BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Bmw x2 led headlight coding
      08-09-2023, 10:43 AM   #1
anilahmed280716
Drives: BMW X2
Exclamation Bmw x2 led headlight coding
Hi there , need help with my BMW X2.
I bought an X2 in auction damaged. Headlight was damaged so had to buy a new one. I bought second hand headlight and bought new modules as old modules were either damaged or missing. I have put the new headlight together and connected it. I took it to a coder to get it coded. The results were that the angel eyes/drls work, the indicator within the headlight works however when it comes to the full beams and dipped beams, the light comes on but goes off after like maybe 3-5 seconds. The angel eyes/drls are always on and are working. It is only the main beam that goes off. Is this a coding issue? Please help!
      08-09-2023, 10:48 AM   #2
rice_rocket88
No_Country
298
Drives: E60 F48 F39
If it is anything like the older cars, then the modules do need to be reprogrammed. Sorry I can't say for sure if this is the issue or not, just that it's a very good possibility.
      08-11-2023, 09:02 AM   #3
anilahmed280716
Drives: BMW X2
Thanks for reply, I will retry the coding. Its just an annoying issue. It cant be the bulb as it turns on for 5 seconds then cuts off. Hope its coding as i dont want to take apart the bumper again. Accessing these lights modules are a pain in the ass!!!
      09-14-2023, 11:00 AM   #4
yupetc
390
Drives: 2015 X535i
If the beams turn on and then off after a few seconds, that's because the voltage monitoring system picked up voltages and amperages out of target. It's a short circuit protection mechanism. And if you keep operating it like this, the maximum instance count allowed is 50 times, after it picked up the 51st time during this circuitry check with the same fault, it'll disable the beams completely until you use ISTA to get that counter to reset. Check to see if the headlight you purchased is the same year/fit. Between years they sometimes may go through a facelift and swap some wires around or edit the circuitry a little bit, etc. to cause a voltage inconsistency.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP
2017 540i - MHD2+, VRSF DP, TU Pump
      10-08-2023, 03:28 AM   #5
kubax86
kubax86's Avatar
No_Country
1790
Drives: M2
Probably coding issue, we can help remotely.
