2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB B46 oil filter - wrong one?
      06-03-2017, 08:34 PM   #1
crabu2
142
Drives: Truck and ...
So I ordered a oil change kit from a board sponsor and went to change the oil... 1200 mile change on a 230xi.
I drain the oil and pull the old filter out... and when I look at it versus what I ws given, it looks like the wrong filter.. You can see the new and old filter..
Did I get the wrong filter? Also, how do you remove the filter from the cap to replace it?
BTW, I had to put the old filter back in..
Oh.. and the oil filter is a bear to remove.. where it's stuffed in the back! I did torque it back to 25nm, which was on the box of the new filter. You need a 27mm socket to remove the oil filter.
'20 240ix convertible
      06-03-2017, 08:46 PM   #2
overcoil
3074
Drives: M235i 6spd
Was the new filter too long ? I can't tell from the picture but it looks close.
The old filter pulls/snaps off the black cap. I usually wear gloves to grasp the filter off the cap.
      06-03-2017, 08:51 PM   #3
crabu2
142
No idea if it's to long, but I noticed right away that the old filter had that numb sticking off the bottom and the one they supplied did not. I didn't take a picture of it, but the oil in the center looked to be slightly different too.
I just looked up the part over at ECS and the picture they provide, for the filter, has the knub...
Here's the picture that ECS has showing and it matches whats in the car.
      06-03-2017, 08:51 PM   #4
pikcachu
pikcachu's Avatar
1400
Drives: M235i (F22 Red angel)
Looks the same to me. Just pull down the filter from the cap
      06-03-2017, 08:55 PM   #5
crabu2
142
Look at the bottom.. see the knub? The one they supplied that 3 little tabs like a clip, not a knub.
      06-03-2017, 09:01 PM   #6
overcoil
3074
Drives: M235i 6spd
Yeah, I see that nub,
I don't know what's going on with that - never seen anything like that - with the nub.
      06-03-2017, 11:56 PM   #7
pikcachu
pikcachu's Avatar
1400
ah I see.... maybe it has no function....
maybe check the part number on the old filter... it should be at the top or bottom printed on the filter
      06-04-2017, 12:43 AM   #8
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
That filter looks like part 11428570590 for a B38 engine or B46 engine used in Minis, you should have part 11428575211 for a B46 engine in an F22. If you go to realoem.com and input the last 7 digits of your VIN, you will be able to select parts that are specific to your car to confirm the part number.
crabu2141.50
      06-04-2017, 07:16 AM   #9
crabu2
142
That's it! I just went out and looked at the box and they gave me Filter 11428570590. I pretty much knew it couldn't be the same filter that came in the car, but I thought maybe it was one of those things that might allow them to be inter changeable. But I didn't want to chance it..
Thanks!!!.. Now to see how easy it will be to do an exchange...
      06-04-2017, 12:17 PM   #10
pikcachu
pikcachu's Avatar
1400
They should send you one for free it it was their fault. Else you probably need to ship it back and do an rma which is probably useless as it's like a $10 part and you might as well just order a new one so you skip waiting to ship it back and forth
      06-04-2017, 03:58 PM   #11
crabu2
142
The dealership is down the street from my office.. If they weren't, I'd be throwing a fit to get them to ship me the correct filter, since it was their mistake.. especially since I gave them the VIN as they requested.
      06-05-2017, 11:20 AM   #12
crabu2
142
Update.. Got an email from the dealer today.. They're going to overnight the correct filter.
      06-05-2017, 07:53 PM   #13
pikcachu
pikcachu's Avatar
1400
      07-19-2018, 05:35 PM   #14
dbcooper77
Drives: 2016 X1
I know this is an old thread, but...
I have a 2016 F48 and it requires an 11428570590 filter. The tops of the filters are quite clear, the 11428575211 is stamped "ONLY ... B46B ..." whereas the 11428570590 filter is stamped "ONLY ... B46A ...". And while I couldn't find it on the underhood stickers, there's an identifying plate on the passenger side of the engine block that identifies the engine in my X1 as a B46A.
So... there are BMWs with the "Mini" engine, and the different flavors of the B46 are used in different models within the same model year. The only way to be sure is to look for the plate on the engine itself. The filter designs are completely non-interchangeable.
And if anybody would like a great deal on a few 11428575211 filter kits, PM me... 'cause I've got 'em!
2addicts
