on my car. Im thinking of getting bc racing coilovers. BR series. I'm looking for a tire-to-fender/stance look. I was wondering will the coilovers give me the look I'm going for because I know the RWD can go low but haven't seen nothing for the Xdrive, or should I go for the extreme lows. I do not have EDC
10-16-2020, 07:28 AM | #2 |
8297
Rep 16,186
The last thing I'd do in Toronto is to lower the car, unless you put it up for the winter. Lowered cars, snow and potholes are a bad combination.
10-16-2020, 07:45 AM | #3 |
41
Rep 71
I have coilovers on my xdrive, I played around with a few lowering options.
First 2 pics show my current ride height and I love it. Looks great imo, has a composed ride and comfortable over bumps. I also didn't worry about scraping. Second pic was when I had the car slammed all the way down just to see what it would look like. This lasted only a few hours. The ride felt noticeably worse due to less spring travel and I personally don't like the slammed look. It's also stressing the axles when it's that low so I didn't wanna cause any damage. Hope this helps! |
saigonair40.00 |
10-16-2020, 01:17 PM | #4 |
Modder of everything I own
147
Rep 491
I did this on my 2013 335i xdrive
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
10-16-2020, 07:53 PM | #5 |
313
Rep 272
Just get the standard BR, I’m pretty low on Emmanuel design springs and the axle angle makes me nervous to turn xdrive back on
Bt130916.50 SteveInfante604.00 |
10-16-2020, 10:56 PM | #6 | |
521
Rep 1,288
Drives: 2015 335i xdrive Msport Mbrake
10-17-2020, 04:56 PM | #7 | ||
41
Rep 71
10-17-2020, 05:16 PM | #8 |
521
Rep 1,288
10-23-2020, 07:52 PM | #9 |
5942
Rep 10,314
It's very important to note that as the suspension is lowered the negative camber increases. The chances breaking the front axle (half shaft) on lowered xDrive vehicles increase significantly if negative camber is greater than stock.
Four wheel alignment is highly recommended after lowering xDrive vehicles. |
12-04-2020, 08:49 PM | #10 |
521
Rep 1,288
Mun Mun zole2112 blumagic smak168 anielsen71 cfm56d7b
Hey guys ... just want to hear if anybody has issues with lowered Xdrives... I just got mine dropped 1-1/2" and just read someone has issues only after 3500miles dropped only 1-1/4" and yes he had an alignment.... your responses would be greatly appreciated... My Fender height is 25-3/4"Front & 25-7/8"Rear |
12-05-2020, 12:23 AM | #11 |
99
Rep 98
Hey FastF30.
I"ve had no issues...however, I only dropped by 1.0" fronts and 0.8" Rear. I also changed to F80 M3 bump stops which were about 1/2" shorter than my stock F36 bump stops. But was enough for me to get rid of that xdrive gap. Last edited by smak168; 12-05-2020 at 12:52 AM.. Reason: wrong measurement |
12-05-2020, 09:31 AM | #13 |
5942
Rep 10,314
smak168, thanks for sharing the pictures. Dropping xDrive suspension more than 0.8" - 1.0" wouldn't be prudent. Your drop is just right.
12-05-2020, 10:29 AM | #14 |
105
Rep 285
Drives: 2014 428i XDrive
Hey, just want to say. Be careful when dropping XDrives. I just broke my front axle and my ride height wasn't even that low (Bilstein B14s). But I do have wheel spacers and thicker wheels (8.5 front 9.5 rear)
12-05-2020, 11:01 AM | #15 |
994
Rep 1,934
"Wasn't even that low" is wildly subjective. Hard numbers or we can assume you were tucking tire.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
12-05-2020, 12:04 PM | #16 |
521
Rep 1,288
I'm just trying to figure this all out... what where your tire sizes exactly?... which knuckle of the axle failed... don't think spacers could have that effect except for bearing failure in the hub.. please let me know all data... others have said and most springs are set-up for 7/8" drop... I'm on coilovers so no biggy to change height..
12-05-2020, 12:19 PM | #17 |
173
Rep 139
Drives: f36 435i
Here is mine, lowered on H&R springs with winterwheels on
12-05-2020, 12:40 PM | #18 |
521
Rep 1,288
H&R springs say they are 1-5/8" drop or 40mm drop (I used this as my base when lowering)... can you please measure fender to ground ... and how long have you been dropped... also your car looks real nice...
12-05-2020, 06:33 PM | #19 | |
521
Rep 1,288
So let me know root cause and keep us updated.... thanks in advance... Last edited by FastF30; 12-05-2020 at 06:43 PM.. |
12-05-2020, 07:09 PM | #20 |
105
Rep 285
No accidents or pot holes. The cars has 34k miles haha
I'm in some shit situation right now haha... My only wheels are my Niche ones because I've sold my 17" Stock wheels (I guess it won't fit anyway, because I upgraded to 435i XDrive brakes), so I ordered BBS RS 18"x8" square setup with new tires ($2000 with TPMS), B6 Bilsteins Front and Rear ($650), Stock Springs + Stock Strut Hardware ($800 )... $1250 per axle (I hope it's just one...) and whatever the f*** the labor will be. I mean do whatever you want with your car, I'm just letting you know what I've experienced and going through now. It's whatever the highest setting Bilstein recommended for B14s were. Last edited by lonecitizenfour; 12-05-2020 at 07:18 PM.. |
12-05-2020, 07:30 PM | #21 | |
521
Rep 1,288
12-05-2020, 07:32 PM | #22 | |
521
Rep 1,288
P.s. check carparts for a used axle... another guy was getting axles for less than a couple hundred on there... |
